#1 Tue 11 June 2013 16:15
- Sylvain PIERRE
- Lieu: Strasbourg
[OpenJump] Impossible de lancer Openjump 1.6
Je n'arrive pas à lancer OpenJump sous 7:
C:\Users\sylvain.pierre>"C:\Program Files\OpenJUMP-1.6.3-r3576-CORE\bin\oj_windo ws.bat" Using 'java' found in 'C:\Program Files\Java\jre6\bin\' java version "1.6.0_18"; Java(TM) SE Runtime Environment (build 1.6.0_18-b07); J ava HotSpot(TM) Client VM (build 20.6-b01 mixed mode) ---PATH--- lib\native\seven;lib\native\seven;lib\native;lib\ext;C:\Perl\site\bin;C:\Perl\bi n;C:\app\product\11.2.0\client_1\bin;C:\ORA102\bin;C:\Windows\system32;C:\Window s;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Progra m Files\Toshiba\Bluetooth Toshiba Stack\sys\;C:\Program Files\QuickTime\QTSystem \;C:\Program Files\FWTools2.4.7\;c:\Program Files\Microsoft SQL Server\100\Tools \Binn\;c:\Program Files\Microsoft SQL Server\100\DTS\Binn\;c:\Program Files\Micr osoft SQL Server\100\Tools\Binn\VSShell\Common7\IDE\;C:\Program Files\openModell er 1.2.0;C:\Program Files\Graphviz 2.28\bin;C:\Program Files\Microsoft SQL Serve r Migration Assistant for Access\bin\;C:\Program Files\Quantum GIS Lisboa\bin;C: \Program Files\Quantum GIS Lisboa\apps\qgis\bin;C:\Program Files\PostgreSQL\8.3\ bin;C:\Program Files\PostgreSQL\8.3\lib;C:\Users\sylvain.pierre\Documents\R\R-2. 15.2\bin;C:\Program Files\Java\jre6\bin;C:\Program Files\R\R-2.15.2\bin\i386;C:\ Users\sylvain.pierre\Documents\R\win-library\2.15\deldir\libs\i386;C:\apps\FME\ ---CLASSPATH--- .;bin;conf;lib\bsh-2.0b4.jar;lib\buoy-1.8.jar;lib\jai_codec-1.1.2_01.jar;lib\jai _core-1.1.2_01.jar;lib\jama-1.0.2.jar;lib\jdom-1.1.3.jar;lib\jmatharray-20070905 .jar;lib\jmathplot-20070905.jar;lib\jts-1.13.jar;lib\jython-2.2.jar;lib\log4j-1. 2.16.jar;lib\OpenJUMP-1.6.3-r3576-nosrc.jar;lib\postgresql-9.2-1002.jdbc4.jar;li b\xercesImpl-2.8.1.jar;lib\xml-apis-1.3.03.jar;lib\xmlParserAPIs-2.0.2.jar ---Save logs & state to--- C:\Users\sylvain.pierre\.openjump ---Detect maximum memory limit--- set Xmx to 1024M (32 bit jre maximum) ---Start OJ--- Exception in thread "main" java.lang.NoSuchMethodError: disposeLater at java.awt.Component.initIDs(Native Method) at java.awt.Component.<clinit>(Unknown Source) at javax.swing.ImageIcon.<clinit>(Unknown Source) at com.vividsolutions.jump.workbench.ui.images.IconLoader.icon(IconLoade r.java:44) at com.vividsolutions.jump.workbench.JUMPWorkbench.<clinit>(JUMPWorkbenc h.java:122) Could not find the main class: com.vividsolutions.jump.workbench.JUMPWorkbench. Program will exit.
Ce serait vraiment super si qqun me sortait de là!
#2 Wed 12 June 2013 09:13
- mmichaud
Re: [OpenJump] Impossible de lancer Openjump 1.6
Quelques explications possibles sur ce bug que je vois pour la première fois.
L'erreur se produit au démarrage de l'application, lorsqu'elle essaye de lire l'icone d'OpenJUMP.
Je pense que l'icône est bien présente mais qu'il y a un conflit de version au niveau de java (une méthode - disposeLater - est attendue mais pas trouvée).
Vous semblez pourtant utiliser une version valide de java (1.6.0_18). Peut-être qu'une désinstallation / réinstallation de la JRE permettrait au système de retrouver ses marques.
Il serait également intéressant de vérifier si ce problème est propre au démarrage d'OpenJUMP où s'il affecte d'autres programmes java.
Michaël
#3 Wed 12 June 2013 22:55
- Thomas Gratier
- Invité
A priori, vous utilisez une Jre 64 bits. Comme OpenJump est en 32 bits,
Java vous alloue trop de mémoire et OpenJ UMP plante. Installez une Jre 32
bits et ça devrait marcher.
Thomas
#4 Thu 13 June 2013 00:50
- mmichaud
En l'absence de précision, je pense plutôt que le JRE utilisé est 32 bits.
En tous cas, OpenJUMP n'est pas une appli 32 bits. Comme tous les programmes java,
OpenJUMP est portable et peut être exécuté par une JVM 32 bits ou 64 bits, suivant ce
qui est disponible sur le système.
En regardant d'un peu plus près l'origine du message, j'ai vu que c'est au moment de
charger des ressources système que le problème se produit.
La seule référence à ce problème que j'ai trouvé sur internet suggère également de
procéder à une ré-installation de l'environnement java.
https://www.tibcommunity.com/thread/22058
Michaël
#5 Thu 13 June 2013 08:41
- Sylvain PIERRE
- Lieu: Strasbourg
Merci pour vos réponses,
J'avais dans un premier temps cherché sur le Web, mais RAS.
Je vais désinstaller et réinstaller java.
64 bits, ça me parait bizarre quand même...
Je vous tiens au courant.
J'avais installé il y a qq années Jump et les premières versions d'OpenJump, et ça marchait plutôt bien.
Je retentais l'expérience pour tester les outils de conflation et les connexions Oracle et Postgis.
#6 Thu 13 June 2013 09:41
- Sylvain PIERRE
- Lieu: Strasbourg
That's it!
