Différences
Lien vers cette vue comparative
Les deux révisions précédentesRévision précédente
main:logiciels:ilwis:georef.eng [2009/04/16 16:17] – Page moved from main:geolibre:ilwis:georef.eng to main:logiciels:ilwis:georef.eng Robinmain:logiciels:ilwis:georef.eng [2026/11/08 23:33] (Version actuelle) – supprimée - modification externe (Date inconnue) 127.0.0.1
Ligne 1: Ligne 1:
-[[traduction_soft|Retour]]
-Contenu de georef.eng à traduire :
-    1 "Create GeoReference" @
-    2 "GeoReference Editor" @
-    3 "GeoReference Editor: %S" @
-    4 "Add Tie Point" @
-    5 "Customize GeoRefEditor" @
-    6 "Transformation" @
-    7 "Delete Tie Point" @
-    8 "Quality Information" @
-    9 "Tie Point Table" @
-   10 "Create GeoReference 3D" @
- 100 "Not a valid GeoReference name" @
- 101 "GeoReference already exists" @
- 102 "Pixel size too small" @
- 103 "%li lines and %li columns" @
- 104 "Minimum should be smaller than maximum" @
- 105 "Pixel Size = %.3f m" @
- 106 "Pixel Size = %.3f m, %.3f m" @
- 107 "Not enough points" @
- 108 "Singular Matrix" @
- 109 "Error" @
- 110 "Sigma = %6.3f pixels" @
- 111 "Add Tiepoint number %i" @
- 112 "Row and/or Col offset should be less than the Factor" @
- 113 "Factor should be larger than 1" @
- 114 "Pixel Size = %S" @
- 115 "Pixel Size = %S, %S" @
- 200 "GeoReference not editable" @
- 201 "GeoReference Editor" @
- 202 "Reference Map has other georeference" @
- 203 "DTM is not valid" @
- 204 "Photobase is too short" @
- 205 "Transferred PP undefined or at wrong side" @
- 206 "Scale point 1 too close to flight-line" @
- 207 "Scale point 2 too close to flight-line" @
- 400 "Transformation: " @
- 401 "Conformal" @
- 402 "Affine" @
- 403 "Second Order Bilinear" @
- 404 "Full Second Order" @
- 405 "Third Order" @
- 406 "Projective" @
- 407 "Linked GeoRef" @
- 408 "First Row, Col: %li, %li" @
- 409 "First Coordinate: (%.3lf, %.3lf)" @
- 410 "Opposite Coordinate: (%.3lf, %.3lf)" @
- 411 ", linked to %S" @
- 412 "Increased pixel size, factor =" @
- 413 "Decreased pixel size, factor =" @
- 500 "&GeoReference Name" @
- 501 "GeoRef &Corners" @
- 502 "GeoRef &Tiepoints" @
- 503 "GeoRef &3-D display" @
- 504 "&Coordinate System" @
- 505 "&Background Map" @
- 506 "&Rows, Columns" @
- 507 "&DTM" @
- 508 "&Pixel size" @
- 509 "&Min X, Y" @
- 510 "&Max X, Y" @
- 511 "&Center of Corner pixels" @
- 512 "Transformation:" @
- 513 "&Conformal" @
- 514 "&Affine" @
- 515 "&Second Order Bilinear" @
- 516 "&Full Second Order" @
- 517 "&Third Order" @
- 518 "&Projective" @
- 519 "&Row, Col" @
- 520 "&X, Y" @
- 521 "&Color" @
- 522 "GeoRef &Ortho Photo" @
- 523 "&Description:" @
- 524 "&Active Color" @
- 525 "&Passive Color" @
- 526 "Symbol &Size" @
- 527 "&Tiepoint number" @
- 528 "GeoRef &Direct Linear" @
- 529 "&Principal Distance (mm)" @
- 530 "&Fiducial Marks Color" @
- 531 "&Z" @
- 532 "a11= %lg,   a12= %lg" @
- 533 "a21= %lg,   a22= %lg" @
- 534 "b1= %lg,   b2= %lg" @
- 535 "Edit Root GeoRef" @
- 536 "Edit &Linked GeoRef" @
- 537 "&Increase" @
- 538 "Dec&rease" @
- 539 "&Factor" @
- 540 "&Offset Row, Col" @
- 541 "&First Row, Col" @
- 542 "&Size Row, Col" @
- 543 "&Pixel size in Degrees" @
- 544 "&Lat, Lon" @
- 545 "&Medium Error" @
- 546 "&Large Error" @
- 547 "GeoRef &Parallel Projective" @
- 548 "&Principal Point (mm,mm)" @
- 549 "Allow 8 Fiducials" @
- 600 "Delete selected tiepoints" @
- 601 "Delete tiepoints" @
