#1 Tue 22 January 2013 16:46
petit_pied
Lieu: Pau
OpenLayers WMS et Oracle
Je suis actuellement sur une mini application avec de OL, Mapserver et base de données sous oracle spatial  10G.
L'erreur retournée par MapServer est la suivante :
msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in the LAYERS parameter.
je n'arrive pas à sortir de ce problème.
Mon mapfile :
MAP
  EXTENT 212386.486486486 224800 2641413.51351351 2222000
  FONTSET "fonts/fonts.txt"
  IMAGECOLOR 255 255 255
  IMAGETYPE PNG
  SYMBOLSET "symbols/symbols.sym"
  SIZE 1000 1000
  SHAPEPATH "/var/www/rasters/"
  STATUS ON
  CONFIG "MS_ERRORFILE" /var/www/html/tmp/ms_error.txt
  UNITS METERS
OUTPUTFORMAT
    NAME aggpng24
    DRIVER AGG/PNG
    MIMETYPE "image/png"
    IMAGEMODE RGBA
    EXTENSION "png"
    FORMATOPTION "INTERLACE=OFF"
END
  OUTPUTFORMAT
    NAME "png"
    MIMETYPE "image/PNG"
    DRIVER "AGG/PNG"
    EXTENSION "PNG"
    IMAGEMODE "RGB"
    TRANSPARENT FALSE
    FORMATOPTION "QUALITY=30"
  END
PROJECTION
"init=epsg:3943"
END
  WEB
    IMAGEPATH "/var/www/html/tmp/"
    IMAGEURL "html/tmp/"
    TEMPLATE "/var/www/html/technos/mapserver_test/template.html"
    QUERYFORMAT text/html
    LEGENDFORMAT text/html
    BROWSEFORMAT text/html
    METADATA
        "WMS_TITLE" "oracle"
        "WMS_ONLINERESOURCE" "http:///localhost/cgi-bin/mapserv?map=/var/www/html/astech/map/astech.map&"
        "WMS_SRS" "EPSG:3943"
        "WMS_FORMAT" "image/png"
        "WMS_ENABLE_REQUEST" "*"
        "WMS_PROXY_HOST" "192.168.1.201"
        "WMS_PROXY_PORT" "3128"
        "WMS_EXTENT" "1416170.749530 2220567.100330 1441220.549670 2248121.880470"
    END
  END
LAYER
    NAME "ADM.Communes_CDA"
    STATUS ON
    TYPE POLYGON
    TRANSPARENCY ALPHA
    CONNECTION "collaboratif/collaboratif@(DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=192.168.1.5)(PORT=1521))(CONNECT_DATA=(SERVICE_NAME=SIG)))"
    CONNECTIONTYPE ORACLESPATIAL
    DATA "SHAPE FROM (SELECT * FROM ADM.COMMUNES_CDA) USING UNIQUE OBJECTID SRID 3943"
    CLASS
        STYLE
            WIDTH 2
            OUTLINECOLOR 255 255 255
            #COLOR 255 255 255
            ANTIALIAS TRUE
        END
    END
    METADATA
            "wms_title" "ADM.Communes_CDA"
            "wms_transparent" "false"
            "wms_srs" "epsg:3943"
            "wms_extent"  "1416170.749530 2220567.100330 1441220.549670 2248121.880470"
    END
    PROJECTION
            "init=epsg:3943"
    END
END
END
Voici le .js :
var ortho;
var equip;
var map;
function init() {
    //etendu
    var extent = new OpenLayers.Bounds(1417000.000000,2222200.000000,1439800.000000,2247400.000000);
    //Projection
    var projlamb ='EPSG:3943';
    //Options de la carte
    var options={
        //new OpenLayers.Control.Navigation(),
        controls: [new OpenLayers.Control.PanZoomBar()],
        resolutions: [25,10,5,2,1,0.5,0.25,0.1,0.05],
        maxExtent: extent,
        maxResolution: 'auto',
        units: 'm',
        projection: projlamb,
        displayProjection: projlamb
    map = new OpenLayers.Map('map_canvas',options);
        map.addControl(new OpenLayers.Control.LayerSwitcher());
     equip = new OpenLayers.Layer.WMS("equip", "http://193.17.196.20/cgi-bin/mapserv?map=/var/www/html/astech/map/astech.map&",
    {layers:'basic',srs:'ESPG:3943',format:'image/png'});
    equip.id = 'equip';
    map.addLayer(equip);
Marion
#2 Tue 22 January 2013 17:52
Yves
Lieu: Aix-les-Bains
Re: OpenLayers WMS et Oracle
Dans ton objet layer dans ton code JavaScript tu as définie le paramètre layers à basic (en fait tu as laissé la valeur de l'exemple). Or cette couche n'apparait pas dans ton mapfile :
Ceci devrait corriger l'affaire :
{layers:'ADM.Communes_CDA',srs:'ESPG:3943',format:'image/png'});
#3 Wed 23 January 2013 16:06
petit_pied
Lieu: Pau
ça marche.
Merci beaucoup votre aide.
Marion
