#1 Tue 29 May 2012 14:32
rboussant
srsName est null
J'ai plusieurs couches avec différentes projections (une couche de base en EPSG:900913 et des couches dessin en EPSG:27593) et j'ai l'erreur suivante lorsque j'essaye d'enregistrer une nouvelle feature :
Error performing insert: Source was null in trying to create a reprojected feature collection!
Le code XML de la transaction est le suivant :
<wfs:Transaction xmlns:wfs="http://www.opengis.net/wfs" service="WFS" version="1.1.0" xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<wfs:Insert><feature:sig__elements_poly xmlns:feature="geodp"><feature:the_geom>
<gml:Polygon xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:900913"><gml:exterior><gml:LinearRing>
<gml:posList>-41768.058637764 5357800.9464467 -41966.317179851 5357774.6712182 -41906.600751512 5357323.21502 -41710.730866559 5357349.4902485 -41768.058637764 5357800.9464467</gml:posList>
</gml:LinearRing></gml:exterior></gml:Polygon></feature:the_geom>
<feature:id_univers>1</feature:id_univers><feature:id_typologie>1</feature:id_typologie>
<feature:dos_infos>opp</feature:dos_infos><feature:id_element>1</feature:id_element></feature:sig__elements_poly></wfs:Insert></wfs:Transaction>
La transaction INSERT est la suivante :
Transasction Insert:net.opengis.wfs.impl.InsertElementTypeImpl@f73dde (feature: [SimpleFeatureImpl:sig__elements_poly=[SimpleFeatureImpl.Attribute:
metaDataProperty<metaDataProperty id=fid--376dd377_1379804d450_-7ff5>=null, SimpleFeatureImpl.Attribute: description<description id=fid--376dd377_1379804d450_-7ff5>=null,
SimpleFeatureImpl.Attribute: name<name id=fid--376dd377_1379804d450_-7ff5>=null, SimpleFeatureImpl.Attribute: boundedBy<boundedBy id=fid--376dd377_1379804d450_-7ff5>=null,
SimpleFeatureImpl.Attribute: location<location id=fid--376dd377_1379804d450_-7ff5>=null, SimpleFeatureImpl.Attribute: gid<gid id=fid--376dd377_1379804d450_-7ff5>=null,
SimpleFeatureImpl.Attribute: enddate<enddate id=fid--376dd377_1379804d450_-7ff5>=null, SimpleFeatureImpl.Attribute: startdate<startdate id=fid--376dd377_1379804d450_-7ff5>=null,
SimpleFeatureImpl.Attribute: code_commune<code_commune id=fid--376dd377_1379804d450_-7ff5>=null, SimpleFeatureImpl.Attribute:
id_element<id_element id=fid--376dd377_1379804d450_-7ff5>=1, SimpleFeatureImpl.Attribute: id_univers<id_univers id=fid--376dd377_1379804d450_-7ff5>=1,
SimpleFeatureImpl.Attribute: id_typologie<id_typologie id=fid--376dd377_1379804d450_-7ff5>=1, SimpleFeatureImpl.Attribute:
dos_infos<dos_infos id=fid--376dd377_1379804d450_-7ff5>=opp, SimpleFeatureImpl.Attribute: the_geom<the_geom id=fid--376dd377_1379804d450_-7ff5>=POLYGON
((-41768.058637764 5357800.9464467, -41966.317179851 5357774.6712182, -41906.600751512 5357323.21502, -41710.730866559 5357349.4902485,
-41768.058637764 5357800.9464467))]], handle: null, idgen: <unset>, inputFormat: <unset>, srsName: null)
Je travaille avec GéoServer.
Avez-vous déjà eu à faire à ce problème ?
Savez-vous d'où cela peut-il venir ?
Et surtout, avez-vous une solution à ce problème ?
Merci d'avance pour vos réponses !
Dernière modification par rboussant (Tue 29 May 2012 15:14)
#2 Wed 20 March 2013 15:10
Boy_From_HelL
Re: srsName est null
a quoi ça sert les xmlns (xml name space) ?? peut on supprimer tous ces urls ?
#3 Wed 20 March 2013 15:26
Yves
Lieu: Aix-les-Bains
Surement pas ! Il vaut mieux éviter, elles n'ont pas été mise là par hasard pour faire jolie.
Les xmlns sont des déclarations d'espaces de nom qui seront utilisé dans le xml qui suit. Cela permet d'avoir un xml correctement structuré avec des éléments dont on connaît la source et la description.
Y.
#4 Mon 08 April 2013 13:05
Boy_From_HelL
bien claire merci
