Différences
Lien vers cette vue comparative
Les deux révisions précédentesRévision précédente
Prochaine révision
Révision précédente
main:logiciels:ilwis:digitizr.eng [2009/12/03 22:34] Robinmain:logiciels:ilwis:digitizr.eng [Date inconnue] (Version actuelle) – supprimée - modification externe (Date inconnue) 127.0.0.1
Ligne 1: Ligne 1:
-[[traduction_soft|Retour]]
-Contenu de digitizr.eng à traduire :
-    1 "Setup Digitizer"
-    2 "Setup Digitizer - Port Settings"
-    3 "Setup Digitizer - Select Port" @
-    4 "Setup Digitizer - Automatic Detection"
-    5 "Setup Digitizer - Manual Setup" @
-    6 "Setup Digitizer - Size, Resolution and Final Check" @
-    7 "Map Referencing - Coordinate System"
-    8 "Locate Fiducial Marks" @
-    9 "Map Referencing - Digitizer Control Points"
- 100 "Are these settings correct"
- 101 "Port Settings"
- 102 "Scan Resolution:"
- 103 "pixel"
- 104 "Digitizer Grid Resolution:"
- 105 "Digitizer-Grid Unit" @
- 200 "Received:"
- 201 "Number of Received Characters is not constant"
- 202 "Press Button %i" @
- 203 "Trying Automatic Detection"
- 204 "Nothing"
- 205 "Button"
- 206 "None"
- 207 "digitizer"
- 208 "coordinates"
- 209 "diff X" @
- 210 "diff Y" @
- 211 "Minimum three points required"
- 212 "Scale 1:XXXXXXXXXXXX / XXXXXXXXXXXX"
- 213 "Rotation XXXXX.X / XXXXX.X degrees"
- 214 "Not enough points"
- 215 "Singular Matrix"
- 216 "Sigma = %2.1f mm" @
- 217 "Scale 1:%1.0f / 1:%1.0f"
- 218 "Rotation %1.1f / %1.1f degrees"
- 219 "Scale 1:%1.0f"
- 220 "Rotation %1.1f degrees"
- 221 "RowCol (pixels)"
- 222 "Photo (mm)" @
- 223 "diff Row" @
- 224 "diff Col" @
- 225 "Grid XY (digitizer grid units)"
- 226 "diff Grid X" @
- 227 "diff Grid Y" @
- 228 "Specify settings for the selected port:" @
- 229 "RowCol (sub-pixel precision)"
- 230 "Photo (mm in camera-system)"
- 300 "BADID: The device identifier is invalid or unsupported"
- 301 "BAUDRATE: The device's baud rate is unsupported"
- 302 "BYTESIZE: The specified byte size in invalid"
- 303 "DEFAULT: The default parameters are in error" @
- 304 "HARDWARE: The hardware is not availablen(is locked by another device)"
- 305 "MEMORY: The function cannot allocate the queues"
- 306 "NOPEN: The device is not open" @
- 307 "OPEN: The device is already open" @
- 308 "IE error %i" @
- 309 "Error opening COM port %in%S" @
- 310 "Error opening COM port %i (DCB)" @
- 311 "Error opening comport %i (State)"
- 312 "Digitizer Error" @
- 313 "WinTab driver not found or not active"
- 314 "Error in communication"
- 315 "Error"
- 316 "No valid fiducial marks found" @
- 317 "Less than 2 fiducial marks" @
- 318 "Incorrect positions of fiducial marks" @
- 319 "Incorrect ordering of 4 fiducial marks" @
- 320 "Wrong number"
- 321 "Too few fiducials, %i needed"
- 400 "&Manual"
- 401 "&Nr chars" @
- 402 "&X Pos" @
- 403 "X &Length"
- 404 "&Y Pos" @
- 405 "Y &Length"
- 406 "&Flag pos" @
- 407 "Flag &Codes"
- 408 "&Metric System"
- 409 "&Lines per mm" @
- 410 "&Lines per inch" @
- 411 "&X-size (mm)" @
- 412 "&Y-size (mm)" @
- 413 "&X-size (inch)"
- 414 "&Y-size (inch)"
- 415 "Digitizer Port:" @
- 416 "&None"
- 417 "COM&1:"
- 418 "COM&2:"
- 419 "COM&3:"
- 420 "COM&4:"
- 421 "&Coordinate System"
- 422 "Use for Control Points:"
- 423 "&Metric (Projected) Coordinates"
- 424 "&Geographic Coordinates"
- 425 "&Conformal transformation"
- 426 "&Affine transformation"
- 427 "&WinTab"
- 428 "&Baud Rate" @
- 429 "&Data Bits" @
- 430 "&Parity"
- 431 "&Stop Bits" @
- 500 "Map Referencing"
- 501 "Digitize Point" @
- 502 "Next Point" @
- 503 "Delete Point" @
-   1 "Configuration du numériseur"
-   2 "Configuration du numériseur - Paramètres du port"
