#1 Fri 11 July 2008 15:30
- calito
Create a summary table
Lorsque j'utilise l'outil "Summary statistics" dans ArcToolsBox pour creer ma table, on me donne la possibilité de choisir un "Case Field", puis un champ "Frequency" est créé automatiquement. Mais avec ce code que j'ai vu sur edn.esri, je n'arrive pas à preciser le "Case Field". Ensuite, je'n sais pas comment faire pour que le champ frequency soit créé automatiquement.
Public Sub CreateSummaryTable(IntCount As Integer)
On Error GoTo EH
Dim pDoc As IMxDocument
Set pDoc = ThisDocument
Dim pMap As IMap
Set pMap = pDoc.FocusMap
' Find the layer named US_Counties
Dim pLayer As ILayer
Dim pFeatLayer As IFeatureLayer
Set pLayer = pMap.layer(IntCount) '(intCount)
Set pFeatLayer = pLayer
' Get the workspace of the US_Counties layer
Dim pFeatClass As IFeatureClass
Dim pTable As ITable
Dim pDataSet As IDataset
Dim pWkSpDS As IDataset
Dim pWkSpName As IName
Set pFeatClass = pFeatLayer.FeatureClass
Set pTable = pFeatClass
Set pDataSet = pTable
Set pWkSpDS = pDataSet.Workspace
Set pWkSpName = pWkSpDS.FullName
' The output is set to SumSample.dbf file in c:\temp
Dim pWkSpFactory As IWorkspaceFactory
Dim pWkSp As IWorkspace
' Dim pWkSpDS As IDataset
' Dim pWkSpName As IWorkspaceName
Dim pOutDSName As IDatasetName
Set pWkSpFactory = New ShapefileWorkspaceFactory
Set pWkSp = pWkSpFactory.OpenFromFile("c:\temp", 0)
Set pWkSpDS = pWkSp
Set pOutDSName = New TableName
pOutDSName.Name = "SumSample"
Set pOutDSName.WorkspaceName = pWkSpName
' Make sure there is a field called state_name in the layer
'If pTable.FindField("Shape_Area") = -1 Then
' MsgBox "There must be a field named state_name in US_Counties"
' Exit Sub
'End If
' Perform the summarize. Note the summary fields string (minimum.state_name ...)
' below. This is a comma-delimited string that lists the generated summary
' fields. Each field must start with a keyword, and be followed by .fieldName,
' where fieldName is the name of a field in the original table.
' If you specify the Shape field, you must use the keyword 'Dissolve'. This
' is not used below since we are creating a non-spatial summary table.
Dim pGeoProc As IBasicGeoprocessor
Dim pSumTable As ITable
Set pGeoProc = New BasicGeoprocessor
Set pSumTable = pGeoProc.Dissolve(pTable, False, "years", "Sum.Shape_Area", pOutDSName)
' add the table to map
Dim pStTab As IStandaloneTable
Set pStTab = New StandaloneTable
Set pStTab.table = pSumTable
Dim pStTabColl As IStandaloneTableCollection
Set pStTabColl = pMap
pStTabColl.AddStandaloneTable pStTab
' Refresh the TOC
pDoc.UpdateContents
Exit Sub
EH:
MsgBox Err.Number & " " & Err.Description
End SubEst-ce que qqn peut m'aider? SVP.
#2 Thu 17 July 2008 15:00
- calito
Re: Create a summary table
SVP Aidez moi.
#3 Thu 17 July 2008 16:02
- freesnowpetrel
- Lieu: Pretoria, Afrique du Sud
Peux tu detailler un peu plus ton probleme s'il te plait ?
Je ne comprend pas ce que tu veux faire exactement, et je ne suis peut-etre pas le seul puisque personne ne te repond...
Personnellement je ne comprend pas pourquoi tu veux utiliser ce script VBA alors que tu sembles avoir ce que tu veux dans la toolbox ??? Est-ce pour creer un outil personnalise ?? Un script pour automatiser une action repetitive ??? Donnes nous plus de details si tu veux de l'aide.
Rodolphe
#4 Thu 17 July 2008 16:42
- Tnarbiv
- Lieu: Véretz
où se trouve l'outil Summary statistics dans ArcToolbox ?
