#1 Thu 16 August 2012 09:37
Loic_GR
Lieu: Besancon
fme_aggregate dans table postgis multipolygon
Je n'arrive pas à intégrer des multi polygones que j'agrège avec "aggregator" dans une table postgis qui a pour restriction en multipolygon
voici le log d'erreur :
2012-08-16 09:34:21|  12.2|  0.0|WARN  |Export to Well Known Binary (WKB) failed.  Geometry might not be representable in requested form
2012-08-16 09:34:21|  12.2|  0.0|STATS |Storing feature(s) to FME feature store file `E:\loic\ppnmefc\Plateforme\bdd ppnmefc\modelisation\V4\remplissage_v1\FME/1_wrkb_zonages_administratifs_log.ffs'
2012-08-16 09:34:21|  12.2|  0.0|WARN  |+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2012-08-16 09:34:21|  12.2|  0.0|WARN  |Feature Type: `public.t_geom_zonage'
2012-08-16 09:34:21|  12.2|  0.0|WARN  |Attribute(string)           : `__wb_out_feat_type__' has value `public.t_geom_zonage'
2012-08-16 09:34:21|  12.2|  0.0|WARN  |Attribute(string)           : `com_insee' has value `39140'
2012-08-16 09:34:21|  12.2|  0.0|WARN  |Attribute(string)           : `com_nom' has value `Chêne-Sec'
2012-08-16 09:34:21|  12.2|  0.0|WARN  |Attribute(string)           : `com_pop' has value `37'
2012-08-16 09:34:21|  12.2|  0.0|WARN  |Attribute(string)           : `fme_basename' has value `COMMUNE'
2012-08-16 09:34:21|  12.2|  0.0|WARN  |Attribute(entangled: string): `fme_color' has value `0.627450980392157,0.627450980392157,0.627450980392157'
2012-08-16 09:34:21|  12.2|  0.0|WARN  |Attribute(string)           : `fme_dataset' has value `E:\loic\ppnmefc\Data\referentiel\IGN\COMMUNE.tab'
2012-08-16 09:34:21|  12.2|  0.0|WARN  |Attribute(string)           : `fme_feature_type' has value `COMMUNE'
2012-08-16 09:34:21|  12.2|  0.0|WARN  |Attribute(string)           : `fme_geometry' has value `fme_aggregate'
2012-08-16 09:34:21|  12.2|  0.0|WARN  |Attribute(entangled: string): `fme_type' has value `fme_collection'
2012-08-16 09:34:21|  12.2|  0.0|WARN  |Attribute(string)           : `gez_id_geom_zonage' has value `642'
2012-08-16 09:34:21|  12.2|  0.0|WARN  |Attribute(string)           : `multi_writer_id' has value `1'
2012-08-16 09:34:21|  12.2|  0.0|WARN  |Attribute(string)           : `postgis_type' has value `postgis_geometrycollection'
2012-08-16 09:34:21|  12.2|  0.0|WARN  |Attribute(encoded: utf-8)   : `tzo_id_type_zonage' has value `1'
2012-08-16 09:34:21|  12.2|  0.0|WARN  |Coordinate System: `EPSG:2154'
2012-08-16 09:34:21|  12.2|  0.0|WARN  |Geometry Type: Multiple Geometry
2012-08-16 09:34:21|  12.2|  0.0|WARN  |Number of Geometries: 1
2012-08-16 09:34:21|  12.2|  0.0|WARN  |--------------------------------------
2012-08-16 09:34:21|  12.2|  0.0|WARN  |Geometry Number: 0
2012-08-16 09:34:21|  12.2|  0.0|WARN  |   Geometry Type: IFMEMultiArea
2012-08-16 09:34:21|  12.2|  0.0|WARN  |   Name(fme-system): `fme_area'
2012-08-16 09:34:21|  12.2|  0.0|WARN  |   Number of Areas: 3
2012-08-16 09:34:21|  12.2|  0.0|WARN  |   --------------------------------------
2012-08-16 09:34:21|  12.2|  0.0|WARN  |   Area Number: 0
2012-08-16 09:34:21|  12.2|  0.0|WARN  |      Geometry Type: IFMEPolygon
2012-08-16 09:34:21|  12.2|  0.0|WARN  |      Boundary:
2012-08-16 09:34:21|  12.2|  0.0|WARN  |         Geometry Type: IFMELine
2012-08-16 09:34:21|  12.2|  0.0|WARN  |         Number of Coordinates: 203 -- Coordinate Dimension: 2
2012-08-16 09:34:21|  12.2|  0.0|WARN  |         (885361.19972610509,6642936.7995219901)(885341.99952075654,6642940.4009999754)(885328.00103340205,6642941.099427863)(885311.69929778157,6642947.200072729)(885293.49975460104,6642956.6991382716)
2012-08-16 09:34:21|  12.2|  0.0|WARN  |         (885261.40092764306,6642968.6996020935)(885246.69938885164,6642973.8005802082)(885234.19973814965,6642978.2008990357)(885227.90031101007,6642983.4000587054)(885206.39901399508,6642924.2010432361)
2012-08-16 09:34:21|  12.2|  0.0|WARN  |         ...Skipping coordinates...
