#1 Thu 11 July 2013 18:44
araking
getmap
Je suis débutant je vais vous demander de m'aider à résoudre ce problème je n'est plus du temps, je veux visualiser un mapfile avec mon navigateur mais j'arrive pas voilà le fichier:
map
name "wms_tunisie"
EXTENT -104049 3820546 1088656 4652283
STATUS ON
PROJECTION
"init=epsg:4121"
END
WEB
  METADATA
    "wms_title"           "WMS_TUNISIA"
    "wms_onlineresource"  "http://localhost/cgi-bin/mapserv?map=arafet/projet1/proj.map&"
"wms_srs" "epsg:4326"
"wms_format" "image/png"
  END
END
IMAGETYPE PNG
IMAGECOLOR 240 240 240
STATUS ON
UNITS METERS
FONTSET"fonts.txt"
SYMBOLSET"symbols.txt"
SHAPEPATH"projet1"
size 600 420
size 600 420
OUTPUTFORMAT
  NAME "png"
  DRIVER AGG/PNG
  MIMETYPE "image/png"
  IMAGEMODE RGB
  EXTENSION "png"
  FORMATOPTION "GAMMA=0.75"
END
OUTPUTFORMAT
  NAME "jpeg"
  DRIVER AGG/JPEG
  MIMETYPE "image/jpeg"
  IMAGEMODE RGB
  EXTENSION "jpg"
END
REFERENCE
IMAGE projet1/img.png
EXTENT 454024 3892529 528373 3950102
SIZE 163 122
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 0 128 0
END
SCALEBAR
POSTLABELCACHE TRUE
STYLE 0
UNITS kilometers
size 350 3
TRANSPARENT ON
COLOR 77 77 88
IMAGECOLOR 242 255 195
BACKGROUNDCOLOR 222 222 222
LABEL
  COLOR  150 150 150
  OUTLINECOLOR 255 255 255
  FONT "sans"
  TYPE Bitmap
  SIZE small
  ANGLE 90
  POSITION AUTO
  PARTIALS FALSE
END
END
LEGEND
  STATUS ON
  KEYSIZE 18 12
END
Layer
NAME "TUNISIA"
METADATA
"wms_title"   "TUNSIA"
END
PROJECTION
"init=epsg:4326"
END
data"TUN_adm1.shp"
status ON
type POLYGON
class
name "TUNISIA"
color 204 250 255
end
LAYER
NAME copyright
transform off
LABELCACHE ON
POSTLABELCACHE TRUE
STATUS ON
# TYPE annotation
TYPE POINT
FEATURE
POINTS
40 590 #this is the position of the text in image coordinates (pixels)
END
TEXT "Geographical data - Prefecture of Chania 2009 ©" #this is your displaying text
END
CLASS
LABEL #defines the font, colors etc. of the text
FONT "Vera"
TYPE TRUETYPE
SIZE 9
BUFFER 1
COLOR 0 0 0
FORCE TRUE
position cr
END
END
END
avec la requète getmap: http://localhost/cgi-bin/mapserv?map=home/projet1/proj.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=Getmap&LAYERS=TUNISIA
j'ai comme résultat :
msLoadMap(): Unable to access file. (home/projet1/proj.map)
merci smile
Dernière modification par araking (Thu 11 July 2013 18:45)
#2 Fri 12 July 2013 09:14
VianneyD
Re: getmap
Je te suggère de vérifier le chemin de ton mapfile, est- ce bien : home/projet1/proj.map ?
Si oui il peut s'agir aussi de problème de droits sur le fichier...
Vianney Dugrain
#3 Fri 12 July 2013 13:10
araking
Re: getmap
merci Vianney pour ta réponse le chemin est faux , je l'ai changé mais j'ai la même erreur,autre chose j'ai vérifier avec shp2img mais il me génère une image blanche ; j'ai convertit mon mapfle en osm j'ai trouvé comme epsg:3857 je l'ai changé voici c'est ce que j'a trouvé dans le ficher .osm
<Viewport>
      <topright lon="12.9592606" lat="39.8437949"/>
      <bottomleft lon="-3.1300151" lat="27.2414696"/>
</Viewport>
    <Projection type="EPSG:3857"/>
donc j'ai aussi changé l'étendue mais j'ai  la même image blanche est la même erreur avec le navigateur.
merci
#4 Sat 13 July 2013 11:41
Yves
Lieu: Aix-les-Bains
Re: getmap
Il manque le / devant home : map=/home/etc
Y.
