#1 Mon 26 April 2010 16:16
- mlking31
Création de cartes à la chaine
Bonjour à toutes et à tous,
Je voudrais exporter en lot des cartes au jormat jpeg mais j’aimerais qu’elles soient centrées sur une commune différentes à chaque exportation.
J’ai fait mon .wor que je souhaite
!Workspace
!Version 700
!Charset WindowsLatin1
Open Table "C\...\communes dep13" As communes_dep13 Interactive
Set Window Info
Position (9.48958,5.30208) Units "in"
Width 2.60417 Units "in" Height 4.69792 Units "in"
Font ("Arial",0,8,0)
Open Window Info
Map From communes_dep13
Position (0.0520833,0.0520833) Units "in"
Width 6.66667 Units "in" Height 4.47917 Units "in"
Set Window FrontWindow() ScrollBars Off Autoscroll On
Set Map
CoordSys Earth Projection 3, 1002, "m", 0, 46.8, 45.898918964419, 47.696014502038, 600000, 2200000
Center (851298.3575,1816638.506)
Zoom 37.51688603 Units "km"
Preserve Zoom Display Zoom
Distance Units "km" Area Units "sq km" XY Units "m"
Set Map
Layer 1
Display Graphic
Global Pen (1,2,0) Brush (2,16777215,16777215) Symbol (35,0,12) Line (1,2,0) Font ("Arial",0,9,0)
Label Line None Position Center Font ("Arial",0,9,0) Pen (1,2,0)
With COMMUNE
Parallel On Auto Off Overlap Off Duplicates On Offset 2
Visibility On
Set Window FrontWindow() Printer
Name "PDFCreator09" Orientation Portrait Copies 1
Papersize 9
Layout
Position (1.86458,1.80208) Units "in"
Width 6.625 Units "in" Height 4.47917 Units "in"
Dim uniqueStringName As String
uniqueStringName = "Set " + SessionInfo(1)
Set CoordSys Layout Units "in"
Create Frame (0.1965,0.1965) (8.0708,11.4958)
Pen (1,2,0)
Title "communes_dep13 Carte"
FillFrame On
Set Layout Ruler On Pagebreaks On Frame Contents Active
Zoom 76.247 Center (4.06329,2.6777) Extents To Fit
Set Window FrontWindow() Autoscroll On
Run Command uniqueStringName
Undim uniqueStringName
Papersize 9
Dim WorkspaceMaximizedWindow As Integer
WorkspaceMaximizedWindow = Frontwindow()
Set Window WorkspaceMaximizedWindow Max
Undim WorkspaceMaximizedWindow
save window Frontwindow() as "C:\...\aix.jpg" type "JPEG" resolution 150
Close All Interactivecependant je ne sais pas trop comment jouer avec le zoom ni la position de la carte
J'ai trouver une étude qui correspond parfaitement a ce que je veux faire
http://www.ppige-npdc.fr/article.php3?id_article=105
(lien direct vers le pdf qui explique --> http://www.ppige-npdc.fr/documentation/ … pinfo.zip)
Voila merci.
#2 Mon 26 April 2010 17:21
- Spacejo
- Lieu: Nancy
Re: Création de cartes à la chaine
Ce travail peut être fait en batch avec la FMB couplée avec un générateur de script.
A voir:
Il te suffit d'ajouter le zoom et le centre de la fenêtre dans:
http://www.forumsig.org/showthread.php? … hlight=pdf
Joël
Dernière modification par Spacejo (Mon 26 April 2010 17:39)
#3 Mon 26 April 2010 19:02
- Maurice
- Lieu: Montpellier
Voir - entre autres - ce sujet...
#4 Mon 10 May 2010 11:24
- mlking31
désolé j'ai oublier de vous remercier pour les liens,
Merci bien
