#1 Thu 25 July 2013 13:09
- araking
[openlayers] addFeatures
j'ai un problème dans la de dessiner mon point aprés la géolocalistion voici le code:
function loadDemo() {
if(navigator.geolocation) {
document.getElementById("support").innerHTML = "I'll find you!";
navigator.geolocation.getCurrentPosition(updateLocation, handleLocationError, {timeout:100000});
} else {
document.getElementById("support").innerHTML = "Browser is so old";
function handleLocationError(){
switch(error.code)
case error.PERMISSION_DENIED:
x.innerHTML="User denied the request for Geolocation."
break;
case error.POSITION_UNAVAILABLE:
x.innerHTML="Location information is unavailable."
break;
case error.TIMEOUT:
x.innerHTML="The request to get user location timed out."
break;
case error.UNKNOWN_ERROR:
x.innerHTML="An unknown error occurred."
break;
function updateLocation(position) {
var latitudeg = position.coords.latitude;
var longitudeg = position.coords.longitude;
var accuracy = position.coords.accuracy;
document.getElementById("latitude").innerHTML = latitudeg;//works
document.getElementById("longitude").innerHTML = longitudeg;//works
document.getElementById("accuracy").innerHTML = "This location is accurate within " +accuracy + " meters."
var lonLat = new OpenLayers.LonLat(longitudeg,latitudeg).transform(new OpenLayers.Projection("EPSG:4326"),new OpenLayers.Projection("EPSG:900913"));
alert(lonLat);
var pointg = new OpenLayers.Geometry.Point(longitudeg, latitudeg);
pointg.transform(
var feature_point_g = new OpenLayers.Feature.Vector(pointg);
alert(pointg.lat);// retourne undifined
alert(feature_point_g);//retourne [object Object]
map.addFeatures([feature_point_g]);//retourne map.addFeatures is not a fuction
map.refresh({force:true});
}Hors ligne
#2 Thu 25 July 2013 16:39
- araking
Re: [openlayers] addFeatures
pas d'aide
le problème vient de
ça retourne
[object Object]
Dernière modification par araking (Thu 25 July 2013 16:50)
#3 Thu 25 July 2013 18:31
- VianneyD
ça retourne
[object Object]
Je pense que c'est normal, tu fais un alert d'un objet OpenLayers.Feature.Vector, qui est de type {Object}
Si tu veux tester ta variable il vaut mieux faire un alert sur un attribut texte ou nombre de ta variable, par exemple :
alert (feature_point_g.geometry.toString());
Vianney Dugrain
#4 Thu 25 July 2013 18:42
- VianneyD
Je pense que le problème vient plutot du fait que tu fais appel à une fonction qui n'existe pas :
Ta variable map est-elle un objet OpenLayers.Map ?
Attention car addFeatures est une fonction de l'objet OpenLayers.Layer.Vector
Vianney Dugrain
#5 Thu 25 July 2013 19:01
- araking
merci pour l'info,toString() me montre que ça marche bien, j'ai changé un peu mon code en créant un vecteur
vectors = new OpenLayers.Layer.Vector("Vector Layer");
vectors.addFeatures([feature_point_g]);//
map.addLayer(vectors);
aucun bug n'est détécté par firebug mais mon point ne s'affiche pas, est ce que j'ai oublié quelque chose pour que mon point se dessine?
#6 Fri 26 July 2013 13:36
- VianneyD
La couche "Vector Layer" est-elle bien présente dans ton gestionnaire de couches ? Si oui, il peut s'agir d'un problème de projection, ton feature est bien créé mais il se promène quelque part à l'autre bout de la planète...
Vianney Dugrain
#7 Fri 26 July 2013 15:52
- araking
Effectivement ,aprés un clic sur le bouton de localisation, la couche s'ajoute avec les overlay layers,peut être que c'est un problème de projection,mais comment je peux le résoudre surtout que mon feature a comme prjojection EPSG:4326 avec la créaton de mon map j'ai ajouté le paramètre Openlayers.Bounds
Dernière modification par araking (Fri 26 July 2013 15:52)
#8 Fri 26 July 2013 16:43
- araking
j'ai enlevé EPSG:900913 et ça marche mais elle n'est pas précise des kilomètres à ma position !
Dernière modification par araking (Fri 26 July 2013 17:13)
