#1 Mon 21 April 2008 11:41
- Loo
[ArcGIS 9.1] Script réarrangement de champs
Salut Tutti!
Voici un code en python qui fonctionne PRESQUE !
J'arrive pas à trouver le bug, alors toutes suggestions bienvenues....
Mercimerci
import os,string,sys
import win32com.client
gp = win32com.client.Dispatch("esriGeoprocessing.GpDispatch.1")
FC_In = sys.argv[1]
NewOrder = "ID_GA25_CH;CODE_ZV;DESCRIPT;SYMBOL;AZIMUT;DIP;ORIENT;SPEC_VAL;SPEC_DESCR;REM"
FC_Out_WS = sys.argv[2]
FC_Out_Name = sys.argv[3]
strFields = gp.listfields(FC_In)
strNewOrder = NewOrder
Layers = [""]
# Get Field Collection into List
NewOrder = string.split(strNewOrder,";")
gp.AddMessage("C'est bien patri")
x=0 #NewOrder enumerator
y=0 #Layers enumerator (first)
# Cycles through the input feature class creating field collections
while x<len(NewOrder):
Fields.Reset()
Field = Fields.Next()
while Field:
FieldName = str(Field.name)
if x<len(NewOrder) and NewOrder[x].lower() == FieldName.lower():
Layers[y] = Layers[y] + FieldName + " " + NewOrder[x] + " VISIBLE"
x=x+1
else:
Layers[y] = Layers[y] + FieldName + " " + FieldName + " HIDDEN"
if Field:
Layers[y] = Layers[y] + "; "
else:
Layers.append("")
y=y+1
Layers[y]=""
# Use Field collections to create Layers with proper order until all fields have been used
z=0 #Layers enumerator (second)
LayerList = ""
for Layer in Layers:
if Layer <> "":
if LayerList <> "":
LayerList=LayerList + ";"
LayerList=LayerList + "Layer" + str(z)
gp.MakeFeatureLayer(FC_In, "Layer" + str(z),"#","#",Layer)
gp.addmessage("Mouais")
z=z+1
#Collect Info about Input Feature Class
dsc = gp.describe(FC_In)
fc_in_stype = dsc.shapetype
fc_in_sr = dsc.spatialreference
# Create new empty Feature class with desired fields
try:
gp.CreateFeatureClass(FC_Out_WS,FC_Out_Name,fc_in_stype,LayerList,"#","#",fc_in_sr)
gp.addmessage("Presque")
except:
gp.addmessage("Oups")
# Append Records to new feature class
gp.append_management(FC_In, FC_Out_WS + "\\" + FC_Out_Name)
gp.addmessage("TipTop")
del gpEt le message d'erreur...
Executing: TestOrder (...) Start Time: (...) Running script TestOrder... C'est bien patri Mouais Mouais Mouais Mouais Oups Error in script TestOrder. Error in executing: cmd.exe /C (...) Failed to execute (TestOrder). End Time: (...) (Elapsed Time: 9.00 seconds)
#2 Mon 21 April 2008 16:18
- Tnarbiv
- Lieu: Véretz
Re: [ArcGIS 9.1] Script réarrangement de champs
tu es en quelle version d'arcgis ?
#3 Mon 21 April 2008 17:01
- Loo
9.1
J'ai avancé un peu...
Maintenant, j'obtiens le nouveau shp, mais avec la table attributaire vide, et je ne sais vraiment pas quelle commande utiliser pour finaliser le tout.
FC_In = sys.argv[1]
Layers = [""]
Fields.Reset()
while Field:
x=x+1
else:
if Field:
else:
Layers.append("")
y=y+1
Layers[y]=""
LayerList = ""
if Layer <> "":
if LayerList <> "":
gp.addmessage(gp.getmessages()+ "\n")
z=z+1
try:
except:
del gpHors ligne
#4 Tue 22 April 2008 15:20
- Tnarbiv
- Lieu: Véretz
peux tu m'envoyer ta donnée d'origine pour que je fasse des tests
