- Vous êtes ici : Accéder au Wiki GeoRezo » Accueil : Wiki GeoRezo » Les logiciels en géomatique » Ilwis » domain.eng
Différences
| Les deux révisions précédentesRévision précédenteProchaine révision | Révision précédente | ||
| main:logiciels:ilwis:domain.eng [2009/12/10 00:12] – Robin | main:logiciels:ilwis:domain.eng [2026/11/09 13:11] (Version actuelle) – supprimée - modification externe (Date inconnue) 127.0.0.1 | ||
| Ligne 1: | Ligne 1: | ||
| - | [[traduction_soft|Retour]] | ||
| - | Contenu de conv.eng à traduire : | ||
| - | 1 " | ||
| - | 2 "Edit Domain Item" @ | ||
| - | 3 "Add Domain Item" @ | ||
| - | 4 "Merge Domain" | ||
| - | 5 " | ||
| - | 6 " | ||
| - | 7 " | ||
| - | 8 "Edit Domain Items" @ | ||
| - | 9 " | ||
| - | 10 " | ||
| - | 11 " | ||
| - | 12 " | ||
| - | 100 "Not a valid domain name" @ | ||
| - | 101 " | ||
| - | 102 " | ||
| - | 103 "The ' | ||
| - | 104 "No empty prefix allowed" | ||
| - | 105 " | ||
| - | 106 "%S name and Code should be different" | ||
| - | 107 "as system domain" | ||
| - | 200 "Too many items in domain to edit" @ | ||
| - | 201 " | ||
| - | 202 " | ||
| - | 203 " | ||
| - | 204 " | ||
| - | 205 "Not possible to merge with itself" | ||
| - | 206 " | ||
| - | 207 "Could not rename %i item(s)" | ||
| - | 208 " | ||
| - | 209 "%S or Code already in domain, cannot change." | ||
| - | 210 "%S or Code already in domain, cannot add, try again?" | ||
| - | 211 "%S or Code already in domain, cannot change, try again?" | ||
| - | 212 "Close all other objects that use %S before attempting to convert it" @ | ||
| - | 300 " | ||
| - | 301 " | ||
| - | 302 "%i Classes selected for deletion, proceed?" | ||
| - | 303 "%i items are selected" | ||
| - | 304 "Upper Bound" @ | ||
| - | 305 "Page: %i" @ | ||
| - | 306 "Page: %i / %i" @ | ||
| - | 307 " | ||
| - | 308 " | ||
| - | 309 " | ||
| - | 310 " | ||
| - | 311 " | ||
| - | 312 "%i ID's selected for deletion, proceed?" | ||
| - | 313 "%i boundary classes selected for deletion, proceed?" | ||
| - | 314 " | ||
| - | 315 " | ||
| - | 316 " | ||
| - | 400 "& | ||
| - | 401 " | ||
| - | 402 "& | ||
| - | 403 "& | ||
| - | 404 "& | ||
| - | 405 "& | ||
| - | 406 "& | ||
| - | 407 "& | ||
| - | 408 "& | ||
| - | 409 "& | ||
| - | 410 "& | ||
| - | 411 "& | ||
| - | 412 "& | ||
| - | 413 "& | ||
| - | 414 "& | ||
| - | 415 "& | ||
| - | 416 "& | ||
| - | 417 "& | ||
| - | 418 "'& | ||
| - | 419 "'& | ||
| - | 420 "Fixed Range" @ | ||
| - | 421 "Fixed Precision" | ||
| - | 422 "& | ||
| - | 423 "& | ||
| - | 1 " | ||
| - | 2 " | ||
| - | 3 " | ||
| - | 4 " | ||
| - | 5 «Sélectionner un nouveau type de tri de domaine" | ||
| - | 6 " | ||
| - | 7 " | ||
| - | 8 " | ||
| - | 9 " | ||
| - | 10 " | ||
| - | 11 " | ||
| - | 12 " | ||
| - | 100 "Nom de domaine non valide" | ||
| - | 101 "Le domaine existe déjà" | ||
| - | 102 " | ||
| - | 103 "Le caractère ' | ||
| - | 104 "Pas de préfixe vide autorisé" | ||
| - | 105 "Objet Système" | ||
| - | 106 "Le nom %S et le code doivent être différents" | ||
| - | 107 "en tant que système de domaine" | ||
| - | 200 "Trop d' | ||
| - | 201 " | ||
| - | 202 " | ||
| - | 203 " | ||
| - | 204 «La représentation doit avoir le bon domaine" | ||
| - | 205 " | ||
| - | 206 "Le domaine est en lecture seule" | ||
| - | 207 " | ||
| - | 208 " | ||
| - | 209 "%S ou code déjà dans le domaine, changement impossible." | ||
| - | 210 "%S ou code déjà dans le domaine, ajout impossible, réessayez?" | ||
| - | 211 "%S ou code déjà dans le domaine, changement impossible, réessayer ?" | ||
| - | 212 " | ||
| - | 300 " | ||
| - | 301 " | ||
| - | 302 "%i classes sélectionnées pour la suppression, | ||
| - | 303 "%i objets sont sélectionnés" | ||
| - | 304 "Borne max" | ||
| - | 305 "Page: %i" | ||
| - | 306 "Page: %i / %i" | ||
| - | 307 " | ||
| - | 308 " | ||
| - | 309 "Les changements dans le domaine dûs à un tri manuel ne peuvent pas être annulés, icontinuer?" | ||
| - | 310 " | ||
| - | 311 " | ||
| - | 312 "%i ID sélectionnés pour la suppression, | ||
| - | 313 "%i classes frontière sélectionnés pour la suppression, | ||
| - | 314 " | ||
| - | 315 " | ||
| - | 316 " | ||
| - | 400 "& | ||
| - | 401 " | ||
| - | 402 "& | ||
| - | 403 "& | ||
| - | 404 "& | ||
| - | 405 "& | ||
| - | 406 "& | ||
| - | 407 "& | ||
| - | 408 "& | ||
| - | 409 "& | ||
| - | 410 "& | ||
| - | 411 "& | ||
| - | 412 "& | ||
| - | 413 "& | ||
| - | 414 "& | ||
| - | 415 "& | ||
| - | 416 "& | ||
| - | 417 "& | ||
| - | 418 " '& | ||
| - | 419 " '& | ||
| - | 420 " | ||
| - | 421 " | ||
| - | 422 "& | ||
| - | 423 "& | ||