2012-08-16 09:34:21|  12.2|  0.0|WARN  |         (885466.10103898414,6642868.9002818186)(885462.99984890304,6642869.6009411048)(885453.20026077505,6642871.3994486984)(885447.70093205012,6642873.2001876915)(885443.79964355461,6642876.6990213236)
2012-08-16 09:34:21|  12.2|  0.0|WARN  |         (885441.20094115706,6642878.9995936928)(885436.90068175411,6642883.6989199864)(885425.69930395111,6642893.2002169285)(885411.89922375057,6642902.7996954266)(885390.40008333512,6642920.4991522944)
2012-08-16 09:34:21|  12.2|  0.0|WARN  |         (885380.69969878404,6642928.4005361535)(885370.80090707913,6642933.4992828686)(885361.19972610509,6642936.7995219901)
2012-08-16 09:34:21|  12.2|  0.0|WARN  |   Area Number: 1
2012-08-16 09:34:21|  12.2|  0.0|WARN  |         Number of Coordinates: 85 -- Coordinate Dimension: 2
2012-08-16 09:34:21|  12.2|  0.0|WARN  |         (886159.70010037557,6641282.0988993431)(886199.4009405711,6641256.7992974808)(886257.79949843162,6641217.6003112476)(886282.30062535114,6641274.6995802587)(886340.80054338812,6641237.7007534401)
2012-08-16 09:34:21|  12.2|  0.0|WARN  |         (886385.29981747107,6641316.1991388611)(886419.69973609562,6641309.8998994837)(886492.70062917063,6641283.2993920045)(886519.69909831113,6641339.9992405949)(886546.60052047414,6641418.3994444599)
2012-08-16 09:34:21|  12.2|  0.0|WARN  |         (886019.49956688064,6641447.4991188189)(886009.69997875264,6641415.0992053384)(886001.5005874536,6641389.7996034771)(885993.79937063914,6641367.0995814493)(885985.99895024754,6641348.0010374086)
2012-08-16 09:34:21|  12.2|  0.0|WARN  |         (885971.89910271659,6641320.6998706441)(885965.80023933062,6641305.8008195208)(886019.70013063413,6641293.4991168333)(886122.69932275405,6641297.299189331)(886159.70010037557,6641282.0988993431)
2012-08-16 09:34:21|  12.2|  0.0|WARN  |   Area Number: 2
2012-08-16 09:34:21|  12.2|  0.0|WARN  |         Number of Coordinates: 68 -- Coordinate Dimension: 2
2012-08-16 09:34:21|  12.2|  0.0|WARN  |         (886845.69930512912,6641962.8005526867)(886842.19914414058,6641947.4998497441)(886841.80017323315,6641941.4996178327)(886841.00007481861,6641931.59890047)(886846.19963621313,6641936.300458163)
2012-08-16 09:34:21|  12.2|  0.0|WARN  |         (886850.70045936957,6641939.1008639075)(886857.70078134665,6641942.3006900735)(886869.10056630359,6641945.7995237056)(886878.00085244013,6641948.599929451)(886883.89915207261,6641950.3002554886)
2012-08-16 09:34:21|  12.2|  0.0|WARN  |         (886803.90009362006,6642139.4001637436)(886794.10050549207,6642098.7998589389)(886792.89927957056,6642087.3996414477)(886793.99914531561,6642078.5990037918)(886800.99946729257,6642065.400278707)
2012-08-16 09:34:21|  12.2|  0.0|WARN  |         (886813.99944907858,6642042.4994307701)(886828.09929660964,6642022.499401533)(886843.10060273157,6642004.0992853791)(886847.59926928859,6641995.4994736323)(886850.79966294661,6641988.300980459)
2012-08-16 09:34:21|  12.2|  0.0|WARN  |         (886850.90102312306,6641980.7990170205)(886849.30082629411,6641972.1010237187)(886845.69930512912,6641962.8005526867)
2012-08-16 09:34:21|  12.2|  0.0|WARN  |===========================================================================
2012-08-16 09:34:21|  12.2|  0.0|INFORM|MULTI_WRITER: multi_writer_id `1': Writing feature 0
2012-08-16 09:34:21|  12.2|  0.0|INFORM|Successfully closed POSTGIS database writer
2012-08-16 09:34:21|  12.2|  0.0|INFORM|=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
2012-08-16 09:34:21|  12.2|  0.0|INFORM|Feature output statistics for `POSTGIS' writer using keyword `POSTGIS_3':
2012-08-16 09:34:21|  12.2|  0.0|STATS |=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
2012-08-16 09:34:21|  12.2|  0.0|STATS |                               Features Written
2012-08-16 09:34:21|  12.2|  0.0|STATS |public.t_geom_zonage (public.t_geom_zonage)                                  1
2012-08-16 09:34:21|  12.2|  0.0|STATS |==============================================================================
2012-08-16 09:34:21|  12.2|  0.0|STATS |Total Features Written                                                       1
N.B: J'utilise FME 2012 sp3
Merci pour votre aide.
#2 Thu 16 August 2012 10:08
Loic_GR
Lieu: Besancon
Re: fme_aggregate dans table postgis multipolygon
Je viens de comprendre le souci. Je faisais une agrégation sur des données déjà agrégées...
#3 Thu 16 August 2012 10:13
Pookie
D'après le log le résultat de l'agrégat est une geometrycollection et pas un multiplygone comme l'attend Postgis. Cela arrive si vous utilisez un geometryextractor après l'aggregator. Pour avoir eu le problème (avec FME2011) je l'avais résolu en spécifiant ogc 1.1 dans le geometryextractor. Veremes m'avait aussi conseillé d'utiliser un FMEFunctionCaller avec "@Geometry(fme_classic_geometry) qui fonctionne bien.
#4 Thu 16 August 2012 12:23
Loic_GR
Lieu: Besancon
Merci Pookie pour ton aide mais le souci venait du fait que faisait une agrégation sur des polygones déjà agrégés.
