#1 Wed 09 February 2011 13:52
zorgglub
Openlayer pour afficher un mapfile
Je suis débutant sur Openlayer.
Avec Mapserver le mapfile s'affiche.
MAP
    IMAGETYPE    PNG
    EXTENT        534939.812465 46660.126962 690104.815208 171430.130363
    SIZE        800 800
    SHAPEPATH    "/ms4w/apps/test"
    IMAGECOLOR    255 255 255
WEB
    IMAGEPATH "http://10.8.*.*/ms4w/tmp/ms_tmp/"
     IMAGEURL "http://10.8.*.*/ms_tmp/"
    METADATA
        "wfs_title"            "layer"
        "wfs_onlineresource"   "http://10.8.*.*/cgi-bin/mapserv?map=/ms4w/apps/test/map2.map&layer=communek1lamb1&layer=oa_sra_surf&mode=map"  ## Recommended
        "wfs_srs"               "epsg:27561"
END
END
SCALEBAR
    INTERVALS 2
    UNITS meters
    OUTLINECOLOR 0 0 0
    STYLE 0
    STATUS embed
          LABEL
               SIZE small
                COLOR 0 0 0
          END
END
    LAYER
        NAME    communek1lamb1
        DATA    communek1lamb1
        STATUS    ON
        TYPE    POLYGON
        CLASS
            STYLE
                COLOR        200 200 200
                OUTLINECOLOR    0 0 0
            END
        END
        METADATA
        ### WFS
        "wfs_title"            "communek1lamb1"
        "gml_featureid"     "NAME"
        "gml_include_items" "all"
        END
        DUMP TRUE
    END
    LAYER
        NAME    oa_sra_surf
        DATA    oa_sra_surf
        STATUS    ON
        TYPE    POLYGON
        CLASS
            STYLE
                COLOR        125 0 0
                OUTLINECOLOR    30 30 10
            END
        END
        METADATA
        ### WFS
        "wfs_title"            "ope"
        END
        DUMP TRUE
    END
    PROJECTION
        "init=epsg:27561"
    END
    OUTPUTFORMAT
        NAME png
        DRIVER "GD/PNG"
        MIMETYPE "image/png"
        IMAGEMODE PC256
        EXTENSION "png"
        TRANSPARENT ON
    END
END
mais quand j'essaye un affichage openlayer, rien ne s'affiche, juste le zoom
voilà le code
<html xmlns="http://www.w3.org/1999/xhtml">
  <head>
    <title>MapServer Layer</title>
    <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
    <link rel="stylesheet" href="style.css" type="text/css" />
  <script src="http://10.8.*.*/openlayers/OpenLayers.js"></script>
  <script type="text/javascript">
var map;
function init() {
     var options =
projection: new OpenLayers.Projection("epsg:27561"),
displayProjection:new OpenLayers.Projection("epsg:27561"),
            map = new OpenLayers.Map('map',options);
var layer = new OpenLayers.Layer.WFS( "layer","http://10.8.1.*.*/cgi-bin/mapserv.exe?map=/ms4w/apps/test/map2.map&"
, {layers: "communek1lamb1", format: 'image/jpeg' }, {buffer: 1, isBaseLayer: true} );
    map.addLayers([layer]);
            map.addControl(new OpenLayers.Control.Scale('scale'));
            map.addControl(new OpenLayers.Control.MousePosition());
     </script>
</head>
<body onLoad="init()">
    <div id="name"></div><br />
    <div id="map" style="width:900px;height:650px"></div>
</body>
</html>
voilà le résultat
je pense que cela vient des projections mais je ne trouve pas d'ou cela vient !!
mon fichier shape est en lambert I Nord
merci pour votre aide
zorgglub
Dernière modification par zorgglub (Wed 09 February 2011 14:00)
#2 Wed 09 February 2011 14:08
Yves
Lieu: Aix-les-Bains
Re: Openlayer pour afficher un mapfile
Peux tu installer Firebug si ce n'est pas déjà fait et vérifier que la requête WFS envoyée par OpenLayers est correct.
Et un lien vers le wiki de GeoRezo pour expliquer en image comment utiliser Firebug : http://georezo.net/wiki/main/logiciels/ … rs/firebug
Y.
#3 Wed 09 February 2011 14:37
zorgglub
bonjour
apparement j'ai
ServiceExceptionReport version="1.2.0" xsi:schemaLocation="http://www.opengis.net/ogc http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd">
<ServiceException code="MissingParameterValue" locator="typename">
msWFSGetFeature(): WFS server error. Incomplete WFS request: TYPENAME parameter missing
</ServiceException>
</ServiceExceptionReport>
j'ai essayer de rajouter
{TYPENAME: "communek1lamb1",layers: "communek1lamb1", format: 'image/jpeg' }, {buffer: 1, isBaseLayer: true} );
mais cela ne marche pas
merci
zorgglub
#4 Wed 09 February 2011 15:01
Yves
Lieu: Aix-les-Bains
Dans le cas d'un WFS il n'y a pas de paramètre layers mais typename. De même le format jpeg pour une couche vecteur wink
continuer à corriger votre code et à regarder les appels WFS réaliser par OL. Il y a probablement d'autres problèmes.
Y.
#5 Wed 09 February 2011 15:54
zorgglub
Merci Yves,
c'est parfait
en effet, jpeg pour une couche vecteur et le typename smile
zorgglub