-   3 "Configuration du numériseur" - Sélectionnez Port"
-   4 "Configuration du numériseur - Détection automatique"
-   5 "Configuration du numériseur" - Configuration Manuelle"
-   6 "Configuration du numériseur - Taille, Résolution et vérification finale"
-   7 "Géoréférencement de carte - Système de coordonnées"
-   8 "Localiser les points de repère"
-   9 "Géoréférencement de carte "- Points de contrôles du numériseur"
-  100 "Les paramètres sont ils corrects"
-  101 "Paramètres du port"
-  102 «Résolution de numérisation:"
-  103 "Pixel"
-  104 "Résolution de la grille du numériseur:"
-  105 "Unité de la grille du numériseur"
-  200 "Reçu :"
-  201 "Nombre de caractères reçus non constants"
-  202 "Appuyer sur le bouton %i"
-  203 "Essai de Détection Automatique"
-  204 "Rien"
-  205 "Bouton"
-  206 "Aucun"
-  207 "Numériseur"   208 "coordonnées"
-  209 "diff X"
-  210 "diff Y"
-  211 "Minimum de trois points requis"
-  212 "Echelle 1: XXXXXXXXXXXX / XXXXXXXXXXXX"
-  213 "Rotation XXXXX.X / XXXXX.X degrés"
-  214 "Pas assez de points"
-  215 "Matrice singulière"
-  217 "Echelle 1:% 1.0f / 1:% 1.0f"
-  218 "Rotation %1.1f / %1.1f degrés"
-  219 "Echelle 1:%1.0f"
-  220 "Rotation %1.1f degrés"
-  221 "LigCol (pixels)"
-  222 "Photo (mm)"
-  223 "diff Ligne"
-  224 "diff Colonne"
-  225 "Grid XY (unités de la grille du numériseur)"
-  226 "diff Grid X"
-  227 "diff Grid Y"
-  228 "Spécifiez les paramètres pour le port sélectionné:"
-  229 "LigCol (précision sub-pixel)"
-  230 "Photo (mm dans le système de l'appareil photo)"
-  300 "BADID: L'identificateur de périphérique n'est pas valide ou non prise en charge"
-  301 "DEBIT : la vitesse de transmission de ce périphérique n'est pas supportée"
-  302 "ByteSize: La taille en octets spécifié est invalide"
-  303 "DÉFAUT: Les paramètres par défaut sont erronnés"
-  304 "Hardware: Le matériel n'est pas disponible /n (verrouillé par un autre périphérique)"
-  305 "MEMOIRE: La fonction ne peut pas allouer les files d'attente"
-  306 "nopen: Le périphérique n'est pas ouvert"
-  307 "OPEN: L'appareil est déjà ouvert"
-  308 "Erreur IE %i"
-  309 "Erreur à l'ouverture du port COM %in%s"
-  310 "Erreur d'ouverture du port COM %i (DCB)"
-  311 "Erreur d'ouverture de comport %i (Etat)"
-  312 "Erreur de numériseur"
-  313 "pilote WinTab introuvable ou non actif"
-  314 "Erreur de communication"
-  315 "Erreur"
-  316 "Points de repères non trouvé"
-  317 "Moins de 2 points de repère"
-  318 "Positions incorrectes des points repères"
-  319 "Classement de 4 points repères incorrect"
-  320 "Nombre incorrect"
-  321 "Trop peu de points de repère, i% nécessaire"
-  400 "&Manuel"
-  401 "&Nr chars"
-  402 "&X Pos"
-  403 "X &Longueur"
-  404 "&Y Pos"
-  405 "Y &Longueur"
-  406 "Etiqueter les POS»
-  407 "Etiquettes & Codes"
-  408 "Système &Métrique"
-  409 "&Lignes par mm"
-  410 "&Lignes par pouce"
-  411 "Taille de &X (mm)"
-  412 "Taille de &Y (mm)"
-  413 "Taille de &X (pouce)"
-  414 "Taille de &Y (pouce)"
-  415 "Port du numériseur:"
-  416 "&Aucun"
-  417 "COM&1:"
-  418 "COM&2:"
-  419 "COM&3:"
-  420 "COM&4:"
-  421 "&Système de Coordonnées"
-  422 "Utilisation des points de contrôle:"
-  423 "Coordonnées &Métriques (projetées) "
-  424 "Coordonnées &Géographiques"
-  425 "Transformation &Conforme"
-  426 "Transformation &Affine»
-  427 "&WinTab"
-  428 "Débit en &Baud"
-  429 "&Octets de données"
-  430 "&Parité»
-  431 "&Arrêter les Octetst"
-  500 "Géoréférencement de carte"
-  501 "Numériser Point"
-  502 "Point suivant"
-  503 "Supprimer le point"
main/logiciels/ilwis/digitizr.eng.1259879699.txt.gz · Dernière modification : (modification externe)
