#1 Thu 03 November 2011 00:31
- alemrabot
Projection UTM
j'ai des shapefile qui ont la projection UTM 28 nord , j"ai essayé de les mettre sur la ma carte main j'ai pas pu.
après une vérification j"ai constaté dans le MetaData il y a une difference en locale cordinates
pour le premeir j'ai In projected or local coordinates
Left: -12.000000
Right: -6.000000
Top: 27.300000
Bottom: 14.000000
pour le deuxième
Left: -12.000000
Right: -6.000000
Top: 27.300000
Bottom: 14.000000
comment je peux mettre le premier en mètre
merci
Dernière modification par alemrabot (Thu 03 November 2011 00:31)
#2 Thu 03 November 2011 10:35
- alemrabot
Re: Projection UTM
voici les details du metadata>>spatial
Horizontal coordinate system Projected coordinate system name: WGS_1984_UTM_Zone_28N Geographic coordinate system name: GCS_WGS_1984 Details Grid Coordinate System Name: Universal Transverse Mercator UTM Zone Number: 28 Transverse Mercator Projection Scale Factor at Central Meridian: 0.999600 Longitude of Central Meridian: -15.000000 Latitude of Projection Origin: 0.000000 False Easting: 500000.000000 False Northing: 0.000000 Planar Coordinate Information Planar Distance Units: meters Coordinate Encoding Method: coordinate pair Coordinate Representation Abscissa Resolution: 0.000000 Ordinate Resolution: 0.000000 Geodetic Model Horizontal Datum Name: D_WGS_1984 Ellipsoid Name: WGS_1984 Semi-major Axis: 6378137.000000 Denominator of Flattening Ratio: 298.257224 _________________ Bounding coordinates Horizontal In decimal degrees West: -19.488898 East: -19.488851 North: 0.000212 South: 0.000126 In projected or local coordinates Left: -17.150000 Right: -12.000000 Top: 23.500000 Bottom: 14.000000 _________________ Spatial data description Vector data information ESRI description FUS28_region ESRI feature type: Simple Geometry type: Polygon Topology: FALSE Feature count: 28 Spatial Index: FALSE Linear referencing: FALSE SDTS description Feature class: SDTS feature type, feature count FUS28_region: G-polygon, 28 Details for FUS28_region Type of object: Feature Class Number of records: 28 Attributes FID Alias: FID Data type: OID Width: 4 Precision: 0 Scale: 0 Definition: Internal feature number. Definition Source: ESRI Shape Alias: Shape Data type: Geometry Width: 0 Precision: 0 Scale: 0 Definition: Feature geometry. Definition Source: ESRI NUMCOUPURE Alias: NUMCOUPURE Data type: Number Width: 10 NOMCOUPURE Alias: NOMCOUPURE Data type: String Width: 50 NRéFéRENCE Alias: NRéFéRENCE Data type: Number Width: 20 NUMFEUILLE Alias: NUMFEUILLE Data type: String Width: 31 UTM_ZONE Alias: UTM_ZONE Data type: Number Width: 5 AREA Alias: AREA Data type: Number Width: 20 Number of decimals: 3 PERIMETER Alias: PERIMETER Data type: Number Width: 20 Number of decimals: 3 X_COORD Alias: X_COORD Data type: Number Width: 31 Number of decimals: 15 Y_COORD Alias: Y_COORD Data type: Number Width: 31 Number of decimals: 15 X_COORD0 Alias: X_COORD0 Data type: Number Width: 31 Number of decimals: 15 Y_COORD0 Alias: Y_COORD0 Data type: Number Width: 31 Number of decimals: 15 X_COORD1 Alias: X_COORD1 Data type: Number Width: 31 Number of decimals: 15 Y_COORD1 Alias: Y_COORD1 Data type: Number Width: 31 Number of decimals: 15 X_COORD2 Alias: X_COORD2 Data type: Number Width: 31 Number of decimals: 15 Y_COORD2 Alias: Y_COORD2 Data type: Number Width: 31 Number of decimals: 15 CHAMP1 Alias: CHAMP1 Data type: Boolean Width: 1
#3 Thu 03 November 2011 15:32
- Christophe Révillion
- Lieu: Saint Pierre (Réunion)
Re: Projection UTM
Logiquement, comme ta couche est projetée, tu peux avoir les distances selon l'unité que tu désires (et donc en mètre).
