#1 Tue 12 March 2013 18:00
Wheintz
Lieu: Toulouse
Problème installation geosource 2.7.3
Bonjour à tou(te)s,
Cela fait un moment que je tente une installation de la version 2.7.3 de geosource sur un Debian Squeeze, connectée à une base Postgres fraîchement installée elle aussi.
Une fois l'installation terminée, j'obtiens systématiquement la même page d'erreur dans mon navigateur :
Error Raised exception while starting appl handler. Skipped.
Exception    org.apache.commons.dbcp.SQLNestedException: Borrow prepareStatement from pool failed
Message     Borrow prepareStatement from pool failed
Handler      org.fao.geonet.Geonetwork
org.apache.commons.dbcp.SQLNestedException: Borrow prepareStatement from pool failed at
org.apache.commons.dbcp.PoolingConnection.prepareStatement(PoolingConnection.java:113) at
org.apache.commons.dbcp.DelegatingConnection.prepareStatement(DelegatingConnection.java:281) at
org.apache.commons.dbcp.PoolingDataSource$PoolGuardConnectionWrapper.prepareStatement(PoolingDataSource.java:313) at
jeeves.resources.dbms.Dbms.selectFull(Dbms.java:204) at jeeves.resources.dbms.Dbms.select(Dbms.java:176) at
org.fao.geonet.languages.IsoLanguagesMapper.init(IsoLanguagesMapper.java:81) at org.fao.geonet.Geonetwork.start(Geonetwork.java:350) at
jeeves.server.JeevesEngine.initAppHandler(JeevesEngine.java:541) at jeeves.server.JeevesEngine.init(JeevesEngine.java:170) at
jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:78) at javax.servlet.GenericServlet.init(GenericServlet.java:212) at
org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1206) at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:1026) at
org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:4421) at org.apache.catalina.core.StandardContext.start(StandardContext.java:4734) at
org.apache.catalina.core.StandardContext.reload(StandardContext.java:3461) at org.apache.catalina.manager.ManagerServlet.reload(ManagerServlet.java:943) at
org.apache.catalina.manager.HTMLManagerServlet.reload(HTMLManagerServlet.java:557) at
org.apache.catalina.manager.HTMLManagerServlet.doGet(HTMLManagerServlet.java:121) at javax.servlet.http.HttpServlet.service(HttpServlet.java:617) at
javax.servlet.http.HttpServlet.service(HttpServlet.java:717) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290) at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at
org.apache.catalina.filters.CsrfPreventionFilter.doFilter(CsrfPreventionFilter.java:186) at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233) at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191) at
org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:563) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
 at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293) at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859) at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:602) at
org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489) at java.lang.Thread.run(Thread.java:636) Caused by: org.h2.jdbc.JdbcSQLException: Column
SHORTCODE not found; SQL statement: SELECT code, shortcode FROM IsoLanguages [42122-104] at org.h2.message.Message.getSQLException(Message.java:103) at
org.h2.message.Message.getSQLException(Message.java:114) at org.h2.message.Message.getSQLException(Message.java:77) at
org.h2.expression.ExpressionColumn.optimize(ExpressionColumn.java:130) at org.h2.command.dml.Select.prepare(Select.java:723) at
org.h2.command.Parser.prepareCommand(Parser.java:233) at org.h2.engine.Session.prepareLocal(Session.java:352) at
org.h2.engine.Session.prepareCommand(Session.java:313) at org.h2.jdbc.JdbcConnection.prepareCommand(JdbcConnection.java:1043) at
org.h2.jdbc.JdbcPreparedStatement.<init>(JdbcPreparedStatement.java:72) at org.h2.jdbc.JdbcConnection.prepareStatement(JdbcConnection.java:220) at
org.apache.commons.dbcp.PoolingConnection.makeObject(PoolingConnection.java:285) at
org.apache.commons.pool.impl.GenericKeyedObjectPool.borrowObject(GenericKeyedObjectPool.java:1190) at
org.apache.commons.dbcp.PoolingConnection.prepareStatement(PoolingConnection.java:107) ... 36 more
Les logs de tomcat ne sont pas beaucoup plus explicites (en tout cas pour moi ...)
J'avoue que je sèche ... J'ai tout tenté mais je n'arrive pas à trouver ce qui cloche.
Si quelqu'un a une idée, ça serait formidable ;-)
Merci !
Wilfried
#2 Wed 13 March 2013 18:13
VianneyD
Re: Problème installation geosource 2.7.3
J'avais eu un problème semblable suite à un démarrage simultané de Tomcat et Postgres.
Avez-vous tenté de redémarrer Tomcat seul ?
Vianney Dugrain
#3 Thu 14 March 2013 14:39
Wheintz
Lieu: Toulouse
Merci pour votre réponse.
Oui, j'ai tenté à peu près toutes les combinaisons. Redémarrages simultanés, successifs ...
Wilfried
Dernière modification par Wheintz (Fri 15 March 2013 14:24)
