#1 Mon 16 January 2012 15:36
darksquall
[mapserver] WFS server error. TYPENAME
Je n'arrive pas à recuperer les données wfs. Un getCapabilities me renvoie un featuretypelist vide et getfeature me renvoie l'erreur
msWFSGetFeature(): WFS server error. TYPENAME 'valenciennes' doesn't exist in this server. Please check the capabilities and reformulate your request.
Mon mapfile est:
MAP
  EXTENT 680404.715625186 293713.61 686466.96 299382.49
  IMAGECOLOR 255 255 255
  IMAGETYPE jpeg
  SIZE -1 -1
  STATUS ON
  UNITS METERS
  NAME "valenciennes map"
  OUTPUTFORMAT
    NAME "jpeg"
    MIMETYPE "image/jpeg"
    DRIVER "GD/jpeg"
    EXTENSION "jpeg"
    IMAGEMODE "RGBA"
    TRANSPARENT FALSE
  END
  SYMBOL
    NAME "symbolbati"
    TYPE VECTOR
    POINTS
      0 1
      1 0
    END
  END
  PROJECTION
    "init=epsg:4326"
  END
  LEGEND
    KEYSIZE 20 10
    KEYSPACING 5 5
    LABEL
      SIZE MEDIUM
      TYPE BITMAP
      BUFFER 0
      COLOR 0 0 0
      FORCE FALSE
      MINDISTANCE -1
      MINFEATURESIZE -1
      OFFSET 0 0
      PARTIALS TRUE
    END
    POSITION LL
    STATUS OFF
  END
  QUERYMAP
    COLOR 255 255 0
    SIZE -1 -1
    STATUS OFF
    STYLE HILITE
  END
  SCALEBAR
    ALIGN CENTER
    COLOR 0 0 0
    INTERVALS 4
    LABEL
      SIZE MEDIUM
      TYPE BITMAP
      BUFFER 0
      COLOR 0 0 0
      FORCE FALSE
      MINDISTANCE -1
      MINFEATURESIZE -1
      OFFSET 0 0
      PARTIALS TRUE
    END
    POSITION LL
    SIZE 200 3
    STATUS OFF
    STYLE 0
    UNITS MILES
  END
  WEB
    IMAGEPATH "/var/www/webserver/tmpWFS/1/"
    IMAGEURL "/webserver/tmpWFS/1/"
    METADATA
      "wfs_title"    "mmap"
      "wfs_onlineresource"    "http://SITE/cgi-bin/mapserv?map=/var/www/webserver/tmpWFS/1/carto2.map&?"
      "wfs_enable_request"    "*"
      "wfs_abstract"       "This text describes my WFS service." ## Recommended
      "wfs_srs"    "EPSG:4326"
    END
    QUERYFORMAT text/html
    LEGENDFORMAT text/html
    BROWSEFORMAT text/html
  END
  LAYER
    NAME "vafp"
    METADATA
        "wfs_title"    "valenciennes"
        "gml_include_items" "all"
        "gml_featureid"    "ID"
    END
    PROJECTION
      "init=epsg:27591"
    END
    STATUS ON
    TYPE LINE
    CONNECTION "user=USER password=PASSWORD dbname=DB host=localhost"
    CONNECTIONTYPE POSTGIS
    DATA "the_geom from affaire1fp "
    UNITS METERS
    CLASS
        NAME 'valenciennes'
      STYLE
        ANGLE 360
        BACKGROUNDCOLOR 255 0 0
        COLOR 0 0 0
        SIZE 1
        SYMBOL 0
        WIDTH 1
      END
    END
  END
END
Merci!
Dernière modification par darksquall (Mon 16 January 2012 15:38)
#2 Mon 16 January 2012 17:43
darksquall
Re: [mapserver] WFS server error. TYPENAME
J'ai trouvé mon erreur, il manquait dump true. Mais maintenant je n'arrive pas à faire interfacer openlayer et mapserver en wfs... J'ai bien parmetre mon proxy. Et avec firebug je recois bien le xml correspondant. Mais rien ne s'affiche.
Dernière modification par darksquall (Mon 16 January 2012 23:40)
#3 Tue 17 January 2012 14:32
Daemons
Lieu: Nice
Peut-on voir ton code JavaScript de ta carte ?
Si ton client reçoit bien les données WFS, ce ne serait pas un problème d'affichage avec un stylemap, ou autre ? Firebug ne renvoie aucune erreur ?...
Par contre, je ne comprends pas vraiment ton code : si c'est un WFS, tu n'as pas besoin de définir de outputformat, ceci est réservé aux services WMS qui renvoient de l'image. Ici, tu veux renvoyer du vecteur ?
#4 Tue 17 January 2012 15:47
darksquall
Voila mon code j'ai fais quelque modification apparement le probleme se trouve au niveau du proxy:
OpenLayers.ProxyHost ="/cgi-bin/proxy.cgi?url=";
that.map = new OpenLayers.Map({
                projection: new OpenLayers.Projection("EPSG:4326"),
                div: divMap,
                allOverlays: true
var cadastre = new OpenLayers.Layer.Vector("vector", {
             styleMap:styleParcelles,
            strategies: [new OpenLayers.Strategy.BBOX(),saveStrategyParcelle],
            protocol: new OpenLayers.Protocol.WFS({
                url:  "http://localhost:8080/cgi-bin/mapserv?map=/var/www/webserver/tmpWFS/1/carto2.map",
                version: "1.0.0",
                featureType: "vafp",
                featureNS: "http://localhost:8080/",
                srsName: "EPSG:4326",
                geometryName: "the_geom",
                schema:  "http://localhost:8080/cgi-bin/mapserv?map=/var/www/webserver/tmpWFS/1/carto2.map&service=wfs&request=DescribeFeatureType&version=1.0.0&typename=vafp",
                extractAttributes: true
Au debut j'avais mis l'url distant dans le protocol.WFS je pense qu'il faut mettre localhost car openlayer utilise le proxy non?
