Différences
Lien vers cette vue comparative
Les deux révisions précédentesRévision précédente
Prochaine révision
Révision précédente
main:logiciels:ilwis:dat.eng [2009/11/28 07:41] Robinmain:logiciels:ilwis:dat.eng [Date inconnue] (Version actuelle) – supprimée - modification externe (Date inconnue) 127.0.0.1
Ligne 1: Ligne 1:
-[[traduction_soft|Retour]]
-Voilà un nouveau fichier traduit relativement vite, via le GTK.
-Bonne chance pour la relecture,
-robin.
-Contenu de dat.eng :
-    1 "Calculating eigen vectors"
-    2 "Create factor %S" @
-    3 "Create principal component %S" @
-    4 "Create MapList %S" @
-    5 "Initialising sample map" @
-    6 "Initialising SampleSet Statistics"
-    7 "Deleting class '%S'"
-    8 "Merging classes '%S' and '%S'"
-    9 "Copy files" @
-   10 "Merging domains"
-   11 "Sizing new domain"
-   12 "Adding to new domain"
-   13 "Add string '%S' to domain '%S'"
-   14 "Merge strings of domain '%S' into domain '%S'nnWarning: the combination of iff() and merging of domains can lead to incorrect resultsnPlease read the help topic 'Map and Table Calculation: Merging domains (workaround)'"
-   15 "Calculating"
- 100 "Row position of text" @
- 101 "Col position of text" @
- 102 "X-coord"
- 103 "Reference X-coord"
- 104 "Y-coord"
- 105 "Reference Y-coord"
- 106 "Z-coord"
- 107 "Reference Z-coord"
- 108 "Active point" @
- 109 "Correlation Matrix for %S" @
- 110 "Variance-Covariance Matrix for %S" @
- 111 "Unspecified Map" @
- 112 "Confusion Matrix for %S, %S and %S" @
- 113 "Average Accuracy is Undefinedn"
- 114 "Average Accuracy"
- 115 "Average Reliablity is Undefinedn"
- 116 "Average Reliablity"
- 117 "Overall Accuracy is Undefinedn"
- 118 "Overall Accuracy"
- 119 "Find data files for" @
- 120 "Create list of objects for" @
- 121 "Class Name" @
- 122 "ID Name" @
- 123 "Code"
- 124 "Order"
- 125 "Inverse Order" @
- 126 "Description"
- 127 "? Deleted domain item" @
- 128 "Equation of Fitting Function"
- 200 "Calculate factors"
- 201 "Calculate principal components"
- 202 "Matrix Error" @
- 203 "Deleting class from SampleSet"
- 204 "Merging classes of SampleSet"
- 205 "Execute script '%S'"
- 206 "Loading attribute table" @
- 207 "Copy Object(s)"
- 208 "ILWIS Error" @
- 209 "Feature Space map %S and map %S" @
- 210 "Name"
- 211 "Create Object Collection"
- 300 "Domain '%S' contained double items.nThis may have caused problems.nItem names have been changed."
- 301 "File already exists, choose another name" @
- 400 "Empty or no '%s=' entry found in section '%s'"
- 401 "Central Latitude should not be 0" @
- 402 "Central Latitude should not be +/-90" @
- 403 "Azimuth should not be +/-90" @
- 404 "Singular"
- 405 "Not symmetrical"
- 406 "Too many iterations"
- 407 "'}' expected"
- 408 "Unknown command: '%S'"
- 409 "Domain/valuerange expected"
- 410 "Invalid line: ' %S '"
- 411 "Only group domain allowed: '%S'"
- 412 "Only value domain allowed: '%S'"
- 413 "Only value, class, ID or group domain allowed: '%S'"
- 414 "Only class, ID or group domain allowed: '%S'"
- 415 "Only class domain allowed: '%S'"
- 416 "Only identifier domain allowed: '%S'"
- 417 "Only image domain allowed, found: '%S'"
- 418 "Invalid directory: '%S'"
- 419 "Attribute Table has wrong Domain"
- 420 "Loading Attribute Table of Map" @
- 421 "Positive threshold needed:"
- 422 "Domains for columns '%S' and '%S' need to be the same" @
- 423 "Class name must be unique"
- 424 "Class code must be unique"
