#1 Tue 22 August 2017 10:33
SIG CDAPP
Lieu: pau
[mapserver] image vide ?
je suis en train de monter un projet avec du leaflet et mapserver sur une base postgis.
je travaille en cc43.
voici mon code leaflet, je pense qu'il est bon :
Test Leaflet
    var crs3943 = new L.Proj.CRS('EPSG:3943',
              "+proj=lcc +lat_1=42.25 +lat_2=43.75+lat_0=43 +lon_0=3 +k=1 +x_0=1400000 +y_0=220000 +ellps=GRS80  +towgs84=0,0,0,0,0,0,0 +units= +no_defs",
        resolutions: [
            8192, 4096, 2048, 1024, 512, 256, 128,
            64, 32, 16, 8, 4, 2, 1, 0.5
    var mymap = L.map('mapid',{
    //crs: crs3943,
    maxZoom: 14,
    minZoom: 0,
    mymap.setView([14.8, 22.3], 3);
    L.marker([14.789, 21.456]).addTo(mymap);
    var basemaps= {
    equipement :  L.tileLayer.wms('https://localhost/cgi-bin/mapserv?map=/home/mbussenot/mapfiles/test.map', {
    layers: 'equipements_structurants',
    format: 'image/png',
    crs: crs3943
    L.control.layers(basemaps).addTo(mymap);
Puis voici mon mapfile il ne renvoie pas d'erreur mais les images sont vides:
MAP
  EXTENT 1421060 2227618 1429195 2233037
   IMAGETYPE "png"
  MAXSIZE 2000
  NAME "test"
  RESOLUTION 96
  SHAPEPATH ""
  SIZE 600 400
  STATUS ON
  TRANSPARENT TRUE
  UNITS METERS
  OUTPUTFORMAT
    NAME "png"
    MIMETYPE "image/png"
    DRIVER "AGG/PNG"
    EXTENSION "png"
    IMAGEMODE RGBA
    TRANSPARENT TRUE
  END # OUTPUTFORMAT
  PROJECTION
    "init=epsg:3943"
  END #
WEB
  METADATA
    "ows_title" "test"
    "ows_onlineresource" "http:/localhost/cgi-bin/mapserv?map=test.map"
    "ows_enable_request" "*"
    "ows_srs" "EPSG:3943"
    "ows_feature_info_mime_type" "text/html"
    "ows_format" "image/png"
    "extent" "1421060 2227618 1429195 2233037"
  END
END
  LAYER
    CONNECTION "host=192.168.1.5 port=5432 dbname=*****  user=postgres password=******"
    CONNECTIONTYPE POSTGIS
    DATA "the_geom FROM (SELECT * FROM bd_equipements.equipements_structurants) as foo  USING UNIQUE objectid USING SRID=3943"
     METADATA
      "OWS_INCLUDE_ITEMS"    "all"
      "OWS_ENABLE_REQUEST" "*"
      "GML_FEATUREID"    "objectid"
      "GML_the_geom_TYPE"    "point"
      "OWS_TITLE"    "equipements_structurants"
      "GML_INCLUDE_ITEMS"    "all"
      "GML_GEOMETRIES"    "the_geom"
      "EXTENT" "1421060 2227618 1429195 2233037"
    END # METADATA
    NAME "equipements_structurants"
    PROJECTION
      "init=epsg:3943"
    END # PROJECTION
    STATUS ON
       TILEITEM "location"
    TYPE POINT
    UNITS METERS
    CLASS
      NAME "default"
      MAXSCALEDENOM 161600
      MINSCALEDENOM 312
      STYLE
        COLOR 100 100 0
      END # STYLE
      STYLE
        OUTLINECOLOR 0 0 0
      END # STYLE
      TITLE "default"
    END # CLASS
  END # LAYER
END # MAP
Les images renvoyées n'ont pas la bonne extent, je n'arrive à savoir pourquoi.
Merci pour votre aide, Marion
#2 Tue 22 August 2017 10:42
chanteclair
Lieu: Pau
Re: [mapserver] image vide ?
Avez-vous essayer d'ajouter un "WMS_SRS" epsg:4326 dans les METADATA de votre section WEB ?
#3 Tue 22 August 2017 11:07
SIG CDAPP
Lieu: pau
En testant, j'ai msWMSLoadGetMapParams(): WMS server error. Invalid values for BBOX.
avec des coordonnées qui ne sont toujours pas en cc43..
Marion
#4 Tue 22 August 2017 11:41
chanteclair
Lieu: Pau
Une chose me parait bizarre dans votre ficher map est que vous demandez de fournir un flux wfs (ou ows) et que vous semblez ensuite passer une url appelant un flux WMS (votre erreur).
#5 Tue 22 August 2017 14:25
SIG CDAPP
Lieu: pau
Vous pensez que je dois remplacer les ows_ par wms_ ?
#6 Tue 22 August 2017 14:37
chanteclair
Lieu: Pau
Cela me semblerait plus cohérent, mais sans garantie que cela résolve votre blocage.
#7 Tue 22 August 2017 15:41
SIG CDAPP
Lieu: pau
Bon, ça ne change rien.
voic la bbox que j'optiens bbox=3407872.0000000224,-3145728.0000001015,3670016.000000023,-2883584.000000109
Qui ne correspond en rien au bbox en cc43.
