#1 Tue 22 August 2017 10:33
- SIG CDAPP
- Lieu: pau
[mapserver] image vide ?
je suis en train de monter un projet avec du leaflet et mapserver sur une base postgis.
je travaille en cc43.
voici mon code leaflet, je pense qu'il est bon :
Test Leaflet
var crs3943 = new L.Proj.CRS('EPSG:3943',
"+proj=lcc +lat_1=42.25 +lat_2=43.75+lat_0=43 +lon_0=3 +k=1 +x_0=1400000 +y_0=220000 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units= +no_defs",
resolutions: [
8192, 4096, 2048, 1024, 512, 256, 128,
64, 32, 16, 8, 4, 2, 1, 0.5
var mymap = L.map('mapid',{
//crs: crs3943,
maxZoom: 14,
minZoom: 0,
mymap.setView([14.8, 22.3], 3);
L.marker([14.789, 21.456]).addTo(mymap);
var basemaps= {
equipement : L.tileLayer.wms('https://localhost/cgi-bin/mapserv?map=/home/mbussenot/mapfiles/test.map', {
layers: 'equipements_structurants',
format: 'image/png',
crs: crs3943
L.control.layers(basemaps).addTo(mymap);Puis voici mon mapfile il ne renvoie pas d'erreur mais les images sont vides:
MAP
EXTENT 1421060 2227618 1429195 2233037
IMAGETYPE "png"
MAXSIZE 2000
NAME "test"
RESOLUTION 96
SHAPEPATH ""
SIZE 600 400
STATUS ON
TRANSPARENT TRUE
UNITS METERS
OUTPUTFORMAT
NAME "png"
MIMETYPE "image/png"
DRIVER "AGG/PNG"
EXTENSION "png"
IMAGEMODE RGBA
TRANSPARENT TRUE
END # OUTPUTFORMAT
PROJECTION
"init=epsg:3943"
END #
WEB
METADATA
"ows_title" "test"
"ows_onlineresource" "http:/localhost/cgi-bin/mapserv?map=test.map"
"ows_enable_request" "*"
"ows_srs" "EPSG:3943"
"ows_feature_info_mime_type" "text/html"
"ows_format" "image/png"
"extent" "1421060 2227618 1429195 2233037"
END
END
LAYER
CONNECTION "host=192.168.1.5 port=5432 dbname=***** user=postgres password=******"
CONNECTIONTYPE POSTGIS
DATA "the_geom FROM (SELECT * FROM bd_equipements.equipements_structurants) as foo USING UNIQUE objectid USING SRID=3943"
METADATA
"OWS_INCLUDE_ITEMS" "all"
"OWS_ENABLE_REQUEST" "*"
"GML_FEATUREID" "objectid"
"GML_the_geom_TYPE" "point"
"OWS_TITLE" "equipements_structurants"
"GML_INCLUDE_ITEMS" "all"
"GML_GEOMETRIES" "the_geom"
"EXTENT" "1421060 2227618 1429195 2233037"
END # METADATA
NAME "equipements_structurants"
PROJECTION
"init=epsg:3943"
END # PROJECTION
STATUS ON
TILEITEM "location"
TYPE POINT
UNITS METERS
CLASS
NAME "default"
MAXSCALEDENOM 161600
MINSCALEDENOM 312
STYLE
COLOR 100 100 0
END # STYLE
STYLE
OUTLINECOLOR 0 0 0
END # STYLE
TITLE "default"
END # CLASS
END # LAYER
END # MAPLes images renvoyées n'ont pas la bonne extent, je n'arrive à savoir pourquoi.
Merci pour votre aide, Marion
#2 Tue 22 August 2017 10:42
- chanteclair
- Lieu: Pau
Re: [mapserver] image vide ?
Avez-vous essayer d'ajouter un "WMS_SRS" epsg:4326 dans les METADATA de votre section WEB ?
#3 Tue 22 August 2017 11:07
- SIG CDAPP
- Lieu: pau
En testant, j'ai msWMSLoadGetMapParams(): WMS server error. Invalid values for BBOX.
avec des coordonnées qui ne sont toujours pas en cc43..
Marion
#4 Tue 22 August 2017 11:41
- chanteclair
- Lieu: Pau
Une chose me parait bizarre dans votre ficher map est que vous demandez de fournir un flux wfs (ou ows) et que vous semblez ensuite passer une url appelant un flux WMS (votre erreur).
#5 Tue 22 August 2017 14:25
- SIG CDAPP
- Lieu: pau
Vous pensez que je dois remplacer les ows_ par wms_ ?
#6 Tue 22 August 2017 14:37
- chanteclair
- Lieu: Pau
Cela me semblerait plus cohérent, mais sans garantie que cela résolve votre blocage.
#7 Tue 22 August 2017 15:41
- SIG CDAPP
- Lieu: pau
Bon, ça ne change rien.
voic la bbox que j'optiens bbox=3407872.0000000224,-3145728.0000001015,3670016.000000023,-2883584.000000109
Qui ne correspond en rien au bbox en cc43.
