#1 Wed 10 March 2010 11:23
Geomatikman
OpenLayer/Mapserver/wms
je voudrai afficher une  carte qui a de sys de projection: RGF93_Lambert_93 et sys : géo GCS_RGF_1993. Je suis encore débutant et j'arrive pas encore à l'afficher sous mapserver/openlayer
Voici mes code :
MAPFILE:
MAP
  NAME "mywms"
  IMAGETYPE      PNG
  STATUS         ON
  EXTENT         348668.554800 6612329.853000  439554.810600 6698167.309200
  SIZE           1000 600
  UNITS          METERS
  SHAPEPATH      "C:/ms4w/apps/SHP"
  IMAGECOLOR     205 205 155
  TRANSPARENT on
WEB
        TEMPLATE "C:/ms4w/Apache/htdocs/WorkShop1.html"
         IMAGEPATH "C:/ms4w/Apache/htdocs/tmp/"
        IMAGEURL '/ms_tmp/'
        METADATA
            ### WMS
              "wms_title"                "WMS Demo Server"
              "wms_onlineresource"    "localhost/cgi-bin/mapserv.exe?map=C:/ms4w/apps/SHP/fifth.map&"
              "wms_srs"                "epsg:2154"
              "wms_format"             "image/png"
              ### WFS
              "wfs_title"                "WFS Demo Server"
            "wfs_onlineresource"       "localhost/cgi-bin/mapserv.exe?map=C:/ms4w/apps/SHP/fifth.map&?"  ## Recommended
            "wfs_srs"               "epsg:2154"  ## Recommended
        END
    END
    PROJECTION
        "init=epsg:2154"
    END
    OUTPUTFORMAT
        NAME png
        DRIVER "GD/PNG"
        MIMETYPE "image/png"
        IMAGEMODE PC256
        EXTENSION "png"
        TRANSPARENT off
    END
LAYER
            NAME RIVIERE
            STATUS ON
            METADATA
                ### WMS
                "wms_title"    "RIVIERE"
                ### WFS
                "wfs_title"    "RIVIERE"
                "gml_featureid" "NAME"
                "gml_include_items" "all"
            END
            PROJECTION
                "init=epsg:2154"
            END
            DUMP TRUE
            TYPE POLYGON
            STATUS ON
            DATA RIVIERE
            CLASS
                COLOR 217 217 217
                OUTLINECOLOR 0 0 0
            END
    END###### END OF Layer ######
END ###### END OF Map File  ######
et voila mon script;
function init(){
    var map = new OpenLayers.Map('map');
    var wms=new OpenLayers.Layer.Mapserver("TEST","http://localhost/cgi-bin/mapserv.exe",{map:'C:/ms4w/apps/SHP/fifth.map'});
    var OverLayer = new OpenLayers.Layer.WMS("OverLayers", "http://localhost/cgi-bin/mapserv.exe",
              {layers: ['RIVIERE'], format: "image/png"},
              {singleTile: true, minResolution: 1000});
         map.addLayer(wms);
         map.addLayers([overlay]);
         map.setBaseLayer(wms);
         map.zoomToMaxExtent();
Ou se trouve elle l'erreur???Y a t-il une solution complète??
