#1 Tue 29 April 2008 17:22
nouraF
tracking
Nous travaillons sur un projet concernant le tracking…Et nous voulons afficher des itinéraires d’une base de données mysql sur une carte de RABAT (MAROC) grâce à Mapserver…On s’est sert d’un logiciel qui s’appelle GmapMaker  qui nous a permis de télécharger des portions de cartes Google Maps sous forme d’image de l’extention .jpg et son mapfile(.map) mais ce mapfile nous n’avons pas pu le lire sur mapserver  car sa structure ne ressemble pas à la structure officielle de mapfile de mapserver…
Voila le contenu de ce mapfile :
OziExplorer Map Data File Version 2.2
1 ,Map Code,
WGS 84,,   0.0000,   0.0000,WGS 84
Reserved 1
Reserved 2
Magnetic Variation,,,E
Map Projection,Mercator,PolyCal,No,AutoCalOnly,No,BSBUseWPX,No
Point01,xy,      0,      0,in, deg,   33, 36.602674,N,    7, 40.766602,W, grid, , , ,N
Point02,xy,   5376,   3328,in, deg,   33, 33.033069,N,    7, 33.845215,W, grid, , , ,N
Point03,xy,      0,   3328,in, deg,   33, 33.033069,N,    7, 40.766602,W, grid, , , ,N
Point04,xy,   5376,      0,in, deg,   33, 36.602674,N,    7, 33.845215,W, grid, , , ,N
Point05,xy,    768,      0,in, deg,   33, 36.602674,N,    7, 39.777832,W, grid, , , ,N
Point27,xy,   3328,   3072,in, deg,   33, 33.307741,N,    7, 36.481934,W, grid, , , ,N
Point28,xy,   4352,   3072,in, deg,   33, 33.307741,N,    7, 35.163574,W, grid, , , ,N
Point29,xy,       ,       ,in, deg,     ,          ,N,     ,          ,E, grid, , , ,N
Point30,xy,       ,       ,in, deg,     ,          ,N,     ,          ,E, grid, , , ,N
Projection Setup,,,,,,,,,,
Map Feature = MF ; Map Comment = MC     These follow if they exist
Track File = TF      These follow if they exist
Moving Map Parameters = MM?    These follow if they exist
MM0,Yes
MMPNUM,4
MMPXY,1,0,0
MMPXY,2,5376,0
MMPXY,3,5376,3328
MMPXY,4,0,3328
MMPLL,1,   -7.679443,   33.610045
MMPLL,2,   -7.564087,   33.610045
MMPLL,3,   -7.564087,   33.550551
MMPLL,4,   -7.679443,   33.550551
MM1B,1.989074
MOP,Map Open Position,0,0
IWH,Map Image Width/Height,5376,3328
On a essayé d’afficher juste l’image en tant qu’une couche raster en créant notre propre mapfile par des différentes possibilité mais en vain…Rien ne s’affiche !!!!!!
Et voila les deux mapfiles qu’on a utilisé :
Mapfile1 : example1.map
MAP
  IMAGETYPE      PNG24
  EXTENT         358900 369700 372450 385000
  SIZE           400 300
  SHAPEPATH      "C:\ms4w\apps\tutorial\data"
 LAYER # MODIS raster layer begins here
    NAME         modis
    DATA         "raster/rabat1.jpg"
    STATUS       OFF
    TYPE         RASTER
    END # MODIS raster layer ends here
END
http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example1.map&layer=modis&mode=map
Mapfile2 : mywms.map
MAP
NAME "WMS_RABAT"
EXTENT 359000 369700 363000 373000
STATUS ON
IMAGETYPE PNG24
UNITS METERS
PROJECTION
  "init=ESPG:2000"
END
WEB
  METADATA
    "wms_title"           "WMS_RABAT"
    "wms_onlineresource"  "http://localhost/cgi-bin/mapserv.exe?map=c:/ms4w/apache/htdocs/openlay/mywms.map&"
  END
END
LAYER
    NAME "rabat1"
    DATA "rabat1.png"
    STATUS ON
    TYPE RASTER
    UNITS METERS
    IMAGETYPE PNG24
    METADATA
        wms_title "rabat1"
        wms_srs   "EPSG:26191"
    END
END
END
http://localhost/cgi-bin/mapserv.exe?map=c:/ms4w/apache/htdocs/openlay/mywms.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=getmap&LAYERS=rabat1&HEIGHT=3328&WIDTH=5376
Je sais pas si j'ai été très claire. J'ai besoin d'aide rien que pour savoir ou chercher, et pour savoir vers quelles ressources se diriger.
Et je serai reconnaissante pour votre aide
Merci d’avance
Rabab
[EDIT moderation] Inutile de mettre tout votre texte en gras, ce n'est pas plus lisible wink
#2 Tue 29 April 2008 17:57
Yves
Lieu: Aix-les-Bains
Re: tracking
CE que vous avez tenté de faire est strictement illégal. Google n'utilisant pas Mapserver, vous avez récupéré des données qui vous seront inutilisable. D'autre part, ce que vous avez récupéré c'est l'image finale renvoyé par le serveur carto, ce dont vous avez besoin ce sont les données raster ou vecteur géoréférencé.
Regardez du côté d'openstreetmap et d'OpenAerialMap pour des données vecteur et raster.
Y.
#3 Tue 29 April 2008 21:21
nouraF
Re: tracking
Tout d'abord un grand merci pour les liens OpenStreetMap et OpenAerialMap .
Mais j'ai pas arrivé à comprendre comment récupérer des données raster ou data depuis ces deux liens
Merci encore pour votre aide
