#1 Thu 14 October 2010 22:56
tiolebucheron
Lieu: Rouen
Modification d'écriture
Sous Openlayer ou autre, existe-t-il une fonction pour transformer
MULTIPOLYGON(((377214.302977711 2446886.56088011,377182.33865765 2446904.66253807,377156.675547636 2446918.63976763,377114.972993864 2446942.46979836,377138.803024591 2446986.69283615,377148.999528123 2447003.763387,377139.948699145 2447012.81421598,376982.074745581 2447141.70260333,376957.0990403 2447154.19045597,376901.992094244 2447006.62757339,376974.055023701 2446936.74142559,376978.752289374 2446890.11247123,376979.66882
EN
<gml:MultiPolygon srsName="EPSG:4326">
           <gml:polygonMember>
              <gml:Polygon>
              <gml:outerBoundaryIs>
                 <gml:LinearRing>
                    <gml:coordinates>1.313216,46.690770 1.000968,46.861087 0.887424,47.059790 1.142899,47.244300 1.355795,47.244300 1.554498,47.017211 1.710622,47.059790 1.767394,46.747542 1.313216,46.690770 1.313216,46.690770 </gml:coordinates>
                  </gml:LinearRing>
                </gml:outerBoundaryIs>
              </gml:Polygon>
            </gml:polygonMember>
            <gml:polygonMember>
              <gml:Polygon>
                 <gml:LinearRing>
et inversement !!
Pouvez-vous m'indiquez les spécifications de ces deux syntaxes??
Merci de votre aide Tio
#2 Fri 15 October 2010 09:38
Yves
Lieu: Aix-les-Bains
Re: Modification d'écriture
Tu peux regarder cette page d'exemple : http://dev.openlayers.org/releases/Open … rmats.html
Y.
#3 Fri 15 October 2010 11:10
tiolebucheron
Lieu: Rouen
Merci  Voici un example tout simple
    var out_options = {
                'internalProjection': map.baseLayer.projection,
                'externalProjection': map.baseLayer.projection
            var gmlOptions = {
                featureType: "feature",
                featureNS: "http://example.com/feature"
            var gmlOptionsOut = OpenLayers.Util.extend(
                OpenLayers.Util.extend({}, gmlOptions),
                out_options
            formats = {
                wkt: new OpenLayers.Format.WKT(out_options),
                gml2: new OpenLayers.Format.GML.v2(gmlOptionsOut)
console.log(formats);
feature=map.getLayersByName('outline')[0].features;
console.log(feature);
var str = formats['gml2'].write(feature,true);
console.log(str);
Il me reste qu'à faire le ménage pour récupérer la balise de la géometrie.
Merci Yves.
#4 Mon 18 October 2010 10:14
tiolebucheron
Lieu: Rouen
Je relance ce sujet pour deux problèmes :
1) Afin de récupérer uniquement le polygon j'ai fait ceci :
featureGML.substring(featureGML.indexOf('feature:geometry',0)+17,featureGML.indexOf('feature:geometry', featureGML.indexOf('feature:geometry',0)+1)-2);
Efficace mais pas orthodoxe. Je n'ai pas réussit à utiliser Openlayers.formats.XML
2) Ce cherche à récupérer le polygon avec des projection différentes (27582 et 2154)
map.getLayersByName('outline')[0].features[0].geometry.transform(new OpenLayers.Projection('EPSG:27572'),new OpenLayers.Projection('EPSG:27582'));
Ne fonctionne pas!! Je ne situe pas le problème.
#5 Mon 18 October 2010 10:59
Yves
Lieu: Aix-les-Bains
Concernant le point 2 :
là tu as ta géométrie en WKT :
Après il faut que tu te créés un objet Feature propre à OpenLayers que tu pourras reprojeter (le site d'openlayers est down je n'ai pas pu vérifier).
Je n'ai pas compris le point 1 wink
Y.
