Différences
Lien vers cette vue comparative
Les deux révisions précédentesRévision précédente
main:logiciels:ilwis:domain.eng [2009/12/10 00:13] – Robinmain:logiciels:ilwis:domain.eng [2026/11/09 13:11] (Version actuelle) – supprimée - modification externe (Date inconnue) 127.0.0.1
Ligne 1: Ligne 1:
-[[traduction_soft|Retour]]
-Contenu de conv.eng, traduction en dessous :
-    1 "Create Domain" @
-    2 "Edit Domain Item" @
-    3 "Add Domain Item" @
-    4 "Merge Domain" @
-    5 "Selecting new domain sort type" @
-    6 "Domain editor" @
-    7 "Change Prefix" @
-    8 "Edit Domain Items" @
-    9 "Create Domain from String" @
-   10 "Converting Class to Id" @
-   11 "Converting Id to Class" @
-   12 "Converting..." @
- 100 "Not a valid domain name" @
- 101 "Domain already exists" @
- 102 "Invalid Representation" @
- 103 "The '%c' character is not allowed in the prefix" @
- 104 "No empty prefix allowed" @
- 105 "System Object" @
- 106 "%S name and Code should be different" @
- 107 "as system domain" @
- 200 "Too many items in domain to edit" @
- 201 "Domain Editor" @
- 202 "Representation Change" @
- 203 "Error" @
- 204 "Representation should have the correct domain" @
- 205 "Not possible to merge with itself" @
- 206 "Domain is read only" @
- 207 "Could not rename %i item(s)" @
- 208 "Domain warning" @
- 209 "%S or Code already in domain, cannot change." @
- 210 "%S or Code already in domain, cannot add, try again?" @
- 211 "%S or Code already in domain, cannot change, try again?" @
- 212 "Close all other objects that use %S before attempting to convert it" @
- 300 "Delete class '%S' from the domain" @
- 301 "Delete Domain Item" @
- 302 "%i Classes selected for deletion, proceed?" @
- 303 "%i items are selected" @
- 304 "Upper Bound" @
- 305 "Page: %i" @
- 306 "Page: %i / %i" @
- 307 "Selection of: " @
- 308 "Delete boundary class '%S' from the domain" @
- 309 "Changes in the domain caused by changing from Manual Ordering cannot be undone, continue?" @
- 310 "Delete Domain Items" @
- 311 "Delete ID '%S' from the domain" @
- 312 "%i ID's selected for deletion, proceed?" @
- 313 "%i boundary classes selected for deletion, proceed?" @
- 314 "Renaming prefix from '%S' to '%S'" @
- 315 "Loading Domain. Please wait..." @
- 316 "Creating Domain. Please wait..." @
- 400 "&Domain Name" @
- 401 "Type" @
- 402 "&Class" @
- 403 "&Group" @
- 404 "&Identifier" @
- 405 "&Value" @
- 406 "&Integer" @
- 407 "&Name" @
- 408 "&Code" @
- 409 "&Upper Bound" @
- 410 "&Min, Max" @
- 411 "&Precision" @
- 412 "&Width" @
- 413 "&Representation" @
- 414 "&Nr of items" @
- 415 "&Description:" @
- 416 "&Prefix" @
- 417 "&Domain" @
- 418 "'&True' string" @
- 419 "'&False' string" @
- 420 "Fixed Range" @
- 421 "Fixed Precision" @
- 422 "&Unit" @
- 423 "&Bool" @
-Traduction :
-   1 "Créer un domaine"
-   2 "Modifier un domaine"
-   3 "Ajouter un domaine"
-   4 "Fusionner des domaines"
-   5 «Sélectionner un nouveau type de tri de domaine"
-   6 "Editeur de domaine"
-   7 "Changer le préfixe"
-   8 "Modifier des domaines"
-   9 "Créer un domaine à partir de chaîne de caractères"
-  10 "Convertir une classe en ID"
-  11 "Convertir un ID en classe"
-  12 "Conversion en cours ..."
-  100 "Nom de domaine non valide"
-  101 "Le domaine existe déjà"
-  102 "Représentation non valide"
-  103 "Le caractère '%c' n'est pas autorisé dans le préfixe"
-  104 "Pas de préfixe vide autorisé"
-  105 "Objet Système"
-  106 "Le nom %S et le code doivent être différents"
-  107 "en tant que système de domaine"
-  200 "Trop d'éléments dans le domaine à modifier"
-  201 "Editeur de domaine"
-  202 "Changement de Représentation"
-  203 "Erreur"
-  204 «La représentation doit avoir le bon domaine"
-  205 "Impossible de fusionner avec lui-même"
-  206 "Le domaine est en lecture seule"
-  207 "Impossible de renommer l'élément(s) %i"
-  208 "Alerte de domaine"
-  209 "%S ou code déjà dans le domaine, changement impossible."
-  210 "%S ou code déjà dans le domaine, ajout impossible, réessayez?"
-  211 "%S ou code déjà dans le domaine, changement impossible, réessayer ?"
-  212 "Fermer tous les objets qui utilisent %S avant d'essayer de le convertir"
-  300 "Supprimer la catégorie '%S' du domaine"
-  301 "Supprimer le domaine"
-  302 "%i classes sélectionnées pour la suppression, continuer?"
-  303 "%i objets sont sélectionnés"
-  304 "Borne max"
-  305 "Page: %i"
-  307 "Sélection de:"
-  308 "Supprimer la limite de classe '%S' du domaine"
-  309 "Les changements dans le domaine dûs à un tri manuel ne peuvent pas être annulés, icontinuer?"
-  310 "Supprimer les objets de domaine"
-  311 "Supprimer les ID '%S' du domaine"
-  312 "%i ID sélectionnés pour la suppression, continuer ?"
-  313  "%i classes frontière sélectionnés pour la suppression, continuer?"
-  314 "Renommer le préfixe de '%S' à '%S'"
-  315 "Chargement du domaine. Merci de patienter ... "
-  316 "Création de domaine. Merci de patienter ... "
-  400 "&Nom de domaine"
-  401 "Type"
-  402 "&Classe"
-  403 "&Groupe"
-  404 "&Identifier "
-  405 "&Valeur"
-  406 "&Entier"
-  407 "&Nom"
-  408 "&Code"
-  409 "&Borne Max"
-  410 "&Min, Max"
-  411 "&Précision"
-  412 "&Largeur"
-  413 "&Représentation"
-  414 "&Nb d'éléments"
-  416 "&Préfixe"
-  417 "&Domaine"
-  418 " '&Vraie' chaîne de caractères"
-  419 " '&Fausse' chaîne de caractères"
-  420 "Etendue fixe"
-  421 "Précision fixe"
-  422 "&Unité"
-  423 "&Bool"
main/logiciels/ilwis/domain.eng.1260404005.txt.gz · Dernière modification : (modification externe)
