Différences
Lien vers cette vue comparative
Les deux révisions précédentesRévision précédente
main:logiciels:ilwis:drwforms.eng [2009/04/16 16:17] – Page moved from main:geolibre:ilwis:drwforms.eng to main:logiciels:ilwis:drwforms.eng Robinmain:logiciels:ilwis:drwforms.eng [2026/10/28 06:47] (Version actuelle) – supprimée - modification externe (Date inconnue) 127.0.0.1
Ligne 1: Ligne 1:
-[[traduction_soft|Retour]]
-Contenu de drwforms.eng à traduire :
-    1 "Display Options - Raster Map" @
-    2 "Display Options - Point Map" @
-    3 "Display Options - Polygon Map" @
-    4 "Display Options - Segment Map" @
-    5 "Display Options - Grid" @
-    6 "Display Options - Graticule" @
-    7 "Display Options - Annotation" @
-    8 "Display Options - North Arrow" @
-    9 "Display Options - Scale Bar" @
-   10 "Display Options - Single Text" @
-   11 "Display Options - 3D Grid" @
-   12 "Display Options - Map List as SlideShow" @
-   13 "Display Options - Box" @
-   14 "Display Options - Legend" @
-   15 "Map Layer Selection" @
-   16 "Symbol" @
-   17 "Display Options - " @
-   18 "Display Options - Picture" @
-   19 "Display Options - Bitmap" @
-   20 "Display Options - Map List as ColorComp" @
-   21 "Symbols as Arrows" @
-   22 "Color" @
-   23 "Symbols as Graphs" @
-   24 "Symbols by Attributes" @
-   25 "Create Legend" @
-   26 "Display Options - Stereo Pair as Anaglyph" @
- 100 "Graticule.grat" @
- 101 "Grid.grid" @
- 102 "Legend" @
- 103 "Legend" @
- 104 "North Arrow.narw" @
- 105 "Scale Bar.sclb" @
- 106 "Text %S.titl" @
- 107 "3-D Grid.gr3d" @
- 108 "Box" @
- 200 "Minimum: %S  Maximum: %S" @
- 201 "Minimum: %li  Maximum: %li" @
- 202 "Warning: a color map does not display" @
- 203 "with a palette based display driver" @
- 204 "Map has an invalid domain!" @
- 300 "No valid column" @
- 301 "Impossible Domain" @
- 302 "Internal Domain" @
- 303 "Select Color for '%S'" @
- 304 "Info" @
- 305 "Legend" @
- 306 "Attribute" @
- 400 "&Attribute" @
- 401 "&Info" @
- 402 "&Stretch" @
- 403 "&Representation" @
- 404 "&Color" @
- 405 "&Single Color" @
- 406 "&Multiple Colors" @
- 407 "&Light" @
- 408 "&Normal" @
- 409 "&Dark" @
- 410 "&Gray" @
- 411 "&Legend" @
- 412 "&Text" @
- 413 "&Font..." @
- 414 "Text &Color" @
- 415 "Line &Width" @
- 416 "&Line Color" @
- 417 "&Single Symbol" @
- 418 "Symbol &Type" @
- 419 "Symbol &Size" @
- 420 "&Boundaries Only" @
- 421 "Boundary &Color" @
- 422 "Boundary &Width" @
- 423 "&Size (pt)" @
- 424 "&Fast" @
- 425 "&Refresh Rate (/min)" @
- 426 "&Display Options" @
- 427 "&Linear" @
- 428 "Lo&garithmic" @
- 429 "&Radius" @
- 430 "&Area" @
- 431 "&Shortened Coordinates" @
- 432 "&Grid Lines" @
- 433 "Text at every" @
- 434 "Grid Line(s)" @
- 435 "Text &Angle" @
- 436 "Selectable Classes" @
- 437 "Selected Classes" @
- 438 "&Mask" @
- 439 "&Symbol..." @
- 440 "&True Color" @
- 441 "&False Color" @
- 442 "&Symbol" @
- 443 "Symbols &By Attributes" @
