#1 Mon 02 March 2009 12:38
tawfik3221
Export Rasters
je cherche à exporter les layers avec ArcMap en utilisant un code (vba , vb, .net ....)
j'ai réussi à exporter les layers mais pas les rasters
je me demande si il y a un code pour exporter les rasters dans un répertoire donné
voici le code qui fait l'export des données :
Public Sub ExportAll_TOC()
Dim pDoc As IMxDocument
Dim pEnumLayer As IEnumLayer
Dim pLayer As IFeatureLayer
Dim pName As IName
Dim pLayerSet As ISet
Dim pMap As IMap
Dim pFC As IFeatureClass
Dim pINFeatureClassName As IFeatureClassName
Dim pDataset As IDataset
Dim pInDSName As IDatasetName
Dim pFields As IFields
Dim pField As IField
Dim pGeometryDef As IGeometryDef
Dim pFeatureClassName As IFeatureClassName
Dim pOutDatasetName As IDatasetName
Dim pWorkspaceName As IWorkspaceName
Dim pExportOp As IExportOperation
Set pDoc = Application.Document
Set pMap = pDoc.FocusMap
Set pEnumLayer = pMap.Layers
Set pLayerSet = New esriSystem.Set
pEnumLayer.Reset
Set pLayer = pEnumLayer.Next
Do Until pLayer Is Nothing
'Enumerate through the layers in the TOC and
'Get the Feature Class Name from the featureclass
    Set pFC = pLayer.FeatureClass
    Set pDataset = pFC
    Set pINFeatureClassName = pDataset.FullName
    Set pInDSName = pINFeatureClassName
    Set pFields = pFC.Fields
    Set pField = pFields.Field(lGeomIndex)
    Set pGeometryDef = pField.GeometryDef
    Set pFeatureClassName = New FeatureClassName
    Set pOutDatasetName = pFeatureClassName
    'Assign name to each exported layer
        pLayerSet.Add pLayer
        For i = 0 To pLayerSet.Count - 1
            X = pLayerSet.Count - 1
            pOutDatasetName.Name = pDataset.Name
        Next i
    Set pWorkspaceName = New WorkspaceName
    pWorkspaceName.PathName = "C:\temp"
    pWorkspaceName.WorkspaceFactoryProgID = "esriDataSourcesFile.ShapefileWorkspaceFactory"
    Set pOutDatasetName.WorkspaceName = pWorkspaceName
    'Export the layers in the TOC
    Set pExportOp = New ExportOperation
    pExportOp.ExportFeatureClass pInDSName, Nothing, Nothing, pGeometryDef, pOutDatasetName, hWnd
Loop
'Update the table of contents
pDoc.UpdateContents
End Sub
#2 Mon 02 March 2009 22:11
Jeirhome
Lieu: Liverion
Re: Export Rasters
En tapant "export raster" sur le site de référencede l'éditeur, j'ai trouvé la fonction IRasterLayerExport.Export
Ça devrait vous aider.
Jérôme Cuinet
