Rencontres QGIS 2027
#1 Fri 14 May 2010 09:28
bannour
[arcview 3.2] mettre à jour la table attributaire
j'ai longtemps que je n'ai pas utilisé arcview et donc j'ai un petit problème.
Comment mettre à jour la table attributaire après changement de projection ?
remarque: j'ai essayé  le script calcapl.ave mais, les valeurs des champs restent inchangées .
c quoi le problème?
' Name:  View.CalculateFeatureGeometry
' Title:  Calculates feature geometry values
' Topics:  GeoData
' Description:  Calculates area and perimeter for polygon themes and length
' for line themes. If the View has been projected the calculations are in
' projected meters. Otherwise the calculations are in 'native' map units.
' Modify the script to provide calculation in the current report units of
' the View. The script processes the list of active themes to calculate
' area and perimeter, or length, depending on the theme type.
' The script will add the fields: Area and Perimeter to polygon themes, Length
' to line themes if they do not exist. If the fields exist their values will
' be recalculated. Rerun the script if you change the projection of the view.
' Requires:  A View with at least one active theme.  You must have write access
' to the active theme(s).
' Self:
' Returns:
' Get the view and its projection if any.
theView = av.GetActiveDoc
thePrj = theView.GetProjection
if (thePrj.IsNull) then
  hasPrj = false
else
  hasPrj = true
end
' Get the list of active themes. if there aren't any, let the user know
' and exit.
theActivethemeList = theView.GetActivethemes
if (theActivethemeList.Count = 0) then
  MsgBox.Error("No active themes.","")
  Exit
end
' Loop through the list of active themes. if you can't edit the theme
' inform the user.
For Each thetheme in theActivethemeList
  theFTab = thetheme.GetFTab
  if (theFTab.CanEdit.Not) then
    MsgBox.Info("Cannot edit table for theme:"++thetheme.AsString,"")
    Continue
  end
  ' Make the FTAB editable, and find out which type of feature it is.
  theFTab.SetEditable(TRUE)
  theType = theFTab.FindField("shape").GetType
  if (theType = #FIELD_SHAPEPOLY) then
    ' if it's polygonal check for the existence of the fields "Area" and
    ' Perimeter. if they do not exist, create them.
    if (theFTab.FindField("Area") = nil) then
      theAreaField = Field.Make("Area",#FIELD_DOUBLE,16,3)
      theFTab.AddFields({theAreaField})
    else
      ok = MsgBox.YesNo("Update Area?", "Calculate", true)
      if (ok.Not) then
        continue
      end
      theAreaField = theFTab.FindField("Area")
    end
    if (theFTab.FindField("Perimeter") = nil) then
      thePerimeterField = Field.Make("Perimeter",#FIELD_DOUBLE,16,3)
      theFTab.AddFields({thePerimeterField})
    else
      ok = MsgBox.YesNo("Update Perimeter?", "Calculate", true)
      if (ok.Not) then
        continue
      end
      thePerimeterField = theFTab.FindField("Perimeter")
    end
    ' Loop through the FTAB and find the projected area and perimeter of each
    ' shape and set the field values appropriately.
    theShape = theFTab.ReturnValue(theFTab.FindField("shape"),0)
    For Each rec in theFTab
      theFTab.QueryShape(rec,thePrj,theShape)
      theArea = theShape.ReturnArea
      thePerimeter = theShape.ReturnLength
      theFTab.SetValue(theAreaField,rec,theArea)
      theFTab.SetValue(thePerimeterField,rec,thePerimeter)
    end
  elseif (theType = #FIELD_SHAPELINE) then
    ' if the data source is linear, check for the existence of the
    ' field "Length". if it doesn't exist, create it.
    if (theFTab.FindField("Length") = nil) then
      theLengthField = Field.Make("Length",#FIELD_DOUBLE,16,3)
      theFTab.AddFields({theLengthField})
    else
      ok = MsgBox.YesNo("Update Length?", "Calculate", true)
      if (ok.Not) then
        continue
      end
      theLengthField = theFTab.FindField("Length")
    end
    ' Loop through the FTAB and find the projected length of each shape and set
    ' the field values appropriately.
      theLength = theShape.ReturnLength
      theFTab.SetValue(theLengthField,rec,theLength)
    end
  end
  theFTab.SetEditable(FALSE)
end
Dernière modification par bannour (Fri 14 May 2010 09:42)
