#1 Thu 14 November 2013 14:39
frkdavid
QGIS 2.1.0 : Impossible de charger l'extension 'processing'
Après la mise à jour de QGIS 1.8 vers QGIS 2 sous Ubuntu Lucid 64bits (10.04). QGIS affiche une erreur au démarrage :
Impossible de charger l'extension 'processing' depuis ['/usr/share/qgis/python', '/home/frank/.qgis2/python', '/home/frank/.qgis2/python/plugins', '/usr/share/qgis/python/plugins', '/usr/lib/python2.6', '/usr/lib/python2.6/plat-linux2', '/usr/lib/python2.6/lib-tk', '/usr/lib/python2.6/lib-old', '/usr/lib/python2.6/lib-dynload', '/home/frank/.local/lib/python2.6/site-packages', '/usr/lib/python2.6/dist-packages', '/usr/lib/python2.6/dist-packages/PIL', '/usr/lib/python2.6/dist-packages/gst-0.10', '/usr/lib/pymodules/python2.6', '/usr/lib/python2.6/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.6/gtk-2.0', '/usr/lib/python2.6/dist-packages/wx-2.8-gtk2-unicode', '/usr/local/lib/python2.6/dist-packages', '/usr/share/qgis/python/plugins/fTools/tools']
  File "/usr/lib/python2.6/dist-packages/qgis/utils.py", line 182, in loadPlugin
    __import__(packageName)
  File "/usr/lib/python2.6/dist-packages/qgis/utils.py", line 453, in _import
    mod = _builtin_import(name, globals, locals, fromlist, level)
  File "/usr/share/qgis/python/plugins/processing/__init__.py", line 29, in
    from processing.tools.general import *
  File "/usr/share/qgis/python/plugins/processing/tools/general.py", line 29, in
    from processing.core.Processing import Processing
  File "/usr/share/qgis/python/plugins/processing/core/Processing.py", line 49, in
    from processing.grass.GrassAlgorithmProvider import GrassAlgorithmProvider
  File "/usr/share/qgis/python/plugins/processing/grass/GrassAlgorithmProvider.py", line 37, in
    from processing.grass.GrassAlgorithm import GrassAlgorithm
  File "/usr/share/qgis/python/plugins/processing/grass/GrassAlgorithm.py", line 31, in
    import importlib
ImportError: No module named importlib
Version de Python :
2.6.5 (r265:79063, Sep 26 2013, 18:58:43)
[GCC 4.4.3]
Version de QGIS :
2.1.0-Master Master, exported
Chemin vers Python : ['/usr/share/qgis/python', u'/home/frank/.qgis2/python', u'/home/frank/.qgis2/python/plugins', '/usr/share/qgis/python/plugins', '/usr/lib/python2.6', '/usr/lib/python2.6/plat-linux2', '/usr/lib/python2.6/lib-tk', '/usr/lib/python2.6/lib-old', '/usr/lib/python2.6/lib-dynload', '/home/frank/.local/lib/python2.6/site-packages', '/usr/lib/python2.6/dist-packages', '/usr/lib/python2.6/dist-packages/PIL', '/usr/lib/python2.6/dist-packages/gst-0.10', '/usr/lib/pymodules/python2.6', '/usr/lib/python2.6/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.6/gtk-2.0', '/usr/lib/python2.6/dist-packages/wx-2.8-gtk2-unicode', '/usr/local/lib/python2.6/dist-packages', '/usr/share/qgis/python/plugins/fTools/tools']
puis :
Une erreur est apparue lors de l'exécution du code suivant :
pyplugin_installer.initPluginInstaller()
  File "", line 1, in
  File "/usr/share/qgis/python/pyplugin_installer/installer.py", line 43, in initPluginInstaller
    pluginInstaller = QgsPluginInstaller()
  File "/usr/share/qgis/python/pyplugin_installer/installer.py", line 58, in __init__
    repositories.load()
  File "/usr/share/qgis/python/pyplugin_installer/installer_data.py", line 330, in load
    url = settings.value(key+"/url", "", type=unicode)
TypeError: QSettings.value(QString, QVariant defaultValue=QVariant()): 'type' is not a valid keyword argument
Version de Python :
[GCC 4.4.3]
Version de QGIS :
2.1.0-Master 'Master', exported
J'ai modifié les droits de ~/.qgis2 = 777, comme proposé sur plusieurs forums, mais sans changements.
Je suis passé en "nightly" (depot deb http://qgis.org/ubuntugis-nightly lucid main), mais sans changements.
Mes recherches n'ont rien donné de plus, alors je me tourne vers ceux qui auraient pu rencontrer le même problème sous Lucid.
merci d'avance pour vos conseils !
#2 Tue 07 January 2014 19:22
Clovis
Re: QGIS 2.1.0 : Impossible de charger l'extension 'processing'
C'est fou...meme souci chez moi et le moins qu'on puisse dire c'est que ça ne s'agite pas au portillon.
Personne d'autre peine à basculer de la 1.8 à la 2.0 sur linux 10.04 ?
#3 Wed 08 January 2014 08:23
René-Luc D'Hont
La version de Python sur votre distribution pose problème, vous devriez voir si il est possible d'utiliser Python 2.7 et non 2.6.
Je vous conseille aussi de passer à une version plus récente de Ubuntu, votre distribution va bientôt avoir 4 ans.
Cordialment