#5 Thu 17 July 2008 17:09
- freesnowpetrel
C'est dans Arctoolbox>analysis tools>statistics>Summary statistics
#6 Thu 17 July 2008 17:24
- Tnarbiv
- Lieu: Véretz
ok
le champ case field correspond au champ sur lequel tu souhaites t'appuyer pour lancer la récapitulation.
le champ frequency créé automatiquement par arctoolbox est également généré par ton bout de code mais il commence par Cnt_, c'est normalement le 3è champ de ta table
dans ton code le case field correspond au troisième paramètre de cette ligne
soit dans ton cas le champ years
autre chose aussi : cet outil n'existe pas que dans ArcToolbox, il existe existe aussi lorsque tu as une table ouverte et que tu fais un clic droit sur le nom d'un champ. Dans le menu contextuel tu as l'outil Récapituler ou bien Summarize
#7 Thu 17 July 2008 17:48
- calito
Ni le troiseme parametre, ni le champ Frequency n'ont pas ete cree dans la table. J'ai vu que les champs ObjetcID et Shape_area.
#8 Thu 17 July 2008 17:51
- calito
Ce que je voulais faire c'est que:
Dans la table attributaire il y a plusieurs objets qui ont les memes années. Donc, je voulais creer une table qui me dit pour chaque année (Champ years) voila combien d'objet qu'il y a (champ frequency).
#9 Thu 17 July 2008 17:52
- Tnarbiv
- Lieu: Véretz
c'est bizarre, j'ai fais le test chez moi avec mes données et tout marche nickel !!!
que souhaites tu faire exactement ?
peux tu traduire ton bout de code littéralement pour que l'on comprenne mieux et que l'on puisse t'aider un peu plus ?
Dernière modification par Tnarbiv (Thu 17 July 2008 17:52)
#10 Thu 17 July 2008 18:00
- calito
Comme je l'avait dit, c'est un code que j'ai trouvé sur edn.esri.
Est-ce que je peux voir ton code?
#11 Thu 17 July 2008 20:40
- Tnarbiv
- Lieu: Véretz
mon code est identique à celui d'edn
peux tu m'envoyer tes données pour que je puisse tester
Dernière modification par Tnarbiv (Thu 17 July 2008 20:42)
#12 Fri 18 July 2008 09:43
- freesnowpetrel
Pourquoi ne pas faire ce genre de manip qui releve plus du tableur, dans un tableur a partir de ta table d'attribut au format dbf. Ce sera beaucoup plus simple et plus rapide, un simple tableau croise dynamique devrait repondre a ton besoin, si j'ai bien compris...
Rodolphe
#13 Fri 18 July 2008 14:32
- calito
Voici le code:
On Error GoTo EH
Dim pMap As IMap
Set pWkSpDS = pWkSp
pOutDSName.Name = "Yeah"
If pTable.FindField("years") = -1 Then
Exit Sub
End If
' Refresh the TOC
pDoc.UpdateContents
Exit Sub
EH:
End SubHors ligne
#14 Fri 18 July 2008 14:40
- Tnarbiv
- Lieu: Véretz
je ne veux pas le code mais les données sur lesquelles tu veux tester le code !!!!
#15 Mon 21 July 2008 08:52
- calito
Excuse moi, je n'ai aucune droit de diffuser les données. Par contre, est-ce que tu peux me montrer ton code?
#16 Mon 21 July 2008 09:39
- Tnarbiv
- Lieu: Véretz
je te rappelle que mon code est identique à celui d'edn !!!!
Public Sub CreateSummaryTable()
On Error GoTo EH
Dim pMap As IMap
Dim intCount As Integer
For intCount = 0 To pMap.LayerCount - 1
Set pLayer = pMap.Layer(intCount)
If TypeOf pLayer Is IFeatureLayer Then
If pLayer.Name = "XXXX" Then
Exit For
End If
End If
Next
If pFeatLayer Is Nothing Then
MsgBox "The XXXX layer was not found"
Exit Sub
End If
' Get the workspace of the DDASS layer
Set pWkSpDS = pWkSp
If pTable.FindField("test") = -1 Then
MsgBox "There must be a field named state_name in XXXX"
Exit Sub
End If
Set pSumTable = pGeoProc.Dissolve(pTable, False, "test", "Minimum.test, Count.test, Maximum.test,Minimum.test1, Maximum.test1", pOutDSName)
' Refresh the TOC
pDoc.UpdateContents
Exit Sub
EH:
End SubAyez le réflexe "Développement Durable": N'imprimez ce message que si nécessaire.
#17 Mon 21 July 2008 16:07
- calito
Okey c'est bon maintenant, Merci pour ton aide Tnarbiv.