- 425 "Name must be unique"
- 426 "Code name must be unique"
- 427 "Loading attribute table" @
- 428 "Attribute Table has wrong Domain"
- 429 "Loading Attribute Table of Domain"
- 430 "Not allowed in system dir" @
- 431 "Object still open" @
- 432 "File read only" @
- 433 "Can't copy onto itself"
- 434 "No attribute table" @
- 435 "Error in Errorhandling"
- 436 "Fatal ILWIS Error" @
- 437 "*** Error ***" @
- 438 "Unknown"
- 439 "Invalid type in section"
- 440 "This object is not a" @
- 441 "Out of Memory"
- 442 "Error"
- 443 "Not Implemented"
- 444 "Invalid expression '%S':nSyntax:n%S"
- 445 "Invalid application: '%S'"
- 446 "Directory not found: '%S'"
- 447 "Percentage %g should be in range 0..%g%%"
- 448 "Wrong coordinate system: '%S'"
- 449 "Incompatible georefs: %S and %S" @
- 450 "Incompatible domains: %S and %S" @
- 451 "Incompatible coordinate systems: %S and %S" @
- 452 "Incompatible map size: %S and %S" @
- 453 "Georeference with coordinates needed"
- 454 "DTM Map with Georeference Corners needed"
- 455 "Disk full" @
- 456 "Rename"
- 457 "File already exists"
- 458 "Invalid filter size:" @
- 459 "Rank needs to be in range" @
- 460 "Filter size too large:"
- 461 "Not enough points for least squares fit" @
- 462 "Too few terms for least squares fit" @
- 463 "Not enough points for number of terms in least squares fit" @
- 464 "No possible solution in least squares fit" @
- 465 "Invariant failed"
- 466 "Pre/Post condition failed"
- 467 "Assertion failed"
- 468 "ID name must be unique"
- 469 "ID code must be unique"
- 470 "SemiVariogram Model name is not known in ILWIS" @
- 471 "Semivariogram parameter is undefined"
- 472 "Range of Semivariogram must be positive"
- 473 "Power exponent of Semivariogram must be positive"
- 474 "Power exponent of Semivariogram may not be greater than 10" @
- 475 "Could not find %S" @
- 476 "Map List Error" @
- 500 "Floating Point Error" @
- 501 "Invalid"
- 502 "DeNormal"
- 503 "Divide by Zero" @
- 504 "Overflow"
- 505 "Underflow"
- 506 "Inexact"
- 507 "Unemulated"
- 508 "Square Root of Negative Number"
- 509 "Stack Overflow"
- 510 "Stack Underflow"
- 511 "Exception Raised"
- 600 "Invalid function"
- 601 "File not found" @
- 602 "Path not found" @
- 603 "Too many open files" @
- 604 "Access denied"
- 605 "Invalid handle"
- 606 "Arena thrashed"
- 607 "Not enough memory"
- 608 "Invalid block" @
- 609 "Bad environment"
- 610 "Bad format"
- 611 "Invalid access"
- 612 "Invalid data" @
- 613 "Invalid drive" @
- 614 "Current directory"
- 615 "Not same device"
- 616 "No more files" @
- 617 "Write protect error" @
- 618 "Bad unit" @
- 619 "Not ready" @
- 620 "Bad command"
- 621 "CRC error" @
- 622 "Bad length"
- 623 "Seek error" @
- 624 "Not MS-DOS disk" @
- 625 "Sector not found" @
- 626 "Out of paper" @
- 627 "Write fault" @
- 628 "Read fault" @
- 629 "General failure"
- 630 "Sharing violation"
- 631 "Lock violation"
- 632 "Wrong disk" @
- 633 "File control block unavailable"
- 634 "Sharing buffer exceeded"
- 635 "Not supported"
- 636 "Remote not listed"
- 637 "Duplicate name" @
- 638 "Bad netpath"
- 639 "Network busy" @
- 640 "Device does not exist" @
- 641 "Too many commands"
- 642 "Adaptor hardware error" @
- 643 "Bad network response"
- 644 "Unexpected network error" @
- 645 "Bad remote adaptor"
- 646 "Print queue full" @
- 647 "No spool space" @
- 648 "Print canceled"
- 649 "Netname deleted"
- 650 "Network access denied"
- 651 "Bad device type" @
