#1 Sun 18 May 2008 18:28
Stella
Projection Europe
J'aurais aimé savoir quelle projection utiliser pour cartographier l'Europe?
#2 Mon 19 May 2008 09:44
cec_92
Re: Projection Europe
Pourquoi pas de l'UTM (Universal Transverse Mercator)?
#3 Mon 19 May 2008 09:55
JB
quelle Europe? wink L'Europe dite (anciennement) de l'Ouest ou de l'Est? l'Union des 27? l'Europe géographique? Les dimensions de la zone à projeter est un facteur de choix important.
Je crains que la projection UTM ne soit pas ce qu'il y a de mieux, car les déformations sur les bords vont être colossales! Je tenterais une conique ou une plate carrée.
JB
#4 Mon 19 May 2008 09:58
cec_92
Quelles projections, conique ou plate carrée, existent?
#5 Mon 19 May 2008 11:14
odurr
Lieu: Longwy
le programme Corine Landcover 2000 a été réalisé sous etrs89 (epsg=3035):
Reference system:
ETRS - Lambert Azimutal Equal Area
Datum
defines the position of the ellipsoid (spheroid) relative to the center of the earth D_ETRS_1989
Ellipsoid
When used to represent the earth, the three-dimensional shape obtained by rotating an ellipse about its minor axis. GRS_1980
Semi-major axis
Radius of the equatorial axis of the ellipsoid 6378137
Axis units
Unit of the semi-major axis Degrees
Flattening ratio
Radius of the equatorial axis of the ellipsoid 3.35281068118232E-03
Projection
a projected coordinate system designed for two-dimensional surface mapping Lambert_Azimutal_Equal_Area
False easting
A linear value added to the x-coordinate values, usually to ensure that all map coordinates are positive. 4321000 meters
False northing
A linear value added to the y-coordinate values, usually to ensure that all map coordinates are positive. 3210000 meters
Central median
Line of longitude at the centre of a map projection generally used as the basis for constructing the projection 10 degrees
Latitude of origin
Latitude chosen as the origin of rectangular coordinates for a map projection 52 degrees
Amicales salutations
Olivier
#6 Mon 19 May 2008 12:09
cec_92
OK, noté!
Merci.
#7 Wed 21 May 2008 22:43
Stella
Merci pour vos réponses.
Il s'agit de cartographier l'Europe Géographique.
