#1 Fri 29 June 2012 15:54
Lebon henry
Lieu: Avignon
Publier un pmf en python
Bonjour, je travaille sous arcmap10 et je voudrais publier des pmf en python. Le but étant de publier des mxd en lot. J'ai trouvé celui-ci :
# PublishPMF.py
# !!!!Download comtypes installer at http://sourceforge.net/projects/comtypes/
#**** Set params ****
# Set Ver93 to False for 9.4 Beta
Ver93 = True
sProjPath = "c:/apps/Demo"
sMxdPath = sProjPath + "/Hydrants.mxd"
sPmfPath = sProjPath + "/Hydrants.pmf"
bEnableLayout = True
#**** Define helper functions and imports ****
print("Initializing...")
import comtypes
import comtypes.server.localserver
from comtypes.client import GetModule
def NewObj(MyClass, MyInterface):
    from comtypes.client import CreateObject
    try:
        ptr = CreateObject(MyClass, interface=MyInterface)
        return ptr
    except:
        return None
def CType(obj, interface):
    try:
        newobj = obj.QueryInterface(interface)
        return newobj
    except:
        return None
def GetESRILibPath():
    import _winreg
    if Ver93:
        sRegPath = "SOFTWARE\\ESRI\\ArcGIS"
    else:
        sRegPath = "SOFTWARE\\ESRI\\Desktop9.4"
    keyESRI = _winreg.OpenKey(_winreg.HKEY_LOCAL_MACHINE, sRegPath)
    return _winreg.QueryValueEx(keyESRI, "InstallDir")[0] + "com\\"
sLibPath = GetESRILibPath();
GetModule(sLibPath + "esriSystem.olb")
GetModule(sLibPath + "esriCarto.olb")
GetModule(sLibPath + "esriPublisher.olb")
from comtypes.gen.esriSystem import *
from comtypes.gen.esriCarto import *
from comtypes.gen.esriPublisher import *
def Init():
    pInit = NewObj(AoInitialize, IAoInitialize)
    eProduct = esriLicenseProductCodeArcView
    eStatus = pInit.IsProductCodeAvailable(eProduct)
    if eStatus != esriLicenseAvailable:
        return False
    eStatus = pInit.Initialize(eProduct)
    if eStatus != esriLicenseCheckedOut:
        return False
    # Check out Publisher
    eExtension = esriLicenseExtensionCodePublisher
    eStatus = pInit.IsExtensionCodeAvailable(eProduct, eExtension)
        return False
    eStatus = pInit.CheckOutExtension(eExtension)
        return False
    return True
def PublishPMF(pMapDoc, sPath):
    # Configure publisher
    pPub = NewObj(PublisherEngine, IPMFPublish)
    pPropSet = pPub.GetDefaultPublisherSettings()
    pPropSet.SetProperty("DisplayFunctionalityMessage", False)
    pPropSet.SetProperty("OpenOnlyInArcReader", False)
    pPropSet.SetProperty("InternalObjectAccess", True)
    if bEnableLayout:
        pPropSet.SetProperty("DefaultViewType", esriAPEViewTypeAll)
    else:
        pPropSet.SetProperty("DefaultViewType", esriAPEViewTypeDataOnly)
    # Create PMF
    pLayout = pMapDoc.PageLayout
    pMap = pMapDoc.Map(0) # Assume 1 map frame
    pActiveView = CType(pMap, IActiveView)
    bSuccess = True
    try:
        pPub.Publish(pLayout, pActiveView, pPropSet, False, sPath)
    except:
        bSuccess = False
    return bSuccess
#**** Do it ****
def DoIt():
    print "Checking out license..."
    if not Init():
        print "Error:  could not get license."
        return
    # Open mxd
    print "Opening mxd..."
    pMapDoc = NewObj(MapDocument, IMapDocument)
    try:
        pMapDoc.Open(sMxdPath)
    except:
        print "Error opening mxd."
        return
    # Publish PMF
    print "Publishing PMF..."
    bResult = PublishPMF(pMapDoc, sPmfPath)
    pMapDoc.Close()
    if not bResult:
        print "Error publishing pmf."
        return
    print "Done."
DoIt()
Que j'ai modifié comme cela:
Ver10 = True
sMxdPath = "C:\\MaCarte.mxd"
sPmfPath = "C:\\MaCarte.pmf"
import comtypes
    try:
        return ptr
    except:
        return None
    try:
        return newobj
    except:
        return None
GetModule("C:\Program Files\ArcGIS\Desktop10.0\com\esriSystem.olb")
GetModule("C:\Program Files\ArcGIS\Desktop10.0\com\esriCarto.olb")
GetModule("C:\Program Files\ArcGIS\Desktop10.0\com\esriPublisher.olb")
def Init():
        return False
        return False
        return False
        return False
    return True
    if bEnableLayout:
    else:
    # Create PMF
    bSuccess = True
    try:
    except Exception as e:
        print e
        bSuccess = False
    return bSuccess
#**** Do it ****
def DoIt():
    if not Init():
        return
    # Open mxd
    try:
    except:
        return
    # Publish PMF
    pMapDoc.Close()
    if not bResult:
        return
    print "Done."
DoIt()
Mais j'ai ce message d'erreur : (-2147467259, 'Erreur non sp\xe9cifi\xe9e', (None, None, None, 0, None))
Visiblement un problème avec cette ligne du code :
Quelqu'un a-t-il un script qui marche ou peut-il m'aider à faire marcher le mien ?
Merci d'avance. Bonne journée.
