#1 Sun 13 March 2011 10:59
- MED86
osm2pgsql
j'ai essayé d'importer des données osm sur la base de données PostgresSQL (postgis), mais sa n'a pas marché. Je travail sous le windows et j'utilise PostgresSQL v 8.2.
Voici le code que j'ai saisi
osm2pgsql -c --style "C:\Program Files\osm2pgsql\default.style" -d testgis -U postgres -W -H localhost -P 5432 "C:\Documents and Settings\Administrateur\Bureau\map(2).osm"
mais j'ai cette erreur :
Warning: program compiled against libxml 207 using older 206 Using projection SRS 900913 (Spherical Mercator) Setting up table: planet_osm_point NOTICE: table "planet_osm_point" does not exist, skipping NOTICE: table "planet_osm_point_tmp" does not exist, skipping Setting up table: planet_osm_line NOTICE: table "planet_osm_line" does not exist, skipping NOTICE: table "planet_osm_line_tmp" does not exist, skipping Setting up table: planet_osm_polygon NOTICE: table "planet_osm_polygon" does not exist, skipping NOTICE: table "planet_osm_polygon_tmp" does not exist, skipping Setting up table: planet_osm_roads NOTICE: table "planet_osm_roads" does not exist, skipping NOTICE: table "planet_osm_roads_tmp" does not exist, skipping Mid: Ram, scale=100 !! You are running this on 32bit system, so at most !! 3GB of RAM can be used. If you encounter unexpected !! exceptions during import, you should try running in slim !! mode using parameter -s. Reading in file: C:\Documenst and Settings\Administrateur\Bureau\map(2).osm error while opening file C:\Documents and Settings\Administrateur\Bureau\map(2).osm
Merci de bien vouloir m'aide.
Dernière modification par MED86 (Sun 13 March 2011 11:18)
