#1 Sun 01 August 2010 14:49
j.a.yasser
afficher shape en WFS
bonjour
je veu utilisé le WFS pour afficher ma shape en utilisant openlayers
voila le code openlayers
<html>
 <head>
 <script src="http://openlayers.org/api/2/OpenLayers.js"></script>
 <script src="pathTo/olExtToolTips.js" type="text/javascript""></script>
  <script src="http://maps.google.com/maps?file=api&v=2&key=YourKey"
        type="text/javascript"></script>
 </head>
 <body>
test de map centrer et cadrer
 <center>
 <table border="3">
<tr>
<td>
   <div style="width:500; height:300" id="map">
   </div>
   <div id="slider">
     <div class="ui-slider-handle"></div>
  </div>
  <div>Système de Projection WGS84</div>
   <script defer="defer" type="text/javascript">
   var mymap = null;
   var nav = new OpenLayers.Control.NavigationHistory();
 mymap = new OpenLayers.Map('map');
 var mylayers = new OpenLayers.Layer.WFS('exemples',
 "http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/tessst/postgisWFS.map&",
 {typename: 'states', maxfeatures: 10},
                 { featureClass: OpenLayers.Feature.WFS, isBaseLayer: true},{projection: "EPSG:4326"});
 mymap.addLayer(mylayers);
 </script>
   </td>
  </tr>
  </table>
  <input type="submit" name="lenomketuveu">
 </center>
 </form>
 </body>
 </html>
pour le mapfile
MAP
   NAME WFS_server
   STATUS ON
   IMAGETYPE      PNG
   EXTENT         -97.238976 41.619778 -82.122902 49.385620
   SIZE           400 300
   SHAPEPATH      "C:/ms4w/apps/tessst"
   IMAGECOLOR     255 255 255
   # Definições para servidor WFS
   WEB
     IMAGEPATH "/ms4w/tmp/"
     IMAGEURL "/tmp/"
     METADATA
       "wfs_title" "GMap WFS Demo Server"
       "wfs_onlineresource" "http://localhost/cgi-bin/mapserv.exe?"
       "wfs_srs" "EPSG:4326"
     END
   END
# Start of LAYER DEFINITIONS
   LAYER # States polygon layer begins here
   CONNECTION "host='localhost' dbname='postgis' user='postgres' password='yasser' port='5432'"
  CONNECTIONTYPE POSTGIS
  DATA "the_geom from (select * from states) foo USING UNIQUE gid"
     NAME         states
     METADATA
       "wfs_title" "states"
       "gml_includeitems" "all"
    "gml_excludeitems" ""
     END
     PROJECTION
       "init=EPSG:4326"
     END
     STATUS       ON
     TYPE         POLYGON
     DUMP TRUE
     CLASS
       NAME       "The Upper Great Lakes States"
       STYLE
         COLOR        132 232 132
         OUTLINECOLOR 32 32 32
       END
     END
   END # States polygon layer ends here
   # End of LAYER DEFINITIONS -------------------------------
END
le shape n affiche pas dans le navigateur
j attend votre aide
Merci d avance
#2 Sun 01 August 2010 14:53
j.a.yasser
Re: afficher shape en WFS
quand j execute le mapfile seulement il affiche le shap
http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/tessst/postgisWFS.map&layer=states&mode=map
donc je pense le probleme dans l openlayers
#3 Thu 05 August 2010 16:18
Yves
Lieu: Aix-les-Bains
Ceci n'est pas une requête WFS, pour tester il vaut mieux faire une vrai requête. Un peu de lecture : http://georezo.net/wiki/main:standards: … ndards_wfs
Y.
#4 Fri 06 August 2010 16:07
j.a.yasser
bonjour
si vous pouvez me donnée un exemple de vrai requete pour tester
merci pour votre aide
#5 Sat 07 August 2010 04:06
amine596
Exactement Yasser. Tu dois tester en utilisant une requete WFS.
#6 Sat 07 August 2010 14:00
j.a.yasser
merci tous le monde
j ai réussi a affichez mon shape en WFS
mais le problème quand je clic sur un attribue dans le map il m'affiche un Popup mais il arrive pas a sélectionne l information demandé
j'utilise le code suivant:
var htmlContent = "<b>gid : "+e.attributes.gid+"</b><br />";
il affiche gid = undefined
vous avez une information c'est quoi le probleme???
#7 Mon 09 August 2010 17:25
j.a.yasser
pas de remarque??
pas de reponse??
#8 Tue 14 September 2010 10:31
Lilou1863
Je me permet d'écrire sur votre sujet, en espérant ne pas le faire dériver...
Je réalise un état de l'art sur les technologies de WebSIG / WebMapping, et je m'intéresse donc au flux WFS. J'ai réussie à trouver de la documentation assez générale sur l'intérêt et le fonctionnement, par contre je ne trouve rien pour connaître la création de tel flux.
Je me tourne donc vers vous, étant donné que vous en mettez en place.
Comment procédez-vous? Faut-il un outil particulier qui génère de tel flux? Je crois comprendre qu'il s'agit de programmation, mais c'est au niveau de l'architecture des outils nécessaire que je m'interroge.
J'espère avoir été assez claire.
Merci d'avance!
#9 Tue 14 September 2010 10:36
Jeirhome
Lieu: Liverion
Bonjour, j'en ai parlé récemment dans un sujet à côté, mais apparemment vous ne l'avez pas vu, il existe un comparatif des solutions OpenSource de WebMappingréalisé par Laurent Jégou.
Vous aurez pas mal de réponse concernant l'architecture des outils avec ce comparatif.
Jérôme Cuinet
#10 Tue 14 September 2010 10:51
Yves
Lieu: Aix-les-Bains
Merci d'avance!
Il faut mettre en place un serveur WFS. Le site de l'OGC propose une liste de serveur Open source et propriétaire supportant les services WFS.
http://www.opengeospatial.org/resource/products
Y.
