#1 Tue 15 February 2011 15:08
WWS
OpenLayers - Mapserver - WFS
Besoin d'aide ...
Le problème : je n'arrive pas à afficher, par openlayers, des données issues de MapServer en WFS. En WMS, ça fonctionne.
J'ai cherché (longtemps) une solution en parcourant les forums et autres tutoriaux, sans succès. Je pense que le problème vient du .map plutôt que du .php, mais je mets les deux ci-dessous.
Le mapfile :
MAP
    NAME "Admin_Indonesie_WFS"
    SIZE 550 350
    EXTENT 95 -10 132 5
    UNITS METERS
    IMAGECOLOR 255 255 255
    SHAPEPATH "/var/www/mapserver/test"
    TRANSPARENT ON
        PROJECTION
            "init=epsg:4326"
        END
        WEB
            IMAGEPATH "/var/www/mapserver/test/tmp/"
            IMAGEURL "/mapserver/test/tmp/"
                METADATA
                    "original_projection"    "init=epsg:4326"
                    "wfs_title"        "TestWFS"
                    "wfs_onlineresource"    "http://127.0.0.1/cgi-bin/mapserv?"
                    "wfs_srs"        "epsg:4326"
            END
        END
        LAYER
            CONNECTIONTYPE WFS
            CONNECTION "/var/www/mapserver/test/indonesie_surface.tab"
            NAME Admin_Indonesie_WFS
                METADATA
                    "wfs_onlineresource"    "/var/www/mapserver/test/indonesie_surface.tab"
                    "wfs_version"    "1.0.0"
                    "wfs_srs"    "ESPG:4326"
                    "gml_featureid"    "SE_ASIA_"
                    "gml_include_items"    "all"
                END
                CLASS
                    STYLE
                        COLOR 0 0 0
                        OUTLINECOLOR 255 255 255
                    END
                END
            TYPE LINE
            DUMP TRUE
        END
END
Et le PHP :
<html>
<head>
<script type="text/javascript" src="http://127.0.0.1/openlayers/OpenLayers.js"></script>
<script type="text/javascript">
var map;
function init() {
    map = new OpenLayers.Map('map', {
        controls:[
            new OpenLayers.Control.Navigation(),
            new OpenLayers.Control.PanZoomBar(),
            new OpenLayers.Control.LayerSwitcher(),
            new OpenLayers.Control.Attribution()],
    maxExtent: new OpenLayers.Bounds(95,-15,125,10),
    units: 'dd',
    projection: new OpenLayers.Projection("epsg:4326"),
    displayProjection: new OpenLayers.Projection("epsg:4326")
var wfs = new OpenLayers.Layer.WFS(
"Admin_Indonesie_WFS",
"http://127.0.0.1/cgi-bin/mapserv?map=/var/www/mapserver/test/testWFS.map&",
{TYPENAME: 'Admin_Indonesie_WFS',layers: 'Admin_Indonesie_WFS', format: 'image/jpeg' }, {buffer: 1, isBaseLayer: true} );
    map.addLayers([wfs]);
            map.addControl(new OpenLayers.Control.Scale('scale'));
            map.addControl(new OpenLayers.Control.MousePosition());
</script>
</head>
<body onload="init()">
Test d'affichage de la carte d'Indonesie avec Openlayers en WFS sur MapServer.
<div id="map" style="width: 600px; height: 300px"></div>
</body>
Pour info, les codes pour le test en WMS, qui eux fonctionnent bien :
Le mapfile :
MAP
    NAME "Test"
    SIZE 550 350
    EXTENT 95 -10 132 5
    UNITS METERS
    TRANSPARENT ON
        PROJECTION
            "init=epsg:4326"
        END
        WEB
        END
        OUTPUTFORMAT
            NAME png
            DRIVER "GD/PNG"
            MIMETYPE "image/png"
            IMAGEMODE PC256
            EXTENSION "png"
        END
        LAYER
            STATUS ON
            CONNECTIONTYPE OGR
            TYPE LINE
                CLASS
                    STYLE
                        COLOR 0 0 0
                    END
                END
        END
END
et le PHP :
<html>
<head>
var map;
function init() {
        controls:[
    units: 'dd',
var wms = new OpenLayers.Layer.WMS(
"Admin_Indonesie",
"http://127.0.0.1/cgi-bin/mapserv?map=/var/www/mapserver/test/test.map&",
{layers: 'Admin_Indonesie'}
map.addLayers([wms]);
map.zoomToMaxExtent();
</script>
</head>
Test d'affichage de la carte d'Indonesie avec Openlayers en WMS sur MapServer.
</body>
Merci d'avance pour votre aide !
#2 Tue 15 February 2011 16:39
simon_g
Lieu: Paris
Re: OpenLayers - Mapserver - WFS
Tu peux jeter un coup d'oeil au tuto de geotribu : http://www.geotribu.net/node/42
me semble très incertain, car je ne suis pas sur que le niveau layer prend cet attribut et surtout car ca ne ressemble pas à une ressource en ligne.
#3 Wed 16 February 2011 09:24
WWS
Merci pour ta réponse.
J'ai suivi de près les différents tutoriaux de Geotribu, ça a fonctionné en partie, mais pas pour le WFS.
Je vais continuer à chercher !
Je posterai la solution, si je trouve. D'ici là, autres avis bienvenus !!!!
#4 Fri 29 March 2013 13:58
icadedt
Lieu: ici et là
moi de mon côté j'arive à afficher du wfs mapserver dans openlayers.
Le probleme c'est que je souhaite que la couche wfs ne s'affiche plus à partir d'un certain niveau de zoom,
j'ai essayé maxscale et minscale mais cela ne marche pas.
Auriez-vous une solution pour ne plus afficher une couche wfs au dela d'une certaine echelle?
