#1 Wed 16 March 2011 09:22
joe69
[Mapserver] Problème d'exécution
je viens d'installer mapserver sur un ubuntu. J'ai récupérer toutes les dernières versions pour chaque outils (gd, gdal, libpng etc...).
Lorsque j'essaie d'exécuter ce mapfile à partir de mon navigateur Web,
# Map file created from QGIS project file
# Edit this file to customize for your map interface
# (Created with PyQgis MapServer Export plugin)
MAP
  NAME "QGIS-MAP"
  # Map image size
  SIZE 100 100
  UNITS meters
  EXTENT -6.945564 41.133703 12.129085 51.314476
  PROJECTION
    'proj=longlat'
    'ellps=WGS84'
    'datum=WGS84'
    'no_defs'
  END
  # Background color for the map canvas -- change as desired
  IMAGECOLOR 255 255 255
  IMAGEQUALITY 95
  IMAGETYPE agg
  OUTPUTFORMAT
    NAME agg
    DRIVER 'AGG/PNG'
    IMAGEMODE RGB
  END
  # Legend
  LEGEND
    STATUS ON
    KEYSIZE 18 12
    LABEL
      TYPE BITMAP
      SIZE MEDIUM
      COLOR 0 0 89
    END
  END
  # Web interface definition. Only the template parameter
  # is required to display a map. See MapServer documentation
  WEB
    # Set IMAGEPATH to the path where MapServer should
    # write its output.
    IMAGEPATH '/tmp/'
    # Set IMAGEURL to the url that points to IMAGEPATH
    # as defined in your web server configuration
    IMAGEURL '/tmp/'
    # WMS server settings
    METADATA
      'ows_title'           'QGIS-MAP'
      'ows_onlineresource'  'http://localhost/cgi-bin/mapserv?map=/home/toto/limite_dep2.map'
      'ows_srs'             'EPSG:4326'
    END
    #Scale range at which web interface will operate
    # Template and header/footer settings
    # Only the template parameter is required to display a map. See MapServer documentation
    TEMPLATE 'fooOnlyForWMSGetFeatureInfo'
  END
  LAYER
    NAME 'LIMITE_DEPARTEMENT'
    TYPE LINE
    DUMP true
   TEMPLATE fooOnlyForWMSGetFeatureInfo
   DATA '/home/toto/LIMITE_DEPARTEMENT2.shp'
   METADATA
     'ows_title' 'LIMITE_DEPARTEMENT'
      "wfs_title"        "LIMITE_DEPARTEMENT"
        "gml_featureid"        "id_geofla"
        "GML_INCLUDE_ITEMS"     "all"
   END
   STATUS OFF
  TRANSPARENCY 100
   PROJECTION
   'proj=longlat'
   'ellps=WGS84'
  'datum=WGS84'
   'no_defs'
   END
 END
 END
voici le résultat :
Content-type: text/html msReturnPage(): Web application error. Malformed template name (fooOnlyForWMSGetFeatureInfo).
Je ne sais pas d'où sort ce fooOnlyForWMSGetFeatureInfo (apparemment ca vient de QGIS cf un autre post sur ce forum). Comment je pourrais faire dans mon cas ?
#2 Thu 17 March 2011 10:49
joe69
Re: [Mapserver] Problème d'exécution
Laisser tomber j'ai trouvé l'erreur mais je pense que je ne vous ai pas donné assez de détail pour que vous pussiez m'aider.
