#1 Tue 24 April 2007 14:46
Mobilotek
[Mapserver]WMS->probleme d'acces à un serveur "maison"
j'enrage depuis quelques jours, car je ne trouve pas l'erreur,
J'ai un mapfile servant de serveur. Quand je l'appel dans Arcview, pas de pb, ça tourne,
Mais quand je l'appel avec dans un mapfile, ça coince.
Voici les extraits des fichiers:
Mapfile serveur
MAP
    NAME        Test_serveur
    EXTENT        259966 1599000 678359 1900000
    SIZE        450 450
    IMAGETYPE    jpeg
    WEB
        METADATA
            "wms_title"           "WMS_APEM"
            "wms_onlineresource"  "http://192.168.1.14/wms?"
            "wms_srs"             "EPSG:27572 EPSG:27582"
            "WMS_FEATURE_INFO_MIME_TYPE" "text/html"
        END
    END
    PROJECTION
        "init=EPSG:27572"
    END
##FORMAT IMG########
    OUTPUTFORMAT
        NAME PNG
        DRIVER "GD/PNG"
        MIMETYPE "image/png"
        IMAGEMODE RGBA
        FORMATOPTION  INTERLACE=OFF
        TRANSPARENT ON
    END
    OUTPUTFORMAT
        NAME png8
        DRIVER "GD/PNG"
        IMAGEMODE RGBA
        TRANSPARENT ON
    END
    OUTPUTFORMAT
        NAME png24
        DRIVER "GD/PNG"
        IMAGEMODE PC256
        TRANSPARENT ON
    END
    OUTPUTFORMAT
        NAME GTiff
        DRIVER "GDAL/GTiff"
        MIMETYPE "image/tiff"
        IMAGEMODE RGBA
        #FORMATOPTION "TFW=YES"
        #FORMATOPTION "COMPRESS=PACKBITS"
    END
    OUTPUTFORMAT
        NAME imagemap
        MIMETYPE "text/html"
        FORMATOPTION SKIPENDTAG=OFF
        DRIVER imagemap
    END
##SYMBOLS###########
    SYMBOL
        NAME    "symb_ville"
        TYPE    pixmap
        IMAGE    "data/images/mimg.gif"
    END
    LAYER
        NAME    "parc"
        STATUS    OFF
        DATA    "data\Parc_National\pnpal2.shp"
        TYPE    POLYGON
        METADATA
            "DESCRIPTION"   "parc_national"
            "wms_title"    "WMS parc_national"
        END
        PROJECTION
            "init=epsg:27572"
        END
        CLASS
            COLOR 151 221 87
            OUTLINECOLOR 54 94 19
        END
    END
END
Le .map client:
MAP
    IMAGETYPE    jpeg
    #EXTENT        -0.5 40.5 1.5 44.5
    SIZE        800 600
    SHAPEPATH    "D:/Data"
    IMAGECOLOR    255 255 255
    FONTSET        "fonts/fonts.list"
    PROJECTION
        "init=epsg:27582"
    END
    OUTPUTFORMAT
        NAME png
        MIMETYPE image/png
        DRIVER GD/PNG
        EXTENSION png
        IMAGEMODE RGB
        TRANSPARENT FALSE
    END
    OUTPUTFORMAT
        NAME png8
        DRIVER "GD/PNG"
        IMAGEMODE PC256
        TRANSPARENT OFF
    END
    OUTPUTFORMAT
        NAME png24
        DRIVER "GD/PNG"
        IMAGEMODE PC256
        TRANSPARENT ON
    END
    OUTPUTFORMAT
        NAME GTiff
        DRIVER "GDAL/GTiff"
        IMAGEMODE RGB
    END
    OUTPUTFORMAT
        NAME imagemap
        DRIVER imagemap
    END
### START OF WEB INTERFACE DEFINITION ###
WEB
    IMAGEPATH "D:/Website/temp/"
    IMAGEURL "/temp/"
END
    LAYER
        NAME        "APEM_parc"
        GROUP        "APEM_parc"
        TYPE        POLYGON
        STATUS        OFF
        CONNECTION    "http://192.168.1.14/wms?"
        CONNECTIONTYPE    WMS
        PROJECTION
            "init=epsg:27582"
        END
        METADATA
            "DESCRIPTION"            "APEM_parc"
            "wms_name"            "parc"
            "wms_server_version"        "1.1.1"
            "wms_format"            "image/jpeg"
            "wms_exceptions_format"        "application/vnd.ogc.se_xml"
            "wms_latlonboundingbox"        "259966 1599000 678359 1900000"
        END
    END
END
Y voyez vous quelque chose de louche?
Meme dans ie avec getmap , ça ne marche pas...
pourtant j'arrive à visionner des images d'autres serveur wms, tel wms.jpl.nasa.gov, ou demis (mais pas geosignal au passage)
j'ai triffouillé du côté des output format et des "image/types", mais en vain, j'ai pourtant l'impression que ça viens de là, car le temps d'affichage est proportionnel aux couches qui devraient s'afficher. (mais qui ne le font pas)
#2 Tue 24 April 2007 15:38
Yves
Lieu: Aix-les-Bains
Re: [Mapserver]WMS->probleme d'acces à un serveur "maison"
Pensez vous que mapserver utilise ce type MIME ? Moi je pencherai pour du XML.
À tester, je pense.
#3 Tue 24 April 2007 15:57
Mobilotek
heu, avec ou sans ça ne change rien.
pour etre plus precis, il n'y a pas de messages d'erreur, lors du test sous un navigateur...il retourne meme une image, mais celle ci est vide (ou plutot blanche) si je lui demande une couche via wms...
#4 Tue 24 April 2007 16:47
PA
Lieu: Paris
STATUS OFF !?
#5 Tue 24 April 2007 17:24
Mobilotek
STATUS ON ne change rien, mais c'est vrai que comme ça c'est plus logique...
#6 Tue 24 April 2007 17:38
PA
Lieu: Paris
Dommage, j'y croyais fort smile
Peut-être un problème d'extent ?
#7 Tue 24 April 2007 17:45
Mobilotek
le .map serveur et le client ont les meme extent, mon client a des données non-wms, et je parviens a les voir correctement.
Que pensez vous des output format , des métas "wms_format" "images/extension" ou IMAGETYPE  jpeg du map (client ou serveur), ou des layers,  pensez vous qu'un mauvais parametrage de ces derniers pourrait etre la cause de cette image blanche?
jpeg est til optimal?
#8 Tue 24 April 2007 17:51
Mobilotek
J'ai un doute également concernant la sémio des couches,
est-ce bien dans le mapfile serveur que l'on declare les "class" d'affichage?  doit on (ou peut on) la modifier a partir du client?
bon, j'ai des couches raster sur le server, et elles aussi, subissent le meme probleme, donc ce doute n'est sans doute pas la cause du probleme.
#9 Thu 26 April 2007 11:52
Mobilotek
comment savoir quelle est la version du serveur wms que l'on a monté?
c'est surement un probleme de versions, jusqu'à combien ça va? 1.1.1?
#10 Thu 26 April 2007 11:57
Mobilotek
est-ce "wms_context_version" que l'on declare dans les métas du web?
autre question (peut etre idiote, mais) dans le .map côté client, quand on appel une couche polygonale (en wms) doit on mettre "TYPE RASTER" ou "TYPE POLYGON"???
