#1 Wed 20 May 2009 09:54
Pierre
DesCartesPourUnMondeMeilleur
Reprojection orthophoto : erreur "Memoire disponible insuffisante"
Aloha
Nous venons de procéder au test de reprojection de notre répertoire d'orthophoto. Le test se conclue par ce message d'erreur :
2009-05-19 17:42:25|  11.5|  0.0|STATS |Unexpected Input Remover(TestFactory): Tested 567 input features -- 567 features passed, 0 features failed.
2009-05-19 17:42:25|  11.5|  0.0|STATS |Unexpected Input Remover Nuker(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
2009-05-19 17:42:25|  11.5|  0.0|STATS |Source -> Generic(TeeFactory): Cloned 567 input feature(s) into 567 output feature(s)
2009-05-19 17:42:25|  11.5|  0.0|STATS |GEOTIFF (GEOTIFF_1) Splitter(TeeFactory): Cloned 567 input feature(s) into 1134 output feature(s)
2009-05-19 17:42:25|  11.6|  0.0|WARN  |Mosaicker: The resulting raster size of 108000 row(s) and 84000 column(s) is very large. Subsequent operations may take a long time
2009-05-19 17:42:25|  11.6|  0.0|INFORM|Reprojector: Using datum conversion type `SevenParm' when reprojecting from NTF_Reims_Lbt1 to RGF93.CC49
2009-05-19 17:42:25|  11.6|  0.0|INFORM|Reprojector: Reprojecting from source coordinate system 'NTF_Reims_Lbt1' to destination coordinate system 'RGF93.CC49'
2009-05-19 17:42:27|  13.7|  2.1|INFORM|Reprojector: Recalculating raster number of rows and columns from (108000, 84000) to (108744, 84959)
2009-05-19 17:42:27|  13.7|  0.0|INFORM|Reprojector: Recalculating raster cell size from (0.15, 0.15) to (0.15000470471182, 0.150004702711699)
2009-05-19 17:42:27|  13.7|  0.0|INFORM|Reprojector: Recalculating raster extents from (718000.05, 166600.05), (730600.05, 182800.05) to (1769648.86952442, 8221252.07696146), (1782393.11923203, 8237564.18835314)
2009-05-19 17:42:27|  13.7|  0.0|INFORM|FME Configuration: Destination coordinate system set to input coordinate system `RGF93.CC49'
2009-05-19 17:46:13| 196.9|183.2|FATAL |Insufficient memory available -- error code was 2 - please read the FME Help section 'Adjusting Memory Resources' for workarounds.
J'ai noté aussi ce message :
System Status: 1903MB of disk space available in the FME temporary directory (C:\DOCUME~1\FME2009\LOCALS~1\Temp\)
Que puis-je faire pour corriger ce problème ?
D'avance merci de votre aide, de votre retour d'expérience.
#2 Wed 20 May 2009 10:43
Sylvie
Re: Reprojection orthophoto : erreur "Memoire disponible insuffisante"
On est d'accord sur le diagnostic : manque d'espace dans le répertoire de travail temporaire
1/ Faire le ménage : Outils/Supprimer les fichiers temporaires
2/ Tu as la variable d'environnement FME_TEMP qui te permet de rediriger le répertoire temporaire par défaut.
Regarde dans l'Aide :
How FME uses temporary disk space et FME_TEMP_environment_variable
Bon courage
Sylvie
#3 Wed 20 May 2009 15:51
Matthieu-VEREMES
J'ai eu plusieurs retours sur ce type de problème notamment en cas de reprojection en RGF93 de gros fichiers ECW.
L'image est décompressée, chaque pixel est reprojeté puis tout est réassemblé et le fichier de sortie est écrit. Vous imaginez donc le travail que cela demande ainsi que l'espace disque temporaire nécessaire.
Il faut donc effectivement s'assurer de disposer d'un espace disque très important.
D'autre part les performances de FME 2010 lors de ce traitement sont encore améliorées, je conseille donc d'utiliser cette version pour ce cas précis.
Si ces deux conseils ne suffisent pas, je ne vois comme possibilité que la découpe de l'image d'origine, la reprojection des dalles puis leur assemblage.
Problème : on se retrouve avec des bandes noires sur le contour des dalles (à cause de la rotation due à la reprojection).
Une solution peut être l'ajout d'une bande alpha et l'option "composite with alpha band" de RasterMosaïcker ce qui permet de superposer les différentes dalles par dessus les pixels noirs.
Matthieu Ambrosy
Veremes : support FME & version française
support at veremes point com
#4 Thu 04 June 2009 17:48
Pierre
Pour info, une simple redéfinition de ma variable fme_temp a eu l'effet escompté : la traduction est effectuée.
Merci à tous les deux.
#5 Wed 06 January 2010 12:33
Luc_Bauge
Lieu: Tours
Je confirme qu'avec FME 2010 les traitements des ecw sont bien améliorés.
Par exemple, chez nous, le traitement d'un assemblage de tuiles ecw avec reprojection s'arrête à 20% sous FME 2009 (|FATAL |Insufficient memory available) mais il s'effectue correctement avec FME 2010 !
#6 Wed 06 January 2010 19:02
ogayte
Lieu: Saint-Estève
Safe annonce une réduction des besoins en mémoire de 50% pour le traitement des raster et un gain de performance de 5% avec FME 2010.
Olivier Gayte
http://www.veremes.com
+33 (0)4-68-38-65-27
#7 Thu 07 January 2010 00:39
Pierre
On attend de voir...