MAP
IMAGETYPE "png"
MAXSIZE 2000
NAME "test"
RESOLUTION 96
SHAPEPATH ""
SIZE 600 400
STATUS ON
TRANSPARENT TRUE
UNITS METERS
OUTPUTFORMAT
NAME "png"
DRIVER "AGG/PNG"
EXTENSION "png"
IMAGEMODE RGBA
TRANSPARENT TRUE
END # OUTPUTFORMAT
PROJECTION
"init=epsg:3943"
END #
WEB
METADATA
"wms_title" "test"
"wms_onlineresource" "http://leaflet-test.agglo-pau.fr/cgi-bin/mapserv?map=test.map"
"wms_enable_request" "*"
"wms_srs" "EPSG:3943 EPSG:4326"
"wms_feature_info_mime_type" "text/html"
"wms_format" "image/png"
"wms_extent" "1421060 2227618 1429195 2233037"
END
END
LAYER
CONNECTION "host=192.168.1.5 port=5432 dbname=sigcapp user=postgres password=super_postgres"
METADATA
"WMS_INCLUDE_ITEMS" "all"
"WMS_ENABLE_REQUEST" "*"
"WMS_TITLE" "equipements_structurants"
"WMS_EXTENT" "1421060 2227618 1429195 2233037"
END # METADATA
PROJECTION
"init=epsg:3943"
END # PROJECTION
STATUS ON
TILEITEM "location"
TYPE POINT
UNITS METERS
CLASS
NAME "default"
MINSCALEDENOM 312
STYLE
COLOR 100 100 0
END # STYLE
STYLE
OUTLINECOLOR 0 0 0
END # STYLE
TITLE "default"
END # CLASS
END # LAYER
END # MAPHors ligne
#8 Tue 22 August 2017 16:16
- chanteclair
- Lieu: Pau
J'ai fait quelques simplifications (que vous pourrez rajouter ensuite).
Pourriez-vous voir ce que cela donne ?
MAP
IMAGETYPE PNG8
IMAGECOLOR 255 255 255
SIZE 600 400
PROJECTION
"init=epsg:3943"
END
NAME "test"
STATUS ON
WEB
METADATA
"wms_title" "test"
END
END
LAYER
TYPE POINT
STATUS ON
DATA "the_geom FROM (SELECT * FROM bd_equipements.equipements_structurants) USING UNIQUE objectid"
CLASS
NAME "default"
MINSCALEDENOM 312
STYLE
COLOR 100 100 0
OUTLINECOLOR 0 0 0
END # STYLE
END # CLASS
METADATA
END # METADATA
PROJECTION
"init=epsg:3943"
END # PROJECTION
END # LAYER
END # MAPHors ligne
#9 Tue 22 August 2017 16:38
- SIG CDAPP
- Lieu: pau
c'est mieux j'ai des dalles blanches... mais toujours pas des points.
#10 Tue 22 August 2017 16:44
- chanteclair
- Lieu: Pau
Je n'avais pas fait attention lors du post précédent, essayez dans un 1er temps de supprimer le SELECT * FROM dans le DATA de votre layer.
A quoi correspond le bd_equipements devant le nom de la couche ? Au schéma PostgreSQL ?
#11 Tue 22 August 2017 17:18
- SIG CDAPP
- Lieu: pau
Oui c'est le schéma PostgreSQL .
#12 Wed 23 August 2017 08:25
- chanteclair
- Lieu: Pau
Toujours des dalles blanches en testant l'adresse ? : http://leaflet-test.agglo-pau.fr/cgi-bi … p=test.map
Il faudrait aussi rajouter dans la section STYLE de votre couche :
SIZE 5
et éventuellement
SYMBOL 'circle' par exemple.
Dernière modification par chanteclair (Wed 23 August 2017 09:03)
#13 Wed 23 August 2017 12:32
- SIG CDAPP
- Lieu: pau
merci pour votre aide, les dalles sont toujours blanches, meme avec les symbol et size
je pense que les emprises ne sont pas bonnes car les bbox ne correspondent pas au CC43.
&bbox=3670016.000000025,-3145728.0000000997,3932160.0000000247,-2883584.000000109
je ne comprends pas pourquoi. il y a ces coordonnées.
#14 Wed 23 August 2017 13:41
- chanteclair
- Lieu: Pau
A priori votre fichier map semble bon.
Je n'ai pas l'impression que votre problème vienne de là, à moins qu'un paramètre m'échappe.
Par contre je ne peux pas vous aider sur Leaflet.
#15 Wed 23 August 2017 16:46
- SIG CDAPP
- Lieu: pau
Le problème vient de mapserver car les images sont vides.
#16 Thu 24 August 2017 08:51
- chanteclair
- Lieu: Pau
Une image blanche ne veut pas dire vide.
Essayez ceci dans votre layer (à la place de votre code actuel) :
LAYER
CONNECTION "host=localhost port=5432 dbname=**** user=postgres password=****"
DATA "the_geom FROM bd_equipements.equipements_structurants" ####Etes-vous sûr ici que votre champ de géométrie se nomme the_geom ?
TYPE POINT
STATUS DEFAULT
CLASS
STYLE
COLOR 0 58 250
OUTLINECOLOR 255 255 255
SYMBOL 'circle'
SIZE 20
END
END #class
PROJECTION
"init=epsg:3943"
END # PROJECTION
END # LAYEREt ajoutez dans la section MAP
SYMBOLSET "../symbols/symbols.sym" ## pour faire référence au fichier de Symboles qui doit exister par défaut
Ensuite tester l'URL :
http://localhost:MonPort/cgi-bin/mapserv.exe?map="Chemin d'accès à mon fichier map".map&mode=map
Dernière modification par chanteclair (Thu 24 August 2017 08:56)
