#1 Tue 22 January 2013 16:46
- petit_pied
- Lieu: Pau
OpenLayers WMS et Oracle
Je suis actuellement sur une mini application avec de OL, Mapserver et base de données sous oracle spatial 10G.
L'erreur retournée par MapServer est la suivante :
msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in the LAYERS parameter.
je n'arrive pas à sortir de ce problème.
Mon mapfile :
MAP
EXTENT 212386.486486486 224800 2641413.51351351 2222000
FONTSET "fonts/fonts.txt"
IMAGECOLOR 255 255 255
IMAGETYPE PNG
SYMBOLSET "symbols/symbols.sym"
SIZE 1000 1000
SHAPEPATH "/var/www/rasters/"
STATUS ON
CONFIG "MS_ERRORFILE" /var/www/html/tmp/ms_error.txt
UNITS METERS
OUTPUTFORMAT
NAME aggpng24
DRIVER AGG/PNG
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION "png"
FORMATOPTION "INTERLACE=OFF"
END
OUTPUTFORMAT
NAME "png"
MIMETYPE "image/PNG"
DRIVER "AGG/PNG"
EXTENSION "PNG"
IMAGEMODE "RGB"
TRANSPARENT FALSE
FORMATOPTION "QUALITY=30"
END
PROJECTION
"init=epsg:3943"
END
WEB
IMAGEPATH "/var/www/html/tmp/"
IMAGEURL "html/tmp/"
TEMPLATE "/var/www/html/technos/mapserver_test/template.html"
QUERYFORMAT text/html
LEGENDFORMAT text/html
BROWSEFORMAT text/html
METADATA
"WMS_TITLE" "oracle"
"WMS_ONLINERESOURCE" "http:///localhost/cgi-bin/mapserv?map=/var/www/html/astech/map/astech.map&"
"WMS_SRS" "EPSG:3943"
"WMS_FORMAT" "image/png"
"WMS_ENABLE_REQUEST" "*"
"WMS_PROXY_HOST" "192.168.1.201"
"WMS_PROXY_PORT" "3128"
"WMS_EXTENT" "1416170.749530 2220567.100330 1441220.549670 2248121.880470"
END
END
LAYER
NAME "ADM.Communes_CDA"
STATUS ON
TYPE POLYGON
TRANSPARENCY ALPHA
CONNECTION "collaboratif/collaboratif@(DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=192.168.1.5)(PORT=1521))(CONNECT_DATA=(SERVICE_NAME=SIG)))"
CONNECTIONTYPE ORACLESPATIAL
DATA "SHAPE FROM (SELECT * FROM ADM.COMMUNES_CDA) USING UNIQUE OBJECTID SRID 3943"
CLASS
STYLE
WIDTH 2
OUTLINECOLOR 255 255 255
#COLOR 255 255 255
ANTIALIAS TRUE
END
END
METADATA
"wms_title" "ADM.Communes_CDA"
"wms_transparent" "false"
"wms_srs" "epsg:3943"
"wms_extent" "1416170.749530 2220567.100330 1441220.549670 2248121.880470"
END
PROJECTION
"init=epsg:3943"
END
END
ENDVoici le .js :
var ortho;
var equip;
var map;
function init() {
//etendu
var extent = new OpenLayers.Bounds(1417000.000000,2222200.000000,1439800.000000,2247400.000000);
//Projection
var projlamb ='EPSG:3943';
//Options de la carte
var options={
//new OpenLayers.Control.Navigation(),
controls: [new OpenLayers.Control.PanZoomBar()],
resolutions: [25,10,5,2,1,0.5,0.25,0.1,0.05],
maxExtent: extent,
maxResolution: 'auto',
units: 'm',
projection: projlamb,
displayProjection: projlamb
map = new OpenLayers.Map('map_canvas',options);
map.addControl(new OpenLayers.Control.LayerSwitcher());
equip = new OpenLayers.Layer.WMS("equip", "http://193.17.196.20/cgi-bin/mapserv?map=/var/www/html/astech/map/astech.map&",
{layers:'basic',srs:'ESPG:3943',format:'image/png'});
equip.id = 'equip';
map.addLayer(equip);
}Merci d'avance pour votre aide.
Marion
#2 Tue 22 January 2013 17:52
Re: OpenLayers WMS et Oracle
Dans ton objet layer dans ton code JavaScript tu as définie le paramètre layers à basic (en fait tu as laissé la valeur de l'exemple). Or cette couche n'apparait pas dans ton mapfile :
Ceci devrait corriger l'affaire :
{layers:'ADM.Communes_CDA',srs:'ESPG:3943',format:'image/png'});
Y.
#3 Wed 23 January 2013 16:06
- petit_pied
- Lieu: Pau
ça marche.
Merci beaucoup votre aide.
Marion