- 652 "Bad network name" @
- 653 "Too many names" @
- 654 "Too many sessions"
- 655 "Sharing paused"
- 656 "Request not accepted"
- 657 "Redirection paused"
- 658 "File exists"
- 659 "Duplicate file control block" @
- 660 "Cannot make" @
- 661 "Interrupt 24 failure"
- 662 "Out of structures"
- 663 "Already assigned"
- 664 "Invalid password"
- 665 "Invalid parameter"
- 666 "Net write fault" @
- 667 "Unknown error" @
- 668 "File Open Error in" @
- 669 "File Create Error in" @
- 670 "File Seek Error in" @
- 671 "File Read Error in" @
- 672 "File Read Buffer Error in" @
- 673 "File Write Error in" @
- 674 "File Close Error in" @
- 675 "File Still Open Error in" @
- 676 "Rename Error from" @
- 677 "Unlink ErrornIn"
- 678 "Illegal filenamenin"
- 679 "Write access to file failed, file is read/only"
- 680 "Could not open collection %S" @
- 700 "Mean per band:" @
- 701 "Std. per band:" @
- 702 "Copy"
- 703 "position"
- 704 "block of" @
- 705 "bytes"
- 706 "Please report - this is a BUG" @
- 707 "to"
- 708 "Invariant"
- 709 "Pre Condition"
- 710 "Post Condition"
- 711 "Assertion"
-Traduction avec le google Kit, donc pas de version en vis à vis :
-   1 "Calcul des vecteurs étendus"
-   2 "Créer facteur %S"
-   3 "Créer composante principale %S"
-   4 "Créer la liste de cartes %S"
-   5 "Initialisation de la carte d'échantillons"
-   6 "Initialisation des statistiques de set d'échantillons"
-   7 "Suppression de la classe '%S'"
-   8 "Fusion des classes '%S' et '%S'"
-   9 "Copier les fichiers"
-  10 "Fusion des domaines"
-  11 "Dimensionnement du nouveau domaine"
-  12 "Ajout du nouveau domaine"
-  13 "Ajouter la chaîne '%S' au domaine '%S'"
-  14 "Fusion des chaînes du domaine '%S' dans le domaine '%S' /n Attention : l'association du IFF() et la fusion de domaines peuvent conduire à des résultats incorrects /n Merci de lire la rubrique d'aide 'Calcul de carte et de tables : la fusion de domaines (contournement)' "
-  15 "Calcul"
-  100 "Position de la ligne de texte"
-  101 "Position de la colonne de texte"
-  102 "Coord. X"
-  103 "Coord. X de référence"
-  104 "Coord. Y"
-  105 "Coord. Y de référence"
-  106 "Coord. Z"
-  107 "Coord. Z de référence"
-  108 "Point actif"
-  109 "Matrice de corrélation pour'%s'"
-  110 "Matrice de Variance/Covariance pour '%s'"
-  111 "Carte indéfinie"
-  112 "Matrice de confusion pour %S, %S et %S"
-  113 "La précision moyenne est indéfinie"
-  114 "Précision moyenne"
-  115 "La fiabilité moyenne est indéfinie"
-  116 "Fiabilité moyenne"
-  117 "La précision globale est indéfinie"
-  118 "Précision globale"
-  119 "Trouver les fichiers de données pour"
-  120 "Créer une liste d'objets pour"
-  121 "Nom de classe"
-  122 "Nom d'ID"
-  123 "Code"
-  124 "Ordre"
-  125 "Ordre inverse"
-  126 "Description"
-  127 "? Élément de Domaine supprimé"
-  128 "Équation d'une fonction d'ajustement "
-  200 "Calculer les facteurs"
-  201 "Calcul en composantes principales"
-  202 "Matrice d'erreur"
-  203 "Suppression de la classe du set d'échantillonage"
-  204 "Fusion des classes d'échantillonnage"
-  205 "Exécution du script '%S'"
-  206 "Chargement de la table attributaire"
-  207 "Copier Objet (s)"
-  208 "Erreur ILWIS"
-  209 "Afficher la spatiocarte %S et la carte %S"
-  210 "Nom"
-  211 "Créer une collection d'objets"
-  300 "Le Domaine '%S' contenait des éléments en double. /n Ce pourrait causer des erreurs. /n Les noms des éléments ont été changés."
