- Vous êtes ici : Accéder au Wiki GeoRezo » Accueil : Wiki GeoRezo » Les logiciels en géomatique » Ilwis » table.eng
Différences
| Les deux révisions précédentesRévision précédente | |||
| main:logiciels:ilwis:table.eng [2009/04/16 16:22] – Page moved from main:geolibre:ilwis:table.eng to main:logiciels:ilwis:table.eng Robin | main:logiciels:ilwis:table.eng [2026/11/02 17:12] (Version actuelle) – supprimée - modification externe (Date inconnue) 127.0.0.1 | ||
| Ligne 1: | Ligne 1: | ||
| - | [[traduction_soft|Retour]] | ||
| - | Contenu de table.eng à traduire : | ||
| - | 1 " | ||
| - | 2 " | ||
| - | 3 "Break Dependency Link" @ | ||
| - | 4 "Goto Record" | ||
| - | 5 "Goto Column" | ||
| - | 6 "Add Column" | ||
| - | 7 " | ||
| - | 8 "Join Column" | ||
| - | 9 " | ||
| - | 10 " | ||
| - | 11 " | ||
| - | 12 " | ||
| - | 13 "Least Squares Fit" @ | ||
| - | 14 " | ||
| - | 15 " | ||
| - | 16 "Print Table" @ | ||
| - | 17 " | ||
| - | 18 " | ||
| - | 19 " | ||
| - | 20 " | ||
| - | 21 "Print Options" | ||
| - | 22 "Edit selected field(s)" | ||
| - | 23 " | ||
| - | 24 " | ||
| - | 25 " | ||
| - | 26 " | ||
| - | 27 " | ||
| - | 28 "Find 7 Datum Parameters" | ||
| - | 29 "Not a valid table name" @ | ||
| - | 30 "Table already exists" | ||
| - | 31 " | ||
| - | 32 " | ||
| - | 33 " | ||
| - | 34 "Add new column" | ||
| - | 35 "Show record %S in record view" @ | ||
| - | 36 "Edit field %S" @ | ||
| - | 37 " | ||
| - | 38 " | ||
| - | 39 " | ||
| - | 40 " | ||
| - | 41 "Drag objects to change order" @ | ||
| - | 42 "Table is read only" @ | ||
| - | 43 " | ||
| - | 44 "Edit Field" @ | ||
| - | 45 "Field is read only" @ | ||
| - | 46 " | ||
| - | 47 " | ||
| - | 48 " | ||
| - | 49 "Edit record %S" @ | ||
| - | 50 "until record %S" @ | ||
| - | 51 " | ||
| - | 52 " | ||
| - | 53 " | ||
| - | 54 " | ||
| - | 55 "Sum of values in column" | ||
| - | 56 "Open Column Management dialog box" @ | ||
| - | 100 " | ||
| - | 101 "Copy error" @ | ||
| - | 102 "Table Error" @ | ||
| - | 103 " | ||
| - | 104 " | ||
| - | 105 " | ||
| - | 106 "Table is read-only" | ||
| - | 107 "Add records only possible for tables with domain ' | ||
| - | 108 "Could not create column (not enough memory)" | ||
| - | 109 "Could not create column: %S" @ | ||
| - | 110 " | ||
| - | 111 "Error opening table %S: Number of records must be positiv" | ||
| - | 112 "Error opening table %S: Number of columns must be positiv" | ||
| - | 113 " | ||
| - | 200 " | ||
| - | 201 "Value Range" @ | ||
| - | 202 " | ||
| - | 203 " | ||
| - | 204 " | ||
| - | 205 " | ||
| - | 206 " | ||
| - | 207 " | ||
| - | 208 " | ||
| - | 209 " | ||
| - | 210 " | ||
| - | 211 " | ||
| - | 212 " | ||
| - | 213 " | ||
| - | 214 " | ||
| - | 215 " | ||
| - | 216 " | ||
| - | 300 "Break Dependency LinknAre you sure?" @ | ||
| - | 301 " | ||
| - | 302 " | ||
| - | 303 " | ||
| - | 304 " | ||