#5 Sat 13 July 2013 11:42
Yves
Lieu: Aix-les-Bains
Re: getmap
Autre chose : la requête WMS est fausse car incomplète. D'ailleurs il vaut
mieux utiliser une requête de type getcapabilities pour debuguer.
Y.
#6 Sat 13 July 2013 11:48
araking
Re: getmap
merci Yves mais même getcapablities ne marche pas même avec shp2img j'ai une image blanche
#7 Sat 13 July 2013 12:01
Yves
Lieu: Aix-les-Bains
Re: getmap
Tu peux poster ta requete ? Tu n'es pas censé récupérer une image avec un getcapabilites ! Ca devrait être ca :
http://localhost/cgi-bin/mapserv?map=/home/projet1/proj.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
Y.
#8 Sat 13 July 2013 12:03
araking
Re: getmap
http://localhost/cgi-bin/mapserv?map=/home/projet1/proj.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities&LAYERS=TUNISIA
msLoadMap(): Unable to access file. (/home/projet1/proj.map)
#9 Sat 13 July 2013 12:19
araking
Re: getmap
<ServiceExceptionReport version="1.3.0" xsi:schemaLocation="http://www.opengis.net/ogc http://schemas.opengis.net/wms/1.3.0/ex … eption>
msWMSGetCapabilities(): WMS server error. WMS request not enabled. Check wms/ows_enable_request settings.
</ServiceException></ServiceExceptionReport>
Voilà le GetCapabilities
#10 Sat 13 July 2013 12:32
Yves
Lieu: Aix-les-Bains
Re: getmap
Il faut rajouter le paramètre "ows_enable_request" avec une valeur "*" (pour faire simple) dans le METADATA de l'objet WEB :
WEB
  METADATA
      "ows_enable_request" "*"
   END
END
Il faut bien  sur laisser ce qu'y est déjà !
Y.
#11 Sat 13 July 2013 13:41
araking
Re: getmap
merci Yves d'être patient avec moi ,là je bloque encore sad un j'ai comme :WARNING: Optional Ex_GeographicBoundingBox could not be established for this layer.  Consider setting the EXTENT in the LAYER object, or wms_extent metadata. Also check that your data exists in the DATA statement .
Je ne sais pas si l'étendue est juste ou non.
#12 Sat 13 July 2013 14:11
Yves
Lieu: Aix-les-Bains
Re: getmap
Le message est toujours explicite : il faut vérifier le chemin vers les données ou rajouter un paramètre EXTENT dans la couche (où bien encore ajouter le paramètre wms_extent dans les métadata de la couche).
Y.
#13 Sat 13 July 2013 16:07
araking
Re: getmap
Je ne plus de warning au niveau de GetCapabilities,mais avec GetMap j'ai une image blanche voici la requète:"http://localhost/cgi-bin/mapserv?map=/home/arafet/projet1/proj1.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&LAYERS=TUN_adm2&STYLES=&CRS=EPSG:4326&BBOX=-3.13002,27.2414696,12.9592606,39.8437949&WIDTH=600&HEIGHT=420&FORMAT=image/png&"
codeMapfile:
MAP
    NAME "wms_tunisie"
    EXTENT -3.1300151 27.2414696 12.9592606 39.8437949
    STATUS ON
    PROJECTION
       "init=epsg:4326"
    END
    WEB
      METADATA
        "wms_onlineresource"  "http://localhost/cgi-bin/mapserv?map=/home/arafet/projet1/proj1.map&"
        "wms_srs" "epsg:4326 epsg:4269 epsg:3978 epsg:3857"
        "wms_enable_request" "*"
         "wms_extent" "-3.1300151 27.2414696 12.9592606 39.8437949 "
      END
    END
    IMAGETYPE PNG
    STATUS ON
    UNITS METERS
    SHAPEPATH"/home/arafet/projet1"
    SIZE 600 420
    OUTPUTFORMAT
      NAME "png"
      DRIVER AGG/PNG
      IMAGEMODE RGB
      EXTENSION "png"
    END
    REFERENCE
        IMAGE home/arafet/projet1/img.png
        SIZE 163 122
        STATUS ON
        COLOR -1 -1 -1
    END
    SCALEBAR
        POSTLABELCACHE TRUE
        STYLE 0
        UNITS kilometers
        size 350 3
        TRANSPARENT ON
        COLOR 77 77 88
        LABEL
          COLOR  150 150 150
          FONT "sans"
          TYPE Bitmap
          SIZE small
          ANGLE 90
          POSITION AUTO
          PARTIALS FALSE
        END