- 444 "&Details..." @
- 445 "&Class" @
- 446 "&Rotation" @
- 447 "Symbols as &Arrows" @
- 448 "&Length (mm)" @
- 449 "&Direction" @
- 450 "Symbols as &Graphs" @
- 451 "&Pie Chart" @
- 452 "&Bar Graph" @
- 453 "&Line Graph" @
- 454 "&Composed Bar" @
- 455 "&Volume Cubes" @
- 456 "&Height (mm)" @
- 457 "&Width (pt)" @
- 458 "&Axes Color" @
- 459 "&Line Type" @
- 460 "Line &Width (mm)" @
- 461 "&Color..." @
- 462 "&Font" @
- 463 "&Name" @
- 464 "&Code" @
- 465 "&Both" @
- 466 "&Description" @
- 467 "&Upward" @
- 468 "&Symbols" @
- 469 "&Ratio" @
- 470 "&Values" @
- 471 "&Size Legend" @
- 472 "&Color Legend" @
- 473 "&Scale Limits" @
- 474 "&Hide Superfluous Boundaries" @
- 475 "Red - &Green" @
- 476 "Red - &Blue" @
- 477 "&Left Range" @
- 478 "&Right Range" @
- 479 "Create Pyramid Layers" @
- 480 "&Pixel Shift" @
- 500 "Circle" @
- 501 "Square" @
- 502 "Diamond" @
- 503 "Delta Up" @
- 504 "Delta Down" @
- 505 "Plus" @
- 506 "Minus" @
- 507 "Cross" @
- 508 "Icon" @
- 509 "Icons" @
- 510 "Select Icon" @
- 600 "Show &Annotation" @
- 601 "&Show Graticule" @
- 602 "Graticule &Distance" @
- 603 "Grid &Distance" @
- 604 "&Coordinates" @
- 605 "&Inside map" @
- 606 "&Outside map" @
- 607 "&Parallel" @
- 608 "&All Sides" @
- 609 "Draw &Border" @
- 610 "&Number of Columns" @
- 611 "&Transparent" @
- 612 "Arrow Type:" @
- 613 "&Simple" @
- 614 "&Cross" @
- 615 "&Compass" @
- 616 "&Scale Bar" @
- 617 "&Blocked" @
- 618 "&Line" @
- 619 "&Precision" @
- 620 "&Text 1 : ..." @
- 621 "&Grid" @
- 622 "Raster &Drape" @
- 623 "&Pixel steps" @
- 624 "Line Style:" @
- 625 "&Solid" @
- 626 "&Dashed" @
- 627 "D&otted" @
- 628 "&Fill Color" @
- 629 "&Shape Type:" @
- 630 "&Rectangle" @
- 631 "R&ounded Rectangle" @
- 632 "Order of Classes is order in legend" @
- 633 "Interval &Length" @
- 634 "&Isotropic" @
- 635 "&1st interval divided into smaller parts" @
- 636 "&Nr of Intervals" @
- 637 "Drape &Map" @
- 700 "Representation not Editable" @
- 701 "Edit Representation" @
- 702 "Scale too small for grid drawing" @
- 800 "Error" @
- 801 "No Configuration Form" @
- 802 "No Legend possible for ID maps" @
- 803 "No Legend possible for this domain" @
- 804 "Map has no GeoReference" @
- 805 "No curvilinear Grids possible" @
- 806 "Georeference of Texture map and DTM are different" @
- 807 "Maximum number of classes in legend is 255." @
- 808 "Placeable Metafiles are not supportednConvert it to normal Metafile" @
- 809 "Not yet implemented" @
- 810 "Drawer Error" @
- 811 "Impossible action: Edit Domain" @
- 812 "Impossible action: Edit Representation" @
- 900 "&RGB" @
- 901 "&YMC" @
- 902 "&HSI" @
- 903 "&Red Band" @
- 904 "&Green Band" @
- 905 "&Blue Band" @
- 906 "&Yellow Band" @
- 907 "&Magenta Band" @
- 908 "&Cyan Band" @
- 909 "&Hue Band" @
- 910 "&Saturation Band" @
- 911 "&Intensity Band" @
main/logiciels/ilwis/drwforms.eng.1239898631.txt.gz · Dernière modification : (modification externe)