#6 Mon 18 October 2010 11:08
tiolebucheron
Lieu: Rouen
Re,
Ok pour le point 2.
pour le point 1 Dans le fomat GML, j'ai utilisé la chaîne de caractère pour récupérer la balise "feature:geometry". Il aurait été plus propre, je pense d'utiliser le XML!!! Non Qu'en penses-tu?
Tio.
#7 Wed 20 October 2010 09:59
tiolebucheron
Lieu: Rouen
Je rencontre toujours des problèmes. Quand je test les différentes étapes, cela fonctionne.
Quand je lance le script entièrement, j'ai l'erreur suivante : "geometry.clone().transform is not a function"
Je ne comprend pas l'erreur.
Merci de votre Aide
Tio
    var geom = new Array();
    var src = new Array(2154,27582);
    var out_options = {
    var gmlOptions = {
        out_options
    var formats = {
    for (i=0; i<map.getLayersByName('outline')[0].features.length; i++){
        geom[i]= new Array();
        geom[i]['wkt'] = map.getLayersByName('outline')[0].features[i].geometry;
        k=i;
        for(j=0; j<src.length; j++){
            var tmp = new OpenLayers.Feature.Vector(map.getLayersByName('outline')[0].features[k].geometry);
            tmp.geometry.transform(new OpenLayers.Projection(map.baseLayer.projection.projCode),new OpenLayers.Projection('EPSG:'+src[j]));
            var featureGML = formats['gml2'].write(new OpenLayers.Feature.Vector(tmp),true);
            geom[k]['gml'] = new Array();
            geom[k]['gml'][src[j]] = featureGML.substring(featureGML.indexOf('feature:geometry',0)+17,featureGML.indexOf('feature:geometry', featureGML.indexOf('feature:geometry',0)+1)-2);
#8 Fri 22 October 2010 13:16
tiolebucheron
Lieu: Rouen
Je viens de trouver l'erreur , il manquait une affectation à la variable
  tmp =         tmp.geometry.transform(new OpenLayers.Projection(map.baseLayer.projection.projCode),new OpenLayers.Projection('EPSG:'+src[j]));
Par contre, pouvez-vous m'expliquer ce résultat
console.log(map.getLayersByName('outline')[0].features[0].geometry);
var tmp = new OpenLayers.Feature.Vector(map.getLayersByName('outline')[0].features[0].geometry);
tmp = tmp.geometry.transform(new OpenLayers.Projection(map.baseLayer.projection.projCode),new OpenLayers.Projection('EPSG:2154'));
1=> 27572 POLYGON((452458.31904584 2520883.3001864,451752.76387129 2512769.415679,459161.09320412 2516649.969139,452458.31904584 2520883.3001864)) { id="OpenLayers.Geometry.Polygon_3014", more...}
2=> 2154 POLYGON((504638.10140192474 6955402.053690341,503865.8876504806 6947298.930498692,511301.8014213318 6951115.847015039,504638.10140192474 6955402.053690341)) {
Mon objet initial est map.getLayersByName('outline')[0].features[0].geometry.
Après transformation, via la variable tmp l'objet initial n'est pas identique.
Merci pour votre aide.
Tio
#9 Mon 25 October 2010 08:58
tiolebucheron
Lieu: Rouen
J'ai trouvé la solution.
Pour cela j'ai repasse le polygon initial en wkt avec openlayer format. Ensuite j'ai créé un nouveau polygon avec cette chaine.
Résolut
#10 Mon 25 October 2010 16:11
tiolebucheron
Lieu: Rouen
J'ai un problème que je comprend pas lors de la conversion de projection
Cela fonctionne très bien pour la 27582, mais pas pour la 2154. il me modifier la coordonnées des points.
