#1 Tue 01 February 2011 15:23
Morgan73000
Lieu: Chambéry
probleme Maperver avec des couches Postgis
Tout d'abord bonjour tout le monde,
J'utilise sur Windows XP, le logiciel QuantumGis Cociapo..
J'essaie de créer un mapfile avec une couche Postgis mais impossible de m'afficher ma carte
J'ai ceci en message d'erreur
msDrawMap(): Image handling error. Failed to draw layer named 'r_commune_bdc_073_region'. prepare_database(): Query error. Error declaring cursor: ERREUR: erreur de syntaxe sur ou près de « SELECT » LINE 1: ...SOR FOR SELECT asbinary(force_collection(force_2d(SELECT the... ^ With query string: DECLARE mycursor BINARY CURSOR FOR SELECT asbinary(force_collection(force_2d(SELECT the_geom)),'NDR'),gid::text from "r_commune_bdc_073_region" WHERE ( GeometryType("the_geom") IN ('POLYGON','MULTIPOLYGON') ) and (SELECT the_geom && setSRID( 'BOX3D(896362.562446 6421788.714574,1041206.514507 6566632.666635)'::BOX3D,4326) )
Mon mapfile est le suivant:
# Map file created from QGIS project file C:/Program Files/Quantum GIS Copiapo/commune_postgis.qgs
# Edit this file to customize for your map interface
# (Created with PyQgis MapServer Export plugin)
MAP
  NAME "QGIS-MAP"
  # Map image size
  SIZE 100 100
  UNITS meters
  EXTENT 896362.562446 6443617.049623 1041206.514507 6544804.331586
  PROJECTION
    'proj=longlat'
    'ellps=WGS84'
    'datum=WGS84'
    'no_defs'
  END
  # Background color for the map canvas -- change as desired
  IMAGECOLOR 255 255 255
  IMAGEQUALITY 95
  IMAGETYPE gif
  OUTPUTFORMAT
    NAME gif
    DRIVER 'GD/GIF'
    MIMETYPE 'image/gif'
    EXTENSION 'gif'
  END
  # Legend
  LEGEND
    STATUS ON
    KEYSIZE 18 12
    LABEL
      TYPE BITMAP
      SIZE MEDIUM
      COLOR 0 0 89
    END
  END
  # Web interface definition. Only the template parameter
  # is required to display a map. See MapServer documentation
  WEB
    # Set IMAGEPATH to the path where MapServer should
    # write its output.
    IMAGEPATH '/tmp/'
    # Set IMAGEURL to the url that points to IMAGEPATH
    # as defined in your web server configuration
    IMAGEURL '/tmp/'
    # WMS server settings
    METADATA
      'ows_title'           'QGIS-MAP'
      'ows_onlineresource'  'http://127.0.0.1/cgi-bin/mapserv.exe?map=C:/Program Files/Quantum GIS Copiapo/communes_postgis.map'
      'ows_srs'             'EPSG:4326'
    END
    #Scale range at which web interface will operate
    # Template and header/footer settings
    # Only the template parameter is required to display a map. See MapServer documentation
    TEMPLATE 'fooOnlyForWMSGetFeatureInfo'
  END
  LAYER
    NAME 'r_commune_bdc_073_region'
    TYPE POLYGON
    DUMP true
    TEMPLATE fooOnlyForWMSGetFeatureInfo
    CONNECTIONTYPE postgis
    CONNECTION "dbname='postgis' user='postgres' password='denombre' sslmode=disable"
    DATA 'the_geom FROM "r_commune_bdc_073_region" USING UNIQUE gid USING srid=4326'
    FILTER ( GeometryType("the_geom") IN ('POLYGON','MULTIPOLYGON') )
    METADATA
      'ows_title' 'r_commune_bdc_073_region'
    END
    STATUS OFF
    TRANSPARENCY 100
    PROJECTION
    'proj=longlat'
    'ellps=WGS84'
    'datum=WGS84'
    'no_defs'
    END
    CLASS
       STYLE
         WIDTH 1.61
         OUTLINECOLOR 255 0 255
       END
    END
  END
END
Merci d'avance et désolé si je ne suis pas dans la bonne partie du forum
Dernière modification par Morgan73000 (Tue 01 February 2011 15:33)
#2 Tue 01 February 2011 15:47
Yves
Lieu: Aix-les-Bains
Re: probleme Maperver avec des couches Postgis
1. tu postes dans la bonne partie du forum et bienvenu smile
2. la réponse est dans le message d'erreur, regarde la requête :
Tu as un SELECT the_geom qui devrait être juste the_geom.