Mais maintenant j'ai une erreur:
This proxy does not allow you to access that location
Cela fais 2 jours complet que je suis dessus... Désesperant.
#5 Tue 17 January 2012 17:22
Daemons
Lieu: Nice
Je ne pense pas que l'URL distant ou local change grand chose... si tu ne l'utilises qu'en local pour l'instant. Après, il faudra mettre l'URL distante, vu que la requête partira d'un PC différent du tien, donc la requête devra se faire sur ton serveur perso.
Aussi, l'URL que tu appelles dans OpenLayers en paramètre du WFS et le paramètre "wfs_onlineresource" de ton Mapfile doivent être les mêmes. Le GetCapabilities de ton WFS marche bien ?
Teste :
http://localhost:8080/cgi-bin/mapserv?map=/var/www/webserver/tmpWFS/1/carto2.map?service=WFS&version=1.0.0&request=GetCapabilites
Là comme ca, je ne vois pas l'erreur, mais si tu essaie un Protocol.HTTP plutôt qu'un Protocol.WFS, est-ce que ca change quelque chose dans le comportement de ton appli ?
        styleMap: styleParcelles,
        protocol: new OpenLayers.Protocol.HTTP({
            url: "http://localhost:8080/cgi-bin/mapserv?map=/var/www/webserver/tmpWFS/1/carto2.map?",
            params: {
                typename: "vafp",
                service: "WFS",
                version: "1.0.0"
                request: "GetFeature",
                srs: "EPSG:4326",
                format: "WFS"
    }, {extractAttributes:true}
Dernière modification par Daemons (Tue 17 January 2012 17:23)
#6 Tue 17 January 2012 17:33
darksquall
getCapabilities renvoie:
<WFS_Capabilities xmlns="http://www.opengis.net/wfs" xmlns:ogc="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.0.0" updateSequence="0" xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.0.0/WFS-capabilities.xsd">
MapServer version 5.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
<Service>
<Name>MapServer WFS</Name>
<Title>mmap</Title>
<Abstract>This text describes my WFS service.</Abstract>
<OnlineResource>
http://amiciti.fr:8080/cgi-bin/mapserv?map=/var/www/webserver/tmpWFS/1/carto2.map&
</OnlineResource>
</Service>
<Capability>
<Request>
<GetCapabilities>
<DCPType>
<HTTP>
<Get onlineResource="http://x:8080/cgi-bin/mapserv?map=/var/www/webserver/tmpWFS/1/carto2.map&"/>
</HTTP>
</DCPType>
<DCPType>
<HTTP>
<Post onlineResource="http://x:8080/cgi-bin/mapserv?map=/var/www/webserver/tmpWFS/1/carto2.map&"/>
</HTTP>
</DCPType>
</GetCapabilities>
<DescribeFeatureType>
<SchemaDescriptionLanguage>
<XMLSCHEMA/>
</SchemaDescriptionLanguage>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
</DescribeFeatureType>
<GetFeature>
<ResultFormat>
<GML2/>
</ResultFormat>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
</GetFeature>
</Request>
</Capability>
<FeatureTypeList>
<Operations>
<Query/>
</Operations>
<FeatureType>
<Name>vafp</Name>
<Title>valenciennes</Title>
<SRS>EPSG:4326</SRS>
<LatLongBoundingBox minx="-179.829" miny="-67.866" maxx="179.763" maxy="-36.074"/>
</FeatureType>
</FeatureTypeList>
<ogc:Filter_Capabilities>
<ogc:Spatial_Capabilities>
<ogc:Spatial_Operators>
<ogc:Equals/>
<ogc:Disjoint/>
<ogc:Touches/>
<ogc:Within/>
<ogc:Overlaps/>
<ogc:Crosses/>
<ogc:Intersect/>
<ogc:Contains/>
<ogc:DWithin/>
<ogc:BBOX/>
</ogc:Spatial_Operators>
</ogc:Spatial_Capabilities>
<ogc:Scalar_Capabilities>
<ogc:Logical_Operators/>
<ogc:Comparison_Operators>
<ogc:Simple_Comparisons/>
<ogc:Like/>
<ogc:Between/>
</ogc:Comparison_Operators>
</ogc:Scalar_Capabilities>
</ogc:Filter_Capabilities>
</WFS_Capabilities>
Laltn
#7 Thu 19 January 2012 11:45
Daemons
Lieu: Nice
On dirait que la config de ton MapFile est bonne, il reconnait bien ton layer... Si tu as toujours le même message d'erreur de Firebug, le problème doit venir de la configuration du proxy, il faut voir quelles connexions il autorise ? Là par contre, je ne sais pas trop comment ca marche pour ca...