| - | 305 "Clear Fields" | ||
| - | 306 "Clear selected fields" | ||
| - | 307 "%S is not in the domain %SnAdd this item to the domain?" | ||
| - | 308 " | ||
| - | 309 "%S is not a valid value" @ | ||
| - | 310 "Print at %s on %s" @ | ||
| - | 311 " | ||
| - | 312 "Xc = %7.3f, Yc = %7.3f, Zc = %7.3f" @ | ||
| - | 313 "3-D Cartesian Coordinates in WGS84 system using %i points" | ||
| - | 314 " | ||
| - | 400 "& | ||
| - | 401 "& | ||
| - | 402 "& | ||
| - | 403 "& | ||
| - | 404 "& | ||
| - | 405 "& | ||
| - | 406 " | ||
| - | 407 "Value & | ||
| - | 408 "& | ||
| - | 409 "& | ||
| - | 410 "& | ||
| - | 411 "& | ||
| - | 412 "& | ||
| - | 413 "& | ||
| - | 414 "& | ||
| - | 415 "& | ||
| - | 416 "& | ||
| - | 417 "& | ||
| - | 418 "& | ||
| - | 419 "& | ||
| - | 420 "& | ||
| - | 421 "& | ||
| - | 422 "& | ||
| - | 423 "& | ||
| - | 424 "& | ||
| - | 425 " | ||
| - | 426 "& | ||
| - | 427 "& | ||
| - | 428 "& | ||
| - | 429 "& | ||
| - | 430 "& | ||
| - | 431 "& | ||
| - | 432 "& | ||
| - | 433 "& | ||
| - | 434 "& | ||
| - | 435 "& | ||
| - | 436 "& | ||
| - | 437 "& | ||
| - | 438 " | ||
| - | 439 " | ||
| - | 440 "& | ||
| - | 441 "& | ||
| - | 442 " | ||
| - | 443 "& | ||
| - | 444 "Print records by record number" | ||
| - | 445 "& | ||
| - | 446 "& | ||
| - | 447 "& | ||
| - | 448 "& | ||
| - | 449 "& | ||
| - | 450 "& | ||
| - | 451 "& | ||
| - | 452 "Sort & | ||
| - | 453 "& | ||
| - | 454 "& | ||
| - | 455 " | ||
| - | 456 "& | ||
| - | 457 "& | ||
| - | 458 "First Coords" | ||
| - | 459 " | ||
| - | 460 "First Heights" | ||
| - | 461 " | ||
| - | 462 " | ||
| - | 463 " | ||
| - | 464 "Local Centroid of Points" | ||
| - | 465 "3-D Cartesian Coordinates in WGS84 system" | ||
| - | 466 "Xo =" @ | ||
| - | 467 "Yo =" @ | ||
| - | 468 " | ||
| - | 469 "Xc =" @ | ||
| - | 470 "Yc =" @ | ||
| - | 471 "Zc =" @ | ||
| - | 472 " | ||
| - | 473 " | ||
| - | 500 " | ||
| - | 501 "Std Deviation.fun" | ||
| - | 502 " | ||
| - | 503 " | ||
| - | 504 " | ||
| - | 505 " | ||
| - | 506 " | ||
| - | 507 " | ||
| - | 508 " | ||
| - | 509 " | ||
| - | 510 "Power Law.fun" | ||
| - | 511 " | ||
| - | 512 " | ||
| - | 513 " | ||
| - | 514 " | ||
| - | 515 " | ||
| - | 516 " | ||
| - | 517 "Std Deviation.fun" | ||
| - | 518 "t test.fun" | ||
| - | 519 "Std Error.fun" | ||
| - | 520 "chi square.fun" | ||
| - | 521 " | ||
| - | 522 " | ||
| - | 523 " | ||
| - | 524 " | ||
| - | 525 " | ||
| - | 600 "& | ||
| - | 601 "& | ||
| - | 602 " | ||
| - | 700 "' | ||
| - | 701 " | ||
| - | 800 " | ||
| - | 801 " | ||
| - | 802 " | ||
| - | 803 "Wave Model" @ | ||
| - | 804 " | ||
| - | 805 "Power Model" @ | ||
| - | 806 " | ||
| - | 807 "& | ||
| - | 808 "& | ||
| - | 809 "& | ||
| - | 810 "& | ||
| - | 811 "& | ||
| - | 812 " | ||
| - | 813 " | ||
| - | 814 " | ||
| - | 815 " | ||
| - | 900 "& | ||
| - | 901 "& | ||
| - | 902 "& | ||
| - | 903 "& | ||
| - | 904 "& | ||
