#1 Fri 29 June 2012 15:54
- Lebon henry
- Lieu: Avignon
Publier un pmf en python
Bonjour, je travaille sous arcmap10 et je voudrais publier des pmf en python. Le but étant de publier des mxd en lot. J'ai trouvé celui-ci :
# PublishPMF.py
# !!!!Download comtypes installer at http://sourceforge.net/projects/comtypes/
#**** Set params ****
# Set Ver93 to False for 9.4 Beta
Ver93 = True
sProjPath = "c:/apps/Demo"
sMxdPath = sProjPath + "/Hydrants.mxd"
sPmfPath = sProjPath + "/Hydrants.pmf"
bEnableLayout = True
#**** Define helper functions and imports ****
print("Initializing...")
import comtypes
import comtypes.server.localserver
from comtypes.client import GetModule
def NewObj(MyClass, MyInterface):
from comtypes.client import CreateObject
try:
ptr = CreateObject(MyClass, interface=MyInterface)
return ptr
except:
return None
def CType(obj, interface):
try:
newobj = obj.QueryInterface(interface)
return newobj
except:
return None
def GetESRILibPath():
import _winreg
if Ver93:
sRegPath = "SOFTWARE\\ESRI\\ArcGIS"
else:
sRegPath = "SOFTWARE\\ESRI\\Desktop9.4"
keyESRI = _winreg.OpenKey(_winreg.HKEY_LOCAL_MACHINE, sRegPath)
return _winreg.QueryValueEx(keyESRI, "InstallDir")[0] + "com\\"
sLibPath = GetESRILibPath();
GetModule(sLibPath + "esriSystem.olb")
GetModule(sLibPath + "esriCarto.olb")
GetModule(sLibPath + "esriPublisher.olb")
from comtypes.gen.esriSystem import *
from comtypes.gen.esriCarto import *
from comtypes.gen.esriPublisher import *
def Init():
pInit = NewObj(AoInitialize, IAoInitialize)
eProduct = esriLicenseProductCodeArcView
eStatus = pInit.IsProductCodeAvailable(eProduct)
if eStatus != esriLicenseAvailable:
return False
eStatus = pInit.Initialize(eProduct)
if eStatus != esriLicenseCheckedOut:
return False
# Check out Publisher
eExtension = esriLicenseExtensionCodePublisher
eStatus = pInit.IsExtensionCodeAvailable(eProduct, eExtension)
return False
eStatus = pInit.CheckOutExtension(eExtension)
return False
return True
def PublishPMF(pMapDoc, sPath):
# Configure publisher
pPub = NewObj(PublisherEngine, IPMFPublish)
pPropSet = pPub.GetDefaultPublisherSettings()
pPropSet.SetProperty("DisplayFunctionalityMessage", False)
pPropSet.SetProperty("OpenOnlyInArcReader", False)
pPropSet.SetProperty("InternalObjectAccess", True)
if bEnableLayout:
pPropSet.SetProperty("DefaultViewType", esriAPEViewTypeAll)
else:
pPropSet.SetProperty("DefaultViewType", esriAPEViewTypeDataOnly)
# Create PMF
pLayout = pMapDoc.PageLayout
pMap = pMapDoc.Map(0) # Assume 1 map frame
pActiveView = CType(pMap, IActiveView)
bSuccess = True
try:
pPub.Publish(pLayout, pActiveView, pPropSet, False, sPath)
except:
bSuccess = False
return bSuccess
#**** Do it ****
def DoIt():
print "Checking out license..."
if not Init():
print "Error: could not get license."
return
# Open mxd
print "Opening mxd..."
pMapDoc = NewObj(MapDocument, IMapDocument)
try:
pMapDoc.Open(sMxdPath)
except:
print "Error opening mxd."
return
# Publish PMF
print "Publishing PMF..."
bResult = PublishPMF(pMapDoc, sPmfPath)
pMapDoc.Close()
if not bResult:
print "Error publishing pmf."
return
print "Done."
DoIt()Que j'ai modifié comme cela:
Ver10 = True
sMxdPath = "C:\\MaCarte.mxd"
sPmfPath = "C:\\MaCarte.pmf"
import comtypes
try:
return ptr
except:
return None
try:
return newobj
except:
return None
GetModule("C:\Program Files\ArcGIS\Desktop10.0\com\esriSystem.olb")
GetModule("C:\Program Files\ArcGIS\Desktop10.0\com\esriCarto.olb")
GetModule("C:\Program Files\ArcGIS\Desktop10.0\com\esriPublisher.olb")
def Init():
return False
return False
return False
return False
return True
if bEnableLayout:
else:
# Create PMF
bSuccess = True
try:
except Exception as e:
print e
bSuccess = False
return bSuccess
#**** Do it ****
def DoIt():
if not Init():
return
# Open mxd
try:
except:
return
# Publish PMF
pMapDoc.Close()
if not bResult:
return
print "Done."
DoIt()Mais j'ai ce message d'erreur : (-2147467259, 'Erreur non sp\xe9cifi\xe9e', (None, None, None, 0, None))
Visiblement un problème avec cette ligne du code :
Quelqu'un a-t-il un script qui marche ou peut-il m'aider à faire marcher le mien ?
Merci d'avance. Bonne journée.