-  301 "Le fichier existe déjà, choisissez un autre nom"
-  400 "Vide ou sans '%s=' entrée trouvée dans la section '%s'"
-  401 "La Latitude centrale ne devrait pas être 0"
-  402 "La Latitude centrale ne devrait pas être à + / -90"
-  403 "L'Azimut ne devrait pas être à + / -90"
-  404 "Unique"
-  405 "Pas symétriques"
-  406 "Trop d'itérations"
-  407 "'}' attendu"
-  408 "Commande inconnue : '%S'"
-  409 "Domaine / Dimension de valeurs attendus"
-  410 "Ligne non valide: '%S'""
-  411 "Seuls le groupe de domaine est autorisé : '%S'"
-  412 "Seule la valeur de domaine est autorisée : '%S'"
-  413 "Seule la valeur, classe, ID ou groupe de domaine est autorisée : '%S'"
-  414 "Seule la classe, ID ou groupe de domaine est autorisée : '%S'"
-  415 "Seul le domaine de classe est autorisé : '%S'"
-  416 "Seul le domaine d'identifiant est autorisé : '%S'"
-  417 "Seul le domaine d'image est autorisé : '%S'"
-  418 "Répertoire non valide:'%S'"
-  419 "Le domaine de la Table Attributaire est erroné"
-  420 "Chargement de la Table Attributaire de la Carte"
-  421 "Seuil de tolérance positif nécessaire :"
-  422 "Le domaine pour les colonnes '%S' et '%S' doivent être les mêmes"
-  423 "Le Nom de classe doit être unique"
-  424 "Le Code de classe doit être unique"
-  425 "Le nom doit être unique"
-  426 "Le Nom de code doit être unique"
-  427 "Chargement de la Table Attributaire"
-  428 "Le domaine de la Table Attributaire est erroné"
-  429 "Chargement de la Table Attributaire de la Carte"
-  430 "Non autorisé dans le répertoire système"
-  431 "Objet encore ouvert"
-  432 "Fichier en lecture seule"
-  433 "Impossible de copier sur lui-même"
-  434 "Aucune table attributaire"
-  435 "Erreur dans le traitement des erreurs"
-  436 «ILWIS Fatal Error"
-  437 "*** Erreur ***"
-  438 "Inconnu"
-  439 "Type non valide dans la section"
-  440 "Cet objet n'est pas un"
-  441 "Plus de mémoire"
-  442 "Erreur"
-  443 "Non implémenté"
-  444 "Expression non valide '%S' : /n Syntaxe : /n '%S'"
-  445 "Application non valide : '%S'"
-  446 "Répertoire non trouvé: '%S'"
-  447 "Le Pourcentage %g devrait être dans la gamme 0 .. %g%%"
-  448 "Système de coordonnées incorrect : '%S'"
-  449 "GeoRef. incompatibles : %S et %S"
-  450 "Domaines incompatibles : %S et %S"
-  451 "Systèmes de coordonnées incompatibles : %S et %S"
-  452 "Taille de la carte incompatible : %S et %S"
-  453 "Géoréf. avec coordonnées nécessaire"
-  454 "MNT avec des coins géoreferencés nécessaire"
-  455 "Disque plein"
-  456 "Renommer"
-  457 "Le fichier existe déjà"
-  458 "Taille de filtre non valide :"
-  459 "Le rang doit être dans la gamme"
-  460 "Taille de filtre trop grand :"
-  461 "Pas assez de points pour l'ajustement des moindres carrés"
-  462 "Pas assez de termes pour l'ajustement des moindres carrés
-  463 "Pas assez de points pour le nombre de termes pour l'ajustement des moindres carrés"
-  464 "Aucune solution possible pour l'ajustement des moindres carrés"
-  465 "Invariant échoué"
-  466 "Pré/Post condition échouée"
-  467 "Assertion échouée"
-  468 "Le nom de l'ID doit être unique"
-  469 "Le code de l'ID doit être unique"
-  470 "Le nom du modèle de Semi-variogramme n'est pas connu dans ILWIS"
-  471 "Le paramètre de Semi-variogramme n'est pas défini"
-  472 "La gamme de Semi-variogramme doit être positive"
-  473 "L'exposant de la puissance de Semi-variogramme doit être positif"
