#1 Wed 09 December 2009 17:29
Robin
GeoRezo forever
GDAL - Driver pour lire les GRID provenant de SAGA GIS
Hello,
En test pour la prochaine version 1.7 de GDAL, un driver pour lire/écrire des grids provenant de SAGA GIS.
A suivre dans la prochaine version s'il n'y a pas de bugs.
L'intérêt ? Vu que GDAL est partagé et utilisé par de nombreuses applications, les liens depuis SAGA GIS vers d'autres softs vont se renforcer smile
Référence originale sur la liste SAGA GIS :
Dear SAGA users, we finally managed to implement a SAGA driver for GDAL, which will allow you to read and write SAGA grids from applications that use GDAL for import/export. Thanks to Even Rouault, Frank Wamerdam and Roger Bivand for their help! The driver is now in GDAL trunk and needs to be tested. I would encourage you to help us testing. If everything works fine, the driver will be available in GDAL 1.7 released within a few weeks. Those of you who compile SAGA theirselves could download GDAL trunk and build a custom GDAL library. Trunk compiles well under windows and linux. For all others who are willing to test I have prepared a new windows binary build on the [laserdata homepage][1] including a SAGA cvs snapshot from today and GDAL17dev library from today. You can use the GDAL Import/Export module to read and write SAGA grids, and verify the results by loading (or saving) them with SAGA directly/natively. Please report any problems you encounter with the driver, thanks, Volker [1]: http://www.laserdata.at/saga_packages.html
Robin.
Dernière modification par Robin (Wed 09 December 2009 20:01)
#2 Wed 09 December 2009 17:32
Yves
Lieu: Aix-les-Bains
Re: GDAL - Driver pour lire les GRID provenant de SAGA GIS
Robin,
tu vas pouvoir traduire la doc du format SAGA GIS de GDAL-OGR dans le wiki wink
Y.
#3 Wed 09 December 2009 19:56
Robin
GeoRezo forever
Erf... ya du boulot avec ILWIS déjà hmm Je jetterai un coup d'oeil quand ca sera publié, s'il n'y a pas trop à traduire je ferais passer en haut de la pile wink
R.
#4 Thu 10 December 2009 21:30
rouault
Non, il n'y a pas grand chose à traduire : http://gdal.org/frmt_various.html#SAGA
#5 Fri 11 December 2009 09:08
Yves
Lieu: Aix-les-Bains
De toute façon je m'y mettrais en janvier. Une partie (de la version 1.7) est déjà traduite wink Ce n'est plus un gros boulot maintenant smile
Y.