    END
    LEGEND
        STATUS ON
        KEYSIZE 18 12
    END
    LAYER
        NAME TUN_adm2
        METADATA
       END
       PROJECTION
           "init=epsg:3857"
       END
       TYPE POLYGON
       STATUS ON
       DATA  TUN_adm2
       CLASS
              NAME "TUNISIA"
              COLOR 204 250 255
       END
    END
END
et le code xml de GetCapbilities:
<WMS_Capabilities version="1.3.0" xsi:schemaLocation="http://www.opengis.net/wms http://schemas.opengis.net/wms/1.3.0/capabilities_1_3_0.xsd  http://www.opengis.net/sld http://schemas.opengis.net/sld/1.1.0/sld_capabilities.xsd  http://mapserver.gis.umn.edu/mapserver http://localhost/cgi-bin/mapserv?map=/home/arafet/projet1/proj1.map&service=WMS&version=1.3.0&request=GetSchemaExtension"><!-- MapServer version 6.0.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE --><Service><Name>WMS</Name><Title>WMS_TUNISIA</Title><OnlineResource xlink:href="http://localhost/cgi-bin/mapserv?map=/home/arafet/projet1/proj1.map&"/><ContactInformation>
  </ContactInformation><MaxWidth>2048</MaxWidth><MaxHeight>2048</MaxHeight></Service><Capability><Request><GetCapabilities><Format>text/xml</Format><DCPType><HTTP><Get><OnlineResource xlink:href="http://localhost/cgi-bin/mapserv?map=/home/arafet/projet1/proj1.map&"/></Get><Post><OnlineResource xlink:href="http://localhost/cgi-bin/mapserv?map=/home/arafet/projet1/proj1.map&"/></Post></HTTP></DCPType></GetCapabilities><GetMap><Format>image/png</Format><Format>image/jpeg</Format><Format>image/gif</Format><Format>image/png; mode=8bit</Format><Format>application/x-pdf</Format><Format>image/svg+xml</Format><Format>image/tiff</Format><DCPType><HTTP><Get><OnlineResource xlink:href="http://localhost/cgi-bin/mapserv?map=/home/arafet/projet1/proj1.map&"/></Get><Post><OnlineResource xlink:href="http://localhost/cgi-bin/mapserv?map=/home/arafet/projet1/proj1.map&"/></Post></HTTP></DCPType></GetMap><GetFeatureInfo><Format>text/plain</Format><Format>application/vnd.ogc.gml</Format><DCPType><HTTP><Get><OnlineResource xlink:href="http://localhost/cgi-bin/mapserv?map=/home/arafet/projet1/proj1.map&"/></Get><Post><OnlineResource xlink:href="http://localhost/cgi-bin/mapserv?map=/home/arafet/projet1/proj1.map&"/></Post></HTTP></DCPType></GetFeatureInfo><sld:DescribeLayer><Format>text/xml</Format><DCPType><HTTP><Get><OnlineResource xlink:href="http://localhost/cgi-bin/mapserv?map=/home/arafet/projet1/proj1.map&"/></Get><Post><OnlineResource xlink:href="http://localhost/cgi-bin/mapserv?map=/home/arafet/projet1/proj1.map&"/></Post></HTTP></DCPType></sld:DescribeLayer><sld:GetLegendGraphic><Format>image/png</Format><Format>image/jpeg</Format><Format>image/gif</Format><Format>image/png; mode=8bit</Format><DCPType><HTTP><Get><OnlineResource xlink:href="http://localhost/cgi-bin/mapserv?map=/home/arafet/projet1/proj1.map&"/></Get><Post><OnlineResource xlink:href="http://localhost/cgi-bin/mapserv?map=/home/arafet/projet1/proj1.map&"/></Post></HTTP></DCPType></sld:GetLegendGraphic><ms:GetStyles><Format>text/xml</Format><DCPType><HTTP><Get><OnlineResource xlink:href="http://localhost/cgi-bin/mapserv?map=/home/arafet/projet1/proj1.map&"/></Get><Post><OnlineResource xlink:href="http://localhost/cgi-bin/mapserv?map=/home/arafet/projet1/proj1.map&"/></Post></HTTP></DCPType></ms:GetStyles></Request><Exception><Format>XML</Format><Format>INIMAGE</Format><Format>BLANK</Format></Exception><sld:UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0" InlineFeature="0" RemoteWCS="0"/><Layer><Name>wms_tunisie</Name><Title>WMS_TUNISIA</Title><Abstract>wms_tunisie</Abstract><CRS>epsg:4326</CRS><CRS>epsg:4269</CRS><CRS>epsg:3978</CRS><CRS>epsg:3857</CRS><EX_GeographicBoundingBox><westBoundLongitude>-3.13002</westBoundLongitude><eastBoundLongitude>12.9593</eastBoundLongitude><southBoundLatitude>27.2415</southBoundLatitude><northBoundLatitude>39.8438</northBoundLatitude></EX_GeographicBoundingBox><BoundingBox