#1 Tue 03 August 2010 12:42
GeoPAN
[OpenLayers] WMSGetFeatureInfo n'affiche rien
Bonjour.
Depuis la création d'un magasin à partir duquel je peux ajouter des couches à ma carte, la fonction WMSGetFeatureInfo ne retourne plus aucun résultat. Tout marchait bien quand je définissais les couches directement dans le map.
Voilà mon bouton info :
//Info control, a "button" control
action = new GeoExt.Action({
    control: new OpenLayers.Control.WMSGetFeatureInfo({
        url: 'http://[serveur]/geoserver/wms',
        title: 'Identify features by clicking',
        queryVisible: true,
        eventListeners: {
            getfeatureinfo: function (event) {
                var output = event.text,
                    idialog = new Ext.Window({
                        title: "Feature Info",
                        layout: "fit",
                        //autoHeight: true,
                        width: 800,
                        Height: 600,
                        plain: true,
                        constrain: true,
                        items: [{
                            border: true,
                            bodyStyle: {
                                padding: 5,
                                fontSize: 13
                            html: output
                idialog.show();
        out: true
    tooltip: 'Info: click in the map to get object attribute info',
    map: map,
    iconCls: 'info',
    toggleGroup: 'map'
Et voilà à partir de quoi je contrôle les couches que je peux ajouter à ma carte.
// create a new WMS capabilities store
var store = new GeoExt.data.WMSCapabilitiesStore({
    url: "http://[serveur]/geoserver/wms?request=getCapabilities"
// load the store with records derived from the doc at the above url
store.load();
//***     Grid Config        ***
var xg = Ext.grid;
// row expander
var expander = new Ext.grid.RowExpander({
    tpl: new Ext.Template("<p><b>Abstract :</b> {abstract}</p>")
var sm = new xg.CheckboxSelectionModel();
//var sm = new xg.RowSelectionModel({singleSelect:true});
// create a grid to display records from the store
var grid = new xg.GridPanel({
    store: store,
    plugins: [expander],
    cm: new xg.ColumnModel({
        defaults: {
            width: 120,
            sortable: true
        columns: [
        expander, sm,
            header: "Name",
            dataIndex: "name",
            sortable: true
        //{header: "Workspace", dataIndex: "name", , sortable: true},
            header: "Title",
            dataIndex: "title",
            sortable: true
    sm: sm,
    autoExpandColumn: "title",
    height: 300,
    width: 650,
    floating: false,
    x: 10,
    y: 0,
    bbar: ["->",
        //text:"Add Layers",iconCls:"icon-addlayers"
        tooltip: "Add Layer to the map",
        iconCls: "mapadd",
        handler: function () {
            var record = grid.getSelectionModel().getSelected();
            if (record) {
                var copy = record.copy();
                // Ext 3.X does not allow circular references in objects passed
                // to record.set
                copy.data["layer"] = record.get("layer");
                copy.get("layer").mergeNewParams({
                    format: "image/png",
                    transparent: "true"
                    isBaseLayer: false,
                    buffer: 0
                mapPanel.layers.add(copy);
                mapPanel.map.zoomToExtent(
                OpenLayers.Bounds.fromArray(copy.get("llbbox")));
        scope: this
Il s'agit de bouts de code récupérés sur différents tuto sur le net. Je ne comprends pas complètement la logique de l'alchimie GeoExt, Extjs, OpenLayer mais mis à part ce GetFeatureInfo, ça marche plutôt pas mal.
En espérant une solution des experts du forum.
#2 Tue 03 August 2010 13:11
Yves
Lieu: Aix-les-Bains
Re: [OpenLayers] WMSGetFeatureInfo n'affiche rien
Première chose à tester généralement quand cela ne marche pas : la requête envoyée par OL est elle correcte ? Il faut utiliser firebug pour récupérer l'url.
Y.
#3 Tue 03 August 2010 16:23
GeoPAN
Le problème c'est que firebug n'affiche aucune url, j'ai l'impression que le controle associé au bouton ne se lance même pas.