-  474 "L'exposant de la puissance de Semi-variogramme ne doit pas être supérieur à 10"
-  475 "Impossible de trouver %S"
-  476 "Erreur de liste de carte"
-  500 "Erreur de Point Flottant"
-  501 "Non valide"
-  502 "Denormal"
-  503 "Division par zéro"
-  504 "Overflow"
-  505 "Underflow"
-  506 "Inexact"
-  507 "Non émulé"
-  508 "Racine carrée de nombre négatif"
-  511 "Erreur d'Exception"
-  600 "Fonction non valide"
-  601 "Fichier non trouvé"
-  602 "Chemin d'accès introuvable"
-  603 "Trop de fichiers ouverts"
-  604 "Accès refusé"
-  605 "Poignée non valide"
-  606 "Arêne supprimée"
-  607 "Mémoire insuffisante"
-  608 "Bloc non valide"
-  609 "Environnement non valide"
-  610 "Format non valide"
-  611 "Accès non valide"
-  612 "Données incorrectes"
-  613 "Lecteur non valide"
-  614 "Répertoire courant"
-  615 "Périphérique différent"
-  616 "Plus de fichiers"
-  617 "Erreur de protection d'écriture"
-  618 "Unité non valide"
-  619 "Pas prêt"
-  620 "Commande non valide"
-  621 "Erreur CRC"
-  622 "Longueur non valide"
-  623 "Error de recherche"
-  624 "Disque non MS-DOS"
-  625 "Secteur introuvable"
-  626 "Plus de papier"
-  627 "Erreur d'écriture"
-  628 "Erreur de lecture"
-  629 "Erreur générale"
-  630 "Violation de partage"
-  631 "Violation de verrouillage"
-  632 "Mauvais Disque"
-  633 "Bloc de contrôle de fichiers non disponible"
-  634 "Tampon de partage dépassé"
-  635 "Non supporté"
-  636 "Commande à distance non listée"
-  637 "Nom en double"
-  638 "Chemin réseau erroné"
-  639 "Réseau occupé"
-  640 "Le périphérique n'existe pas"
-  641 "Trop de commandes"
-  642 "Erreur d'Adaptateur matériel"
-  643 "Réponse du réseau non valide"
-  644 "Erreur réseau inattendue"
-  645 "Adaptateur distant non valide"
-  646 "File d'attente d'impression complète"
-  647 "Pas d'espace de spool"
-  648 "Impression annulée"
-  649 "Nom réseau supprimé"
-  650 "Accès au réseau refusé"
-  651 "Type de périphérique non valide"
-  652 "Nom du réseau non valide"
-  653 "Trop de noms"
-  654 "Trop de sessions"
-  655 "Partage en pause"
-  656 "Demande non acceptée"
-  657 "Redirection en pause"
-  658 "Le fichier existe "
-  659 "Bloc de contrôle de fichiers dupliqué"
-  660 "Ne peut pas faire"
-  661 "Erreur d'interruption 24"
-  662 "Hors des structures"
-  663 "déjà allouées"
-  664 "Mot de passe non valide"
-  665 "Paramètre non valide"
-  666 "Erreur d'écriture réseau"
-  667 "Erreur inconnue"
-  668 "Erreur d'ouverture de fichier dans"
-  669 "Erreur de création de fichier dans"
-  670 "Erreur de recherche de fichier dans"
-  671 "Erreur de lecture de fichier dans"
-  672 "Erreur de tampon de lecture de fichier dans"
-  673 "Erreur d'écriture de fichier dans"
-  674 "Erreur de fermeture de fichier dans"
-  675 "Erreur de fichier toujours ouvert dans"
-  676 »Renommer erreur de"
-  677 "Détacher l'erreur /n dans "
-  678 "Nom de fichier illégal /n dans"
-  679 "Accès en écriture au fichier échoué, le fichier est en lecture-seule"
-  680 "Impossible d'ouvrir la collection %S"
-  700 "Moyenne par bande :"
-  701 "Std. par bande :"
-  702 "Copie"
-  703 "position"
-  704 "bloc de"
-  705 "octets"
-  706 "Merci de faire un retour - ceci est un BUG"
-  707 "à"
-  708 "invariants"
-  709 "Pré Condition"
-  710 "Post condition"
-  711 "Affirmation"
main/logiciels/ilwis/dat.eng.1259394083.txt.gz · Dernière modification : (modification externe)
