#1 Tue 24 April 2007 14:46
- Mobilotek
- Lieu: Toulouse
[Mapserver]WMS->probleme d'acces à un serveur "maison"
j'enrage depuis quelques jours, car je ne trouve pas l'erreur,
J'ai un mapfile servant de serveur. Quand je l'appel dans Arcview, pas de pb, ça tourne,
Mais quand je l'appel avec dans un mapfile, ça coince.
Voici les extraits des fichiers:
Mapfile serveur
MAP
NAME Test_serveur
EXTENT 259966 1599000 678359 1900000
SIZE 450 450
IMAGETYPE jpeg
WEB
METADATA
"wms_title" "WMS_APEM"
"wms_onlineresource" "http://192.168.1.14/wms?"
"wms_srs" "EPSG:27572 EPSG:27582"
"WMS_FEATURE_INFO_MIME_TYPE" "text/html"
END
END
PROJECTION
"init=EPSG:27572"
END
##FORMAT IMG########
OUTPUTFORMAT
NAME PNG
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGBA
FORMATOPTION INTERLACE=OFF
TRANSPARENT ON
END
OUTPUTFORMAT
NAME png8
DRIVER "GD/PNG"
IMAGEMODE RGBA
TRANSPARENT ON
END
OUTPUTFORMAT
NAME png24
DRIVER "GD/PNG"
IMAGEMODE PC256
TRANSPARENT ON
END
OUTPUTFORMAT
NAME GTiff
DRIVER "GDAL/GTiff"
MIMETYPE "image/tiff"
IMAGEMODE RGBA
#FORMATOPTION "TFW=YES"
#FORMATOPTION "COMPRESS=PACKBITS"
END
OUTPUTFORMAT
NAME imagemap
MIMETYPE "text/html"
FORMATOPTION SKIPENDTAG=OFF
DRIVER imagemap
END
##SYMBOLS###########
SYMBOL
NAME "symb_ville"
TYPE pixmap
IMAGE "data/images/mimg.gif"
END
LAYER
NAME "parc"
STATUS OFF
DATA "data\Parc_National\pnpal2.shp"
TYPE POLYGON
METADATA
"DESCRIPTION" "parc_national"
"wms_title" "WMS parc_national"
END
PROJECTION
"init=epsg:27572"
END
CLASS
COLOR 151 221 87
OUTLINECOLOR 54 94 19
END
END
END
Le .map client:
MAP
IMAGETYPE jpeg
#EXTENT -0.5 40.5 1.5 44.5
SIZE 800 600
SHAPEPATH "D:/Data"
IMAGECOLOR 255 255 255
FONTSET "fonts/fonts.list"
PROJECTION
"init=epsg:27582"
END
OUTPUTFORMAT
NAME png
MIMETYPE image/png
DRIVER GD/PNG
EXTENSION png
IMAGEMODE RGB
TRANSPARENT FALSE
END
OUTPUTFORMAT
NAME png8
DRIVER "GD/PNG"
IMAGEMODE PC256
TRANSPARENT OFF
END
OUTPUTFORMAT
NAME png24
DRIVER "GD/PNG"
IMAGEMODE PC256
TRANSPARENT ON
END
OUTPUTFORMAT
NAME GTiff
DRIVER "GDAL/GTiff"
IMAGEMODE RGB
END
OUTPUTFORMAT
NAME imagemap
DRIVER imagemap
END
### START OF WEB INTERFACE DEFINITION ###
WEB
IMAGEPATH "D:/Website/temp/"
IMAGEURL "/temp/"
END
LAYER
NAME "APEM_parc"
GROUP "APEM_parc"
TYPE POLYGON
STATUS OFF
CONNECTION "http://192.168.1.14/wms?"
CONNECTIONTYPE WMS
PROJECTION
"init=epsg:27582"
END
METADATA
"DESCRIPTION" "APEM_parc"
"wms_name" "parc"
"wms_server_version" "1.1.1"
"wms_format" "image/jpeg"
"wms_exceptions_format" "application/vnd.ogc.se_xml"
"wms_latlonboundingbox" "259966 1599000 678359 1900000"
END
END
END
Y voyez vous quelque chose de louche?
Meme dans ie avec getmap , ça ne marche pas...
pourtant j'arrive à visionner des images d'autres serveur wms, tel wms.jpl.nasa.gov, ou demis (mais pas geosignal au passage)
j'ai triffouillé du côté des output format et des "image/types", mais en vain, j'ai pourtant l'impression que ça viens de là, car le temps d'affichage est proportionnel aux couches qui devraient s'afficher. (mais qui ne le font pas)
#2 Tue 24 April 2007 15:38
Re: [Mapserver]WMS->probleme d'acces à un serveur "maison"
Pensez vous que mapserver utilise ce type MIME ? Moi je pencherai pour du XML.
À tester, je pense.
Y.
#3 Tue 24 April 2007 15:57
- Mobilotek
- Lieu: Toulouse
heu, avec ou sans ça ne change rien.
pour etre plus precis, il n'y a pas de messages d'erreur, lors du test sous un navigateur...il retourne meme une image, mais celle ci est vide (ou plutot blanche) si je lui demande une couche via wms...
#4 Tue 24 April 2007 16:47
STATUS OFF !?
#5 Tue 24 April 2007 17:24
- Mobilotek
- Lieu: Toulouse
STATUS ON ne change rien, mais c'est vrai que comme ça c'est plus logique...
#6 Tue 24 April 2007 17:38
Dommage, j'y croyais fort ![]()
Peut-être un problème d'extent ?
#7 Tue 24 April 2007 17:45
- Mobilotek
- Lieu: Toulouse
le .map serveur et le client ont les meme extent, mon client a des données non-wms, et je parviens a les voir correctement.
Que pensez vous des output format , des métas "wms_format" "images/extension" ou IMAGETYPE jpeg du map (client ou serveur), ou des layers, pensez vous qu'un mauvais parametrage de ces derniers pourrait etre la cause de cette image blanche?
jpeg est til optimal?
#8 Tue 24 April 2007 17:51
- Mobilotek
- Lieu: Toulouse
J'ai un doute également concernant la sémio des couches,
est-ce bien dans le mapfile serveur que l'on declare les "class" d'affichage? doit on (ou peut on) la modifier a partir du client?
bon, j'ai des couches raster sur le server, et elles aussi, subissent le meme probleme, donc ce doute n'est sans doute pas la cause du probleme.
#9 Thu 26 April 2007 11:52
- Mobilotek
- Lieu: Toulouse
comment savoir quelle est la version du serveur wms que l'on a monté?
c'est surement un probleme de versions, jusqu'à combien ça va? 1.1.1?
#10 Thu 26 April 2007 11:57
- Mobilotek
- Lieu: Toulouse
est-ce "wms_context_version" que l'on declare dans les métas du web?
autre question (peut etre idiote, mais) dans le .map côté client, quand on appel une couche polygonale (en wms) doit on mettre "TYPE RASTER" ou "TYPE POLYGON"???