MAP
   IMAGETYPE "png"
  MAXSIZE 2000
  NAME "test"
  RESOLUTION 96
  SHAPEPATH ""
  SIZE 600 400
  STATUS ON
  TRANSPARENT TRUE
  UNITS METERS
  OUTPUTFORMAT
    NAME "png"
    DRIVER "AGG/PNG"
    EXTENSION "png"
    IMAGEMODE RGBA
    TRANSPARENT TRUE
  END # OUTPUTFORMAT
  PROJECTION
    "init=epsg:3943"
  END #
WEB
  METADATA
    "wms_title" "test"
    "wms_onlineresource" "http://leaflet-test.agglo-pau.fr/cgi-bin/mapserv?map=test.map"
    "wms_enable_request" "*"
    "wms_srs" "EPSG:3943 EPSG:4326"
    "wms_feature_info_mime_type" "text/html"
    "wms_format" "image/png"
    "wms_extent" "1421060 2227618 1429195 2233037"
  END
END
  LAYER
    CONNECTION "host=192.168.1.5 port=5432 dbname=sigcapp  user=postgres password=super_postgres"
     METADATA
      "WMS_INCLUDE_ITEMS"    "all"
      "WMS_ENABLE_REQUEST" "*"
      "WMS_TITLE"    "equipements_structurants"
      "WMS_EXTENT" "1421060 2227618 1429195 2233037"
    END # METADATA
    PROJECTION
      "init=epsg:3943"
    END # PROJECTION
    STATUS ON
       TILEITEM "location"
    TYPE POINT
    UNITS METERS
    CLASS
      NAME "default"
      MINSCALEDENOM 312
      STYLE
        COLOR 100 100 0
      END # STYLE
      STYLE
        OUTLINECOLOR 0 0 0
      END # STYLE
      TITLE "default"
    END # CLASS
  END # LAYER
END # MAP
#8 Tue 22 August 2017 16:16
chanteclair
Lieu: Pau
J'ai fait quelques simplifications (que vous pourrez rajouter ensuite).
Pourriez-vous voir ce que cela donne ?
MAP
  IMAGETYPE PNG8
  IMAGECOLOR 255 255 255
  SIZE 600 400
  PROJECTION
    "init=epsg:3943"
  END
  NAME "test"
  STATUS ON
    WEB
        METADATA
        "wms_title" "test"
        END
    END
  LAYER
    TYPE POINT
    STATUS ON
    DATA "the_geom FROM (SELECT * FROM bd_equipements.equipements_structurants) USING UNIQUE objectid"
    CLASS
        NAME "default"
        MINSCALEDENOM 312
            STYLE
                COLOR 100 100 0
                OUTLINECOLOR 0 0 0
            END # STYLE
    END # CLASS
    METADATA
    END # METADATA
    PROJECTION
      "init=epsg:3943"
    END # PROJECTION
  END # LAYER
END # MAP
#9 Tue 22 August 2017 16:38
SIG CDAPP
Lieu: pau
c'est mieux j'ai des dalles blanches... mais toujours pas des points.
#10 Tue 22 August 2017 16:44
chanteclair
Lieu: Pau
Je n'avais pas fait attention lors du post précédent, essayez dans un 1er temps de supprimer le SELECT * FROM dans le DATA de votre layer.
A quoi correspond le bd_equipements devant le nom de la couche ? Au schéma PostgreSQL ?
#11 Tue 22 August 2017 17:18
SIG CDAPP
Lieu: pau
Oui c'est le schéma PostgreSQL .
#12 Wed 23 August 2017 08:25
chanteclair
Lieu: Pau
Toujours des dalles blanches en testant l'adresse ? : http://leaflet-test.agglo-pau.fr/cgi-bi … p=test.map
Il faudrait aussi rajouter dans la section STYLE de votre couche :
SIZE 5
et éventuellement
SYMBOL 'circle' par exemple.
Dernière modification par chanteclair (Wed 23 August 2017 09:03)
#13 Wed 23 August 2017 12:32
SIG CDAPP
Lieu: pau
merci pour votre aide, les dalles sont toujours blanches, meme avec les symbol et size
je pense que les emprises ne sont pas bonnes car les bbox ne correspondent pas au CC43.
&bbox=3670016.000000025,-3145728.0000000997,3932160.0000000247,-2883584.000000109
je ne comprends pas pourquoi. il y a ces coordonnées.
#14 Wed 23 August 2017 13:41
chanteclair
Lieu: Pau
A priori votre fichier map semble bon.
Je n'ai pas l'impression que votre problème vienne de là, à moins qu'un paramètre m'échappe.
Par contre je ne peux pas vous aider sur Leaflet.
#15 Wed 23 August 2017 16:46
SIG CDAPP
Lieu: pau
Le problème vient de mapserver car les images sont vides.
#16 Thu 24 August 2017 08:51
chanteclair
Lieu: Pau
Une image blanche ne veut pas dire vide.
Essayez ceci dans votre layer (à la place de votre code actuel) :
LAYER
    CONNECTION "host=localhost port=5432 dbname=**** user=postgres password=****"
    DATA "the_geom FROM bd_equipements.equipements_structurants" ####Etes-vous sûr ici que votre champ de géométrie se nomme the_geom ?
    TYPE POINT
    STATUS DEFAULT
        CLASS
                STYLE
                    COLOR 0 58 250
                    OUTLINECOLOR 255 255 255
                    SYMBOL 'circle'
                    SIZE 20
                END
         END #class
    PROJECTION
      "init=epsg:3943"
    END # PROJECTION
  END # LAYER
Et ajoutez dans la section MAP
  SYMBOLSET   "../symbols/symbols.sym" ## pour faire référence au fichier de Symboles qui doit exister par défaut
Ensuite tester l'URL :
http://localhost:MonPort/cgi-bin/mapserv.exe?map="Chemin d'accès à mon fichier map".map&mode=map
Dernière modification par chanteclair (Thu 24 August 2017 08:56)