Par contre ton mapfile semble correcte.
Y.
#3 Tue 01 February 2011 15:57
Morgan73000
Lieu: Chambéry
Merci Yves,
Cependant ou est ce que je trouve ce SELECT car il n'est pas dans le mapfile.
#4 Tue 01 February 2011 16:23
Morgan73000
Lieu: Chambéry
C'est bon j'ai trouvé le souci au niveau de la requete.
j'ai un leger ennui a present, mon mapserver m'affiche:
"msSaveImageGD(): Unable to access file. Unable to open file /tmp/QGIS-MAP12965731734080.gif for writing"
Il n'y en a en fait aucune carte de present dans le dossier tmp et malgré une exploration du pc, la carte n'existe meme pas.
        Morgan.
#5 Tue 01 February 2011 17:39
Yves
Lieu: Aix-les-Bains
Typiquement un problème de droit sur le répertoire. Est ce que tu peux définir un répertoire dans /var/www/ ? Je pense que c'est ce qu'il faut faire. Tu as deux paramètres :
    IMAGEPATH '/tmp/'
    IMAGEURL '/tmp/'
IMAGEPATH est le chemin vers le répertoire où se trouve les images. IMAGEURL est l'url (http://localhost/tmp/) où tu peux accéder aux images.
je te laisse corriger en ce sens wink
Y.
PS : le serveur doit avoir accès en écriture dans le répertoire IMAGEPATH => chmod -R 777 /var/www/tmp/ (un peu bourrin, il faut être plus précis en tant normal)
#6 Wed 02 February 2011 09:36
Morgan73000
Lieu: Chambéry
Effectivement il y avait un probleme de droit sur les chemins d'acces
j'ai a présent:
"Content-type: text/html msReturnPage(): Web application error. Malformed template name (fooOnlyForWMSGetFeatureInfo)"
En tout cas merci Yves pour ton aide
        Morgan.
Dernière modification par Morgan73000 (Wed 02 February 2011 09:43)
#7 Thu 03 February 2011 14:47
Morgan73000
Lieu: Chambéry
J'ai trouvé la solution a mon probleme
Merci en tout cas
        Morgan.
#8 Thu 03 February 2011 14:59
Yves
Lieu: Aix-les-Bains
Bonjour Morgan,
N'hésite pas à partager la solution wink
Y.
#9 Thu 03 February 2011 16:02
Morgan73000
Lieu: Chambéry
En fait il y avait un souci au niveau des METADATA que j'ai supprimé tout simplement et tout a l'air de fonctionner parfaitement
J'ai eu un autre souci d'affichage mais qui était du au droit d'utilisateur de mon mapserver et qui ne générait pas de cartes temporaires mais tout va bien
Je m'attelle maintenant aux couches WMS dans l'API GéoPortail.
        Morgan.
#10 Mon 07 March 2011 16:42
jack tippit
Lieu: Limoges
Bonjour Morgan,
J'ai le même problème que celui que tu as eu (a la fin le message
Content-type: text/html msReturnPage(): Web application error. Malformed template name (fooOnlyForWMSGetFeatureInfo).
Est ce que tu es sur que le simple fait de supprimer metadata règle le problème? est ce que tu n'as pas tripatouiller autre chose? Parce que sur ton conseil j'ai virer sans ménagement, mais rien ne change...
pas de chance moi qui suis déjà presque chauve :-)
merci
Etienne
#11 Wed 16 March 2011 00:57
joe69
D'abord ca sort d'ou ce fooOnlyForWMSGetFeatureInfo ????
#12 Wed 16 March 2011 09:09
Yves
Lieu: Aix-les-Bains
Ca vient de l'export Mapfile de QGIS. Pour des services WMS il faut remplir un champ pour activer le GetFeatureInfo mais la valeur du paramètre n'a aucune importance. Généralement on met foo (avec son copain bar) comme exemple de valeur fictive.
Y.
#13 Wed 16 March 2011 09:29
joe69
Et si je n'ai pas QGIS sur mon poste, ça ne marche donc pas ?
