#1 Thu 16 August 2012 09:37
fme_aggregate dans table postgis multipolygon
Je n'arrive pas à intégrer des multi polygones que j'agrège avec "aggregator" dans une table postgis qui a pour restriction en multipolygon
voici le log d'erreur :
2012-08-16 09:34:21| 12.2| 0.0|WARN |Export to Well Known Binary (WKB) failed. Geometry might not be representable in requested form 2012-08-16 09:34:21| 12.2| 0.0|STATS |Storing feature(s) to FME feature store file `E:\loic\ppnmefc\Plateforme\bdd ppnmefc\modelisation\V4\remplissage_v1\FME/1_wrkb_zonages_administratifs_log.ffs' 2012-08-16 09:34:21| 12.2| 0.0|WARN |+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 2012-08-16 09:34:21| 12.2| 0.0|WARN |Feature Type: `public.t_geom_zonage' 2012-08-16 09:34:21| 12.2| 0.0|WARN |Attribute(string) : `__wb_out_feat_type__' has value `public.t_geom_zonage' 2012-08-16 09:34:21| 12.2| 0.0|WARN |Attribute(string) : `com_insee' has value `39140' 2012-08-16 09:34:21| 12.2| 0.0|WARN |Attribute(string) : `com_nom' has value `Chêne-Sec' 2012-08-16 09:34:21| 12.2| 0.0|WARN |Attribute(string) : `com_pop' has value `37' 2012-08-16 09:34:21| 12.2| 0.0|WARN |Attribute(string) : `fme_basename' has value `COMMUNE' 2012-08-16 09:34:21| 12.2| 0.0|WARN |Attribute(entangled: string): `fme_color' has value `0.627450980392157,0.627450980392157,0.627450980392157' 2012-08-16 09:34:21| 12.2| 0.0|WARN |Attribute(string) : `fme_dataset' has value `E:\loic\ppnmefc\Data\referentiel\IGN\COMMUNE.tab' 2012-08-16 09:34:21| 12.2| 0.0|WARN |Attribute(string) : `fme_feature_type' has value `COMMUNE' 2012-08-16 09:34:21| 12.2| 0.0|WARN |Attribute(string) : `fme_geometry' has value `fme_aggregate' 2012-08-16 09:34:21| 12.2| 0.0|WARN |Attribute(entangled: string): `fme_type' has value `fme_collection' 2012-08-16 09:34:21| 12.2| 0.0|WARN |Attribute(string) : `gez_id_geom_zonage' has value `642' 2012-08-16 09:34:21| 12.2| 0.0|WARN |Attribute(string) : `multi_writer_id' has value `1' 2012-08-16 09:34:21| 12.2| 0.0|WARN |Attribute(string) : `postgis_type' has value `postgis_geometrycollection' 2012-08-16 09:34:21| 12.2| 0.0|WARN |Attribute(encoded: utf-8) : `tzo_id_type_zonage' has value `1' 2012-08-16 09:34:21| 12.2| 0.0|WARN |Coordinate System: `EPSG:2154' 2012-08-16 09:34:21| 12.2| 0.0|WARN |Geometry Type: Multiple Geometry 2012-08-16 09:34:21| 12.2| 0.0|WARN |Number of Geometries: 1 2012-08-16 09:34:21| 12.2| 0.0|WARN |-------------------------------------- 2012-08-16 09:34:21| 12.2| 0.0|WARN |Geometry Number: 0 2012-08-16 09:34:21| 12.2| 0.0|WARN | Geometry Type: IFMEMultiArea 2012-08-16 09:34:21| 12.2| 0.0|WARN | Name(fme-system): `fme_area' 2012-08-16 09:34:21| 12.2| 0.0|WARN | Number of Areas: 3 2012-08-16 09:34:21| 12.2| 0.0|WARN | -------------------------------------- 2012-08-16 09:34:21| 12.2| 0.0|WARN | Area Number: 0 2012-08-16 09:34:21| 12.2| 0.0|WARN | Geometry Type: IFMEPolygon 2012-08-16 09:34:21| 12.2| 0.0|WARN | Boundary: 2012-08-16 09:34:21| 12.2| 0.0|WARN | Geometry Type: IFMELine 2012-08-16 09:34:21| 12.2| 0.0|WARN | Number of Coordinates: 203 -- Coordinate Dimension: 2 2012-08-16 09:34:21| 12.2| 0.0|WARN | (885361.19972610509,6642936.7995219901)(885341.99952075654,6642940.4009999754)(885328.00103340205,6642941.099427863)(885311.69929778157,6642947.200072729)(885293.49975460104,6642956.6991382716) 2012-08-16 09:34:21| 12.2| 0.0|WARN | (885261.40092764306,6642968.6996020935)(885246.69938885164,6642973.8005802082)(885234.19973814965,6642978.2008990357)(885227.90031101007,6642983.4000587054)(885206.39901399508,6642924.2010432361) 2012-08-16 09:34:21| 12.2| 0.0|WARN | ...Skipping coordinates... 2012-08-16 09:34:21| 12.2| 0.0|WARN | (885466.10103898414,6642868.9002818186)(885462.99984890304,6642869.6009411048)(885453.20026077505,6642871.3994486984)(885447.70093205012,6642873.2001876915)(885443.79964355461,6642876.6990213236) 2012-08-16 09:34:21| 12.2| 0.0|WARN | (885441.20094115706,6642878.9995936928)(885436.90068175411,6642883.6989199864)(885425.69930395111,6642893.2002169285)(885411.89922375057,6642902.7996954266)(885390.40008333512,6642920.4991522944) 2012-08-16 09:34:21| 12.2| 0.0|WARN | (885380.69969878404,6642928.4005361535)(885370.80090707913,6642933.4992828686)(885361.19972610509,6642936.7995219901) 2012-08-16 09:34:21| 12.2| 0.0|WARN | -------------------------------------- 2012-08-16 09:34:21| 12.2| 0.0|WARN | Area Number: 1 2012-08-16 09:34:21| 12.2| 0.0|WARN | Geometry Type: IFMEPolygon 2012-08-16 09:34:21| 12.2| 0.0|WARN | Boundary: 2012-08-16 09:34:21| 12.2| 0.0|WARN | Geometry Type: IFMELine 2012-08-16 09:34:21| 12.2| 0.0|WARN | Number of Coordinates: 85 -- Coordinate Dimension: 2 2012-08-16 09:34:21| 12.2| 0.0|WARN | (886159.70010037557,6641282.0988993431)(886199.4009405711,6641256.7992974808)(886257.79949843162,6641217.6003112476)(886282.30062535114,6641274.6995802587)(886340.80054338812,6641237.7007534401) 2012-08-16 09:34:21| 12.2| 0.0|WARN | (886385.29981747107,6641316.1991388611)(886419.69973609562,6641309.8998994837)(886492.70062917063,6641283.2993920045)(886519.69909831113,6641339.9992405949)(886546.60052047414,6641418.3994444599) 2012-08-16 09:34:21| 12.2| 0.0|WARN | ...Skipping coordinates... 2012-08-16 09:34:21| 12.2| 0.0|WARN | (886019.49956688064,6641447.4991188189)(886009.69997875264,6641415.0992053384)(886001.5005874536,6641389.7996034771)(885993.79937063914,6641367.0995814493)(885985.99895024754,6641348.0010374086) 2012-08-16 09:34:21| 12.2| 0.0|WARN | (885971.89910271659,6641320.6998706441)(885965.80023933062,6641305.8008195208)(886019.70013063413,6641293.4991168333)(886122.69932275405,6641297.299189331)(886159.70010037557,6641282.0988993431) 2012-08-16 09:34:21| 12.2| 0.0|WARN | -------------------------------------- 2012-08-16 09:34:21| 12.2| 0.0|WARN | Area Number: 2 2012-08-16 09:34:21| 12.2| 0.0|WARN | Geometry Type: IFMEPolygon 2012-08-16 09:34:21| 12.2| 0.0|WARN | Boundary: 2012-08-16 09:34:21| 12.2| 0.0|WARN | Geometry Type: IFMELine 2012-08-16 09:34:21| 12.2| 0.0|WARN | Number of Coordinates: 68 -- Coordinate Dimension: 2 2012-08-16 09:34:21| 12.2| 