#1 Thu 11 July 2013 15:05
araking
msLoadMap(): Premature End-of-File. <br>
salut,
je ne comprends pas cette erreur voila le mapfile:
map
name "wms_tunisie"
EXTENT -104049 3820546 1088656 4652283
STATUS ON
PROJECTION
"init=epsg:4121"
END
IMAGETYPE PNG
IMAGECOLOR 240 240 240
STATUS ON
UNITS METERS
FONTSET"fonts.txt"
SYMBOLSET"symbols.txt"
SHAPEPATH"projet1"
size 600 420
size 600 420
OUTPUTFORMAT
  NAME "png"
  DRIVER AGG/PNG
  MIMETYPE "image/png"
  IMAGEMODE RGB
  EXTENSION "png"
  FORMATOPTION "GAMMA=0.75"
END
OUTPUTFORMAT
  NAME "jpeg"
  DRIVER AGG/JPEG
  MIMETYPE "image/jpeg"
  IMAGEMODE RGB
  EXTENSION "jpg"
END
REFERENCE
IMAGE projet1/img.png
EXTENT 454024 3892529 528373 3950102
SIZE 163 122
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 0 128 0
END
SCALEBAR
POSTLABELCACHE TRUE
STYLE 0
UNITS kilometers
size 350 3
TRANSPARENT ON
COLOR 77 77 88
IMAGECOLOR 242 255 195
BACKGROUNDCOLOR 222 222 222
LABEL
  COLOR  150 150 150
  OUTLINECOLOR 255 255 255
  FONT "sans"
  TYPE Bitmap
  SIZE small
  ANGLE 90
  POSITION AUTO
  PARTIALS FALSE
END
END
LEGEND
  STATUS ON
  KEYSIZE 18 12
END
Layer
name "TUNSIA"
data"TUN_adm1.shp"
status ON
type POLYGON
class
name "TUNISIA"
color 204 250 255
end
LAYER
NAME copyright
transform off
LABELCACHE ON
POSTLABELCACHE TRUE
STATUS ON
# TYPE annotation
TYPE POINT
FEATURE
POINTS
40 590 #this is the position of the text in image coordinates (pixels)
END
TEXT "Geographical data - Prefecture of Chania 2009 ©" #this is your displaying text
END
CLASS
LABEL #defines the font, colors etc. of the text
FONT "Vera"
TYPE TRUETYPE
SIZE 9
BUFFER 1
COLOR 0 0 0
FORCE TRUE
position cr
END
END
END
Dernière modification par araking (Thu 11 July 2013 17:59)
#2 Fri 12 July 2013 13:29
araking
Re: msLoadMap(): Premature End-of-File. <br>
là il manque un end smile
#3 Sat 13 July 2013 11:41
Yves
Lieu: Aix-les-Bains
Il manque un END à la fin de ka couche tunisia et il y a deux fois le
paramètre SIZE au dessus de cette couche.
Pas dur que cela soit ca qui implique l'erreur décrite.
Y.
