#1 Tue 29 January 2013 12:03
xav
Format pdf - Orientation
j'ai un traitement qui me génère des pdf.
Jusque la pas de problème par contre par défaut les pdf sont orienté en portrait, je souhaiterai savoir s'il est possible de changer cette orientation pour du paysage.
Savez-vous si c'est possible ?
Xavier Lang
Cap Atlantique
#2 Tue 29 January 2013 14:06
Loic_GR
Lieu: Besancon
Re: Format pdf - Orientation
Apparemment c'est possible en passant des paramètres à la main
Page size is set in points (1 inch = 72 points), so if you set the page
size to "1191 842" you get a landscape A3. Then with the "Location of
map on page" parameter you define an area on the page (2 pairs of page
coordinates, in points, measuring from the lower left corner) in which
the map is placed and by setting the "Map Extents" you define the
geographical area (in map units) that's to be shown inside the map area
you've defined. Note that these last two parameters are optional and if
the length/width ratios don't match up the writer will compensate for that.
The help for the Geospatial PDF writer is pretty informative, all of
this can be found there.
Autre ressource : http://fmepedia.safe.com/articles/FAQ/G … -Page-Size
Dernière modification par heretik25 (Tue 29 January 2013 14:08)
#3 Tue 29 January 2013 17:13
xav
Merci de l'info, je vais tester
Xavier Lang
Cap Atlantique