CRS="EPSG:4326" minx="27.2415" miny="-3.13002" maxx="39.8438" maxy="12.9593"/><Layer queryable="0" opaque="0" cascaded="0"><Name>TUN_adm2</Name><Title>TUNSIA</Title><CRS>EPSG:3857</CRS><EX_GeographicBoundingBox><westBoundLongitude>-2.81174e-05</westBoundLongitude><eastBoundLongitude>0.000116415</eastBoundLongitude><southBoundLatitude>0.000244714</southBoundLatitude><northBoundLatitude>0.000357923</northBoundLatitude></EX_GeographicBoundingBox><BoundingBox CRS="EPSG:3857" minx="-3.13002" miny="27.2415" maxx="12.9593" maxy="39.8438"/><Style><Name>default</Name><Title>default</Title><LegendURL width="75" height="22"><Format>image/png</Format><OnlineResource xlink:type="simple" xlink:href="http://localhost/cgi-bin/mapserv?map=/home/arafet/projet1/proj1.map&version=1.3.0&service=WMS&request=GetLegendGraphic&sld_version=1.1.0&layer=TUN_adm2&format=image/png&STYLE=default"/></LegendURL></Style></Layer></Layer></Capability></WMS_Capabilities>
#14 Sat 13 July 2013 16:54
Yves
Lieu: Aix-les-Bains
Re: getmap
Change :
PROJECTION
           "init=epsg:3857"
       END
par
PROJECTION
           "init=epsg:4326"
       END
Ca devrait mieux fonctionner !
Y.
#15 Sat 13 July 2013 17:07
araking
Re: getmap
Bonjpur,
je l'ai changé mais encore la même image qui figure peut être l'étendue est faux ?
#16 Sat 13 July 2013 18:40
araking
Re: getmap
même avec shp2img si la projectoin est 3857 ça retourne une image blanche et avec 4326 ça affiche comme erreur :
msDrawMap(): Image handling error. Failed to draw layer named 'TUN_adm2'. <br>
msShapefileOpen(): Unable to access file. (/home/arafet/projet1/./TUN_adm2.shp) <br>
msShapefileOpen(): Unable to access file. (/home/Téléchargements/TUN_adm2/TUN_adm2.shp) <br>
#17 Sat 13 July 2013 19:11
Yves
Lieu: Aix-les-Bains
Re: getmap
Dans tout les cas la projection de la couche doit être celle des données, soit 4326.
Là c'est un autre message d'erreur qui indique que MapServer ne trouve pas le fichier.
Il y a une autre erreur : IMAGE home/arafet/projet1/img.png devait être IMAGE /home/arafet/projet1/img.png
Le fichier TUN_adm2.shp se trouve t'il bien dans le répertoire /home/arafet/projet1 ? Pourquoi le cherche t'il dans le répertoire /home/Téléchargements/TUN_adm2/ ?
Y.
#18 Sat 13 July 2013 20:23
araking
Re: getmap
le chemin home/arafet/projet1/img.png n'a rien à voir avec l'affichage du layer je l'ai corrigé ,à propos du shapefle c'est moi qui a changé le chemin j'ai pensé de séparer les répertoires qu contiennent le mapfile et le shapefile au lieu de les mettre dans un même dossier.
#19 Sat 13 July 2013 20:31
Yves
Lieu: Aix-les-Bains
Re: getmap
Araking,
As tu mis à jour ton mapfile suite au déplacement de tes données wink il semble que non !
Y.
#20 Sat 13 July 2013 20:44
araking
Re: getmap
Bon je ne l'ai pas fait quand j'ai copié le message d'erreur ici mais je l'a fait aprés et j'ai le même message , en tous cas je m'excuse de t'avoir déranger smile ,est-il possible que le problème vient de shapefile! je l'ai importé sur la base de donnée et je l'ai importer à QGIS il m'a affiché la carte ,mais j'aurai bien besoin de l'afficher sur le navigateur pour pouvoir  ajouter d'autres couches aprés sad
#21 Mon 15 July 2013 14:45
araking
Re: getmap
j'ai commis une faute bête, en fait pour le shapefile j'a utilisé seulement l'extension .shp sans utiliser les autres,donc j'a ajouté les autres extensions et ça marche bien smile
Dernière modification par araking (Mon 15 July 2013 14:46)