27582
POLYGON((518071.44534596906 2531717.0935387663,517041.33479111857 2532108.676660671,517750.4177415489 2532154.537746969,518480.66734720924 2532076.926677767,518071.44534596906 2531717.0935387663,518071.44534596906 2531717.0935387663)) { id="OpenLayers.Geometry.Polygon_5919", more...}
<gml:featureMember xmlns:gml="http://www.opengis.net/gml" xsi:schemaLocation="http://www.opengis.net/gml http://schemas.opengis.net/gml/2.1.2/feature.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><feature:feature xmlns:feature="http://example.com/feature"><feature:geometry><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates decimal="." cs="," ts=" ">518071.44534596906,2531717.0935387663 517041.33479111857,2532108.676660671 517750.4177415489,2532154.537746969 518480.66734720924,2532076.926677767 518071.44534596906,2531717.0935387663</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></feature:geometry></feature:feature></gml:featureMember>
2154
POLYGON((570301.7796602645 6965685.096435715,569275.5397314288 6966085.018542743,569984.5830060684 6966124.952082867,570713.7528938007 6966041.310273165,570301.7796602645 6965685.096435715,570301.7796602645 6965685.096435715)) { id="OpenLayers.Geometry.Polygon_5894", more...}
<gml:featureMember xmlns:gml="http://www.opengis.net/gml" xsi:schemaLocation="http://www.opengis.net/gml http://schemas.opengis.net/gml/2.1.2/feature.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><feature:feature xmlns:feature="http://example.com/feature"><feature:geometry><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates decimal="." cs="," ts=" ">570301.7796602645,6965685.096435715,43.78045410942286 569275.5397314288,6966085.018542743,43.789065099321306 569984.5830060684,6966124.952082867,43.78273188881576 570713.7528938007,6966041.310273165,43.7763734459877 570301.7796602645,6965685.096435715,43.78045410942286</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></feature:geometry></feature:feature></gml:featureMember>
voici les quelques lignes de code
  tmp = new OpenLayers.Feature.Vector(GeomFromWKT(formats['wkt'].write(map.getLayersByName('outline')[0].features[k])),true);
            featureGML = formats['gml2'].write(new OpenLayers.Feature.Vector(tmp));
            geom[k] = geom[k]+'"' + src[j] + '":"' + featureGML.substring(featureGML.indexOf('feature:geometry',0)+17,featureGML.indexOf('feature:geometry', featureGML.indexOf('feature:geometry',0)+1)-2).replace(/"/g,"\\\"").replace(/\//g,"\\/") + '",';
Merci de votre aide. J'avance mais pas vite
Tio
#11 Thu 28 October 2010 11:24
tiolebucheron
Lieu: Rouen
J'ai avancé dans le diagnostic du problème
Je crée un Vector en 27572
tmp = new OpenLayers.Feature.Vector(GeomFromWKT('POLYGON((473624.97428247717 2503420.8096146192,468333.3104733147 2481195.821616069,495144.40710643225 2488604.150948889,473624.97428247717 2503420.8096146192))'),true);
Je le transforme en 2154
POLYGON((525647.2866382567 6937775.032845644,520174.83243102545 6915607.812195801,547030.399726584 6922789.120917389,525647.2866382567 6937775.032845644,525647.2866382567 6937775.032845644)) { id="OpenLayers.Geometry.Polygon_2925", more...}
Je fais la transcription en gml
"<gml:featureMember xmlns:gml="http://www.opengis.net/gml" xsi:schemaLocation="http://www.opengis.net/gml http://schemas.opengis.net/gml/2.1.2/feature.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><feature:feature xmlns:feature="http://example.com/feature"><feature:geometry><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates decimal="." cs="," ts=" ">525647.2866382567,6937775.032845644,44.21614613290876 520174.83243102545,6915607.812195801,44.29253465030342 547030.399726584,6922789.120917389,44.039753519929945 525647.2866382567,6937775.032845644,44.21614613290876</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></feature:geometry></feature:feature></gml:featureMember>"
C'est au niveau de la transcription en gml qu'il y a un problème
var out_options = {
var gmlOptions = {
out_options
var formats = {
Ce code fonctionne avec la transcription GML en 27582.
Merci de votre Aide Tio
