#1 Thu 15 December 2011 17:30
Adelweissb
Caler une image GIF avec un fichier MAP
j'ai actuellement un petit souci de "calage".
J'ai des fichiers MapInfo Table File avec des images GIF correspondantes mais je n'arrive pas à les ouvrir déjà géoréférencées. MapInfo me demande de les caler manuellement.
Quand j'ouvre mon fichier MapInfo Table File, j'obtiens :
"OziExplorer Map Data File Version 2.2
1 ,Map Code,
Pulkovo 1942 (2),WGS 84,   0.0000,   0.0000,WGS 84
Reserved 1
Reserved 2
Magnetic Variation,,,E
Map Projection,Transverse Mercator,PolyCal,No,AutoCalOnly,No,BSBUseWPX,No
Point01,xy,  103,  104,in, deg,  44,  0.0000,N,  22, 45.0000,E, grid,   ,           ,           ,N
Point02,xy, 1596,   98,ex, deg,  44,  0.0000,N,  22, 52.5000,E, grid,   ,           ,           ,N
Point03,xy, 3195,  101,in, deg,  44,  0.0000,N,  23,  0.0000,E, grid,   ,           ,           ,N
Point04,xy,  103, 1539,in, deg,  43, 55.0000,N,  22, 45.0000,E, grid,   ,           ,           ,N
Point05,xy, 1648, 1542,in, deg,  43, 55.0000,N,  22, 52.5000,E, grid,   ,           ,           ,N
Point06,xy, 3199, 1537,in, deg,  43, 55.0000,N,  23,  0.0000,E, grid,   ,           ,           ,N
Point07,xy,   99, 2974,in, deg,  43, 50.0000,N,  22, 45.0000,E, grid,   ,           ,           ,N
Point08,xy, 1596, 2970,ex, deg,  43, 50.0000,N,  22, 52.5000,E, grid,   ,           ,           ,N
Point09,xy, 3201, 2973,in, deg,  43, 50.0000,N,  23,  0.0000,E, grid,   ,           ,           ,N
Point10,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point11,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point12,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point13,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point14,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point15,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point16,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point17,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point18,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point19,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point20,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point21,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point22,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point23,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point24,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point25,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point26,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point27,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point28,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point29,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point30,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Projection Setup,     0.000000000,    21.000000000,     1.000000000,       500000.00,            0.00,,,,,
Map Feature = MF ; Map Comment = MC     These follow if they exist
Track File = TF      These follow if they exist
Moving Map Parameters = MM?    These follow if they exist
MM0,Yes
MMPNUM,4
MMPXY,1,105,98
MMPXY,2,3191,98
MMPXY,3,3191,2970
MMPXY,4,105,2970
MMPLL,1,  22.750158,  44.000346
MMPLL,2,  22.999647,  44.000224
MMPLL,3,  22.999218,  43.833506
MMPLL,4,  22.750426,  43.833615
MM1B,6.481999
MOP,Map Open Position,0,0
IWH,Map Image Width/Height,3296,3068"
Je vois bien que l'image est déjà calée normalement!
Quelqu'un a-t'il une idée?
#2 Thu 15 December 2011 18:21
Adelweissb
Re: Caler une image GIF avec un fichier MAP
Je poste à nouveau pour classer ma première demande.
Avec le petit logiciel de UT4RT, on peut finalement tout faire. C'est juste que je ne mettais pas les bonnes données!!
Bonne soirée!
#3 Mon 19 December 2011 18:22
HANCZYK JM
Lieu: Châlons en Champagne
1 ,Map Code,
Reserved 1 ...
C'est du MapInfo ça ? Jamais vu
Jm Hanczyk