0.0|WARN | (886845.69930512912,6641962.8005526867)(886842.19914414058,6641947.4998497441)(886841.80017323315,6641941.4996178327)(886841.00007481861,6641931.59890047)(886846.19963621313,6641936.300458163) 2012-08-16 09:34:21| 12.2| 0.0|WARN | (886850.70045936957,6641939.1008639075)(886857.70078134665,6641942.3006900735)(886869.10056630359,6641945.7995237056)(886878.00085244013,6641948.599929451)(886883.89915207261,6641950.3002554886) 2012-08-16 09:34:21| 12.2| 0.0|WARN | ...Skipping coordinates... 2012-08-16 09:34:21| 12.2| 0.0|WARN | (886803.90009362006,6642139.4001637436)(886794.10050549207,6642098.7998589389)(886792.89927957056,6642087.3996414477)(886793.99914531561,6642078.5990037918)(886800.99946729257,6642065.400278707) 2012-08-16 09:34:21| 12.2| 0.0|WARN | (886813.99944907858,6642042.4994307701)(886828.09929660964,6642022.499401533)(886843.10060273157,6642004.0992853791)(886847.59926928859,6641995.4994736323)(886850.79966294661,6641988.300980459) 2012-08-16 09:34:21| 12.2| 0.0|WARN | (886850.90102312306,6641980.7990170205)(886849.30082629411,6641972.1010237187)(886845.69930512912,6641962.8005526867) 2012-08-16 09:34:21| 12.2| 0.0|WARN |=========================================================================== 2012-08-16 09:34:21| 12.2| 0.0|INFORM|MULTI_WRITER: multi_writer_id `1': Writing feature 0 2012-08-16 09:34:21| 12.2| 0.0|INFORM|Successfully closed POSTGIS database writer 2012-08-16 09:34:21| 12.2| 0.0|INFORM|=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- 2012-08-16 09:34:21| 12.2| 0.0|INFORM|Feature output statistics for `POSTGIS' writer using keyword `POSTGIS_3': 2012-08-16 09:34:21| 12.2| 0.0|STATS |=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- 2012-08-16 09:34:21| 12.2| 0.0|STATS | Features Written 2012-08-16 09:34:21| 12.2| 0.0|STATS |=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- 2012-08-16 09:34:21| 12.2| 0.0|STATS |public.t_geom_zonage (public.t_geom_zonage) 1 2012-08-16 09:34:21| 12.2| 0.0|STATS |============================================================================== 2012-08-16 09:34:21| 12.2| 0.0|STATS |Total Features Written 1 2012-08-16 09:34:21| 12.2| 0.0|STATS |=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
N.B: J'utilise FME 2012 sp3
Merci pour votre aide.
#2 Thu 16 August 2012 10:08
Re: fme_aggregate dans table postgis multipolygon
Je viens de comprendre le souci. Je faisais une agrégation sur des données déjà agrégées...
#3 Thu 16 August 2012 10:13
- Pookie
D'après le log le résultat de l'agrégat est une geometrycollection et pas un multiplygone comme l'attend Postgis. Cela arrive si vous utilisez un geometryextractor après l'aggregator. Pour avoir eu le problème (avec FME2011) je l'avais résolu en spécifiant ogc 1.1 dans le geometryextractor. Veremes m'avait aussi conseillé d'utiliser un FMEFunctionCaller avec "@Geometry(fme_classic_geometry) qui fonctionne bien.
#4 Thu 16 August 2012 12:23
Merci Pookie pour ton aide mais le souci venait du fait que faisait une agrégation sur des polygones déjà agrégés.
