#1 Fri 25 January 2013 19:39
- abel.ludba
MapBasic V 9.5
Salut
Je travaille sur des fichiers routiers : routes de plusieurs categories. Je voudrais faire un fichier MapInfo qui encapsule tous les fichiers sur lesquels je travaille.
Je crée donc, un Seamless file. Voci comment je procede.
(code réduit mais completement fonctionnel)
Include "c:\program files\mapinfo\mapbasic\MapBasic.def"
Include "c:\program files\mapinfo\mapbasic\Icons.def"
Include "c:\program files\mapinfo\mapbasic\Menu.def"
Declare Sub Main
Sub Main
close all
' Decalarations
dim i as Integer
dim intLayerNbr as Integer
dim intLayerNbrToSeamless as Integer
dim intLayerID as Integer
dim strActiveScreenName as String
dim strPathToFiles as String
dim strFileName(3) as String
dim strThisFile as String
dim strSeamlessName as String
Dim tablename As String
Dim TableFullName As String
Dim new_name As String
dim strCurrentLayer as String
strFileName(1)="CollectorRtes.TAB"
strFileName(2)="localRtes.TAB"
new_name="D:\Documents and Settings\hamdoab\My Documents\seamless_roads"
strPathToFiles="D:\Documents and Settings\hamdoab\My Documents\seamless_roads"
dim fltLonMIN, fltLonMAX ,fltLatMIN, fltLatMAX as Float
dim objThisObject as Object
dim boolIsSeamless as Logical
dim boolDoesItWork as Logical
Open Table "D:\Documents and Settings\hamdoab\My Documents\seamless_roads\localRtes.tab" Interactive
Map From localRtes
Open Table "D:\Documents and Settings\hamdoab\My Documents\seamless_roads\CollectorRtes.TAB" Interactive
Add Map Auto Layer CollectorRtes
intLayerID =FrontWindow()
tablename = PathToTableName$(new_name)
note ("tablename ="+tablename )
Create Table tablename (Table Char(100),Description Char(25) )
File new_name
TYPE NATIVE
Create Map For tablename CoordSys Window intLayerID
intLayerNbr =MapperInfo(intLayerID ,MAPPER_INFO_LAYERS )
for i =1 to 2
strCurrentLayer =LayerInfo( intLayerID ,i, LAYER_INFO_NAME)
TableFullName = LayerInfo(intLayerID , i, LAYER_INFO_PATH)
TableFullName = PathToFileName$(TableFullName)
fltLonMIN = TableInfo( strCurrentLayer , TAB_INFO_MINX )
fltLatMIN = TableInfo( strCurrentLayer , TAB_INFO_MINY )
fltLonMAX = TableInfo( strCurrentLayer , TAB_INFO_MAXX )
fltLatMAX = TableInfo( strCurrentLayer , TAB_INFO_MAXY )
Create Rect Into Variable objThisObject (fltLonMIN,fltLatMIN)(fltLonMAX,fltLatMAX)
Insert Into tablename (Table, Description, Obj) Values (TableFullName, strCurrentLayer , objThisObject )
'intLayerNbr = intLayerNbr + 1
Next
Set Table tablename Seamless On
Commit Table tablename
end subJ'ai message à fin disant " Cannont perform this operation on table..."?
Quelqu'un aurait une idée pourquoi?
Thanks
Abel
#2 Sat 26 January 2013 14:18
- Spacejo
- Lieu: Nancy
Re: MapBasic V 9.5
Salut et bienvenue,
Les tables sur lesquelles tu interviens sont t'elles en lecture seule (read only)?
Joël
Dernière modification par Spacejo (Sat 26 January 2013 14:18)
#3 Sun 27 January 2013 15:25
- abel.ludba
Re: MapBasic V 9.5
Salut Joel
Salut tout le monde
Je n'ai pas mis les tables en monde édition (Editabl). J'ai essayé de les mettre ne monde edition et j'ai reçu l'erreur "Invalid view layer".
Je ne sais pas quoi faire?
Merci de votre aide
Abel
#4 Mon 28 January 2013 10:32
- Spacejo
- Lieu: Nancy
Re: MapBasic V 9.5
Est ce que tes tables sont issues d'un fichier excel?
Une possibilité est de faire un "sauvegarder sous" de tes tables et de faire ta manip avec ces copies qui normalement devraient être en "Interractive".
Joël
#5 Mon 28 January 2013 13:19
- abel.ludba
Re: MapBasic V 9.5
Salut
Mes fichiers sont une conversion de fichiers shp (on reçoit ces fichiers 2 fois par an).
Si j'utilise l'outil de création de fichiers seamless de MapInfo cela fonctionne. Mais, comme ce sont des fichiers routiers pour tout le pays et qu'il y a des categories (autoroutes, routes nationnales, etc.) j'ai donc plus de 900 tab à ouvrir avec cette outil pour les convertir en seamless. D'ou l'utilité d'avoir un programme qui fait cela tous les 6 mois.
Le problème c'est mon code MapBasic qui ne fonctionne pas. Je dois faire qlq ch de pas correct.
Mais, je ne sais pas quoi?
Abel