Ce que je ne comprend pas bien c'est pourquoi tu n'arrives pas à afficher tes couches (quel est le message d'erreur?).
Donne-nous de plus d'infos.
#4 Thu 03 November 2011 16:23
- alemrabot
Re: Projection UTM
Il m'affiche pas un message d'errure.
mais je vois pas les deuxcouches sur la memeplace alors qu'ils doivent se superposer.
voici les meta data de chaque couche , vous pouvez constatez la difference
couche 2
Horizontal coordinate system Projected coordinate system name: WGS_1984_UTM_Zone_28N Geographic coordinate system name: GCS_WGS_1984 Details Grid Coordinate System Name: Universal Transverse Mercator UTM Zone Number: 28 Transverse Mercator Projection Scale Factor at Central Meridian: 0.999600 Longitude of Central Meridian: -15.000000 Latitude of Projection Origin: 0.000000 False Easting: 500000.000000 False Northing: 0.000000 Planar Coordinate Information Planar Distance Units: meters Coordinate Encoding Method: coordinate pair Coordinate Representation Abscissa Resolution: 0.000000 Ordinate Resolution: 0.000000 Geodetic Model Horizontal Datum Name: D_WGS_1984 Ellipsoid Name: WGS_1984 Semi-major Axis: 6378137.000000 Denominator of Flattening Ratio: 298.257224 _________________ Bounding coordinates Horizontal In decimal degrees West: -17.509460 East: -16.315473 North: 18.490791 South: 17.033969 In projected or local coordinates Left: 235000.000002 Right: 360000.000002 Top: 2045000.000002 Bottom: 1885000.000002 _________________ Spatial data description Vector data information ESRI description Zone3_UTM28N_Tullow_Final_Polygon ESRI feature type: Simple Geometry type: Polygon Topology: FALSE Feature count: 1 Spatial Index: FALSE Linear referencing: FALSE SDTS description Feature class: SDTS feature type, feature count Zone3_UTM28N_Tullow_Final_Polygon: G-polygon, 1 Details for Zone3_UTM28N_Tullow_Final_Polygon Type of object: Feature Class Number of records: 1 Attributes FID Alias: FID Data type: OID Width: 4 Precision: 0 Scale: 0 Definition: Internal feature number. Definition Source: ESRI Shape Alias: Shape Data type: Geometry Width: 0 Precision: 0 Scale: 0 Definition: Feature geometry. Definition Source: ESRI Id Alias: Id Data type: Number Width: 16 Number of decimals: 6 ET_ID Alias: ET_ID Data type: String Width: 100
#5 Thu 03 November 2011 16:38
Re: Projection UTM
Il semble effectivement que la première couche n'est en fait pas projetée. Il faudrait donc le faire grâce à l'outil "projeter" de la toolbox.
Est-ce que cela corrige ton problème?
#6 Fri 04 November 2011 13:01
- alemrabot
Re: Projection UTM
j'ai changé la projection en utilisant ToolBox , mais c'est toujours la même chose.
#7 Tue 08 November 2011 00:36
- alemrabot
Re: Projection UTM
Personne n' a une solution
#8 Fri 11 November 2011 18:01
- mame1985
- Lieu: Montréal
Re: Projection UTM
mes recherches m'indiquent que ta zone d'etude se situe au senegal, pas vrai?
Il faut d'abord que tu lui definisses une projection sous arc catalog et ensuite tu le projectes
ça devrait marcher normalement.
merci
Mame
