#1 Fri 17 September 2010 20:04
cro
gdal_csharp sous Ubuntu ?
Bonjour, j'essaie de compiler un programme avec Mono en utilisant gdal_csharp. Le programme compile sans problème, mais a l'exécution je reçois cette exception:
Unhandled Exception: System.TypeInitializationException: An exception was thrown by the type initializer for OSGeo.GDAL.GdalPINVOKE ---> System.TypeInitializationException: An exception was thrown by the type initializer for SWIGExceptionHelper ---> System.DllNotFoundException: gdal_wrap
  at (wrapper managed-to-native) OSGeo.GDAL.GdalPINVOKE/SWIGExceptionHelper:SWIGRegisterExceptionCallbacks_Gdal (OSGeo.GDAL.GdalPINVOKE/SWIGExceptionHelper/ExceptionDelegate,OSGeo.GDAL.GdalPINVOKE/SWIGExceptionHelper/ExceptionDelegate,OSGeo.GDAL.GdalPINVOKE/SWIGExceptionHelper/ExceptionDelegate,OSGeo.GDAL.GdalPINVOKE/SWIGExceptionHelper/ExceptionDelegate,OSGeo.GDAL.GdalPINVOKE/SWIGExceptionHelper/ExceptionDelegate,OSGeo.GDAL.GdalPINVOKE/SWIGExceptionHelper/ExceptionDelegate,OSGeo.GDAL.GdalPINVOKE/SWIGExceptionHelper/ExceptionDelegate,OSGeo.GDAL.GdalPINVOKE/SWIGExceptionHelper/ExceptionDelegate,OSGeo.GDAL.GdalPINVOKE/SWIGExceptionHelper/ExceptionDelegate,OSGeo.GDAL.GdalPINVOKE/SWIGExceptionHelper/ExceptionDelegate,OSGeo.GDAL.GdalPINVOKE/SWIGExceptionHelper/ExceptionDelegate)
  at OSGeo.GDAL.GdalPINVOKE+SWIGExceptionHelper..cctor () [0x00000]
  --- End of inner exception stack trace ---
  at OSGeo.GDAL.GdalPINVOKE..cctor () [0x00000]
  at OSGeo.GDAL.Gdal.AllRegister () [0x00000]
  at gdal_demo1.MainClass.Main (System.String[] args) [0x00000]
Alors comment faire pour utiliser gdal_csharp sous Linux ?
#2 Mon 20 September 2010 12:07
LionelR
Re: gdal_csharp sous Ubuntu ?
jamais codé en C# mais vu le "System.DllNotFoundException: gdal_wrap", me dis qu'il y a de grandes chances que ca puisse venir de là smile
#3 Mon 20 September 2010 13:53
Sylvain33
Lieu: Mauritius
Quel est l'intérêt d'utiliser le C# ?
#4 Mon 20 September 2010 13:56
LionelR
Sylvain33 a écrit:
Certainement autant que d'utiliser Java : aucun :-D
<mode troll=off>
#5 Mon 20 September 2010 14:19
Sylvain33
Lieu: Mauritius
Non mais je voulais insinuer que le C# c'est orienté Windows ...
#6 Mon 20 September 2010 14:32
LionelR
Ah bin deux trolls dans un topic, manque plus qu'à faire pousser la forêt big_smile
#7 Mon 20 September 2010 14:42
ThomasG
Lieu: Nantes
Hors trolls, plusieurs pistes:
http://gdalnet.codeplex.com/
ou
bien envoyer un mail sur la mailing-list gdal-dev http://lists.osgeo.org/mailman/listinfo/gdal-dev (l'auteur du blog http://szekerest.blogspot.com/ qui maintient le "binding" csharp pour gdal devrait pouvoir aider, étant sur la mailing-list précitée)
Edit : deux suppléments éventuels:
http://lists.osgeo.org/pipermail/gdal-d … 19729.html
http://go-mono.com/forums/#nabble-td1533739
ThomasG
PS : Juste des pistes, je ne suis pas un utilisateur C#
Dernière modification par ThomasG (Mon 20 September 2010 14:55)
#8 Tue 21 September 2010 13:51
rouault
Comme l'exception l'indique, il faut placer les .so/.dll générés lors de la compilation du binding C# de GDAL (quelque chose du genre [lib]gdal_wrap.dll/so, [lib]ogr_wrap.dll/so, [lib]gdalconst_wrap.dll/so, [lib]ogr_warp.dll), ainsi que le libgdal.so dans un chemin accessible par ton PATH et ça devrait rentrer dans l'ordre
#9 Tue 21 September 2010 14:44
cro
Notre logiciel est sous Windows, mais si j'arrive à le faire fonctionner sous Linux sans trop de modification ça serait vraiment une bonne chose. Merci pour les pistes.
