#1 Fri 03 May 2013 11:39
- tima
mapserver
je suis une stagiaire et je veux afficher mon fichier mapfil sous openlayer
voila mon mapfil:
MAP
NAME "QGIS-MAP"
# Map image size
SIZE 100 100
UNITS meters
SHAPEPATH '../htdocs/data/'
EXTENT 373363.571767 209974.231693 383768.183072 214585.262078
#FONTSET './fonts/fonts.txt'
#SYMBOLSET './symbols/symbols.txt'
PROJECTION
'proj=lcc'
'lat_1=33.3'
'lat_0=33.3'
'lon_0=-5.4'
'k_0=0.999625769'
'x_0=500000'
'y_0=300000'
'a=6378249.2'
'b=6356515'
'towgs84=31,146,47,0,0,0,0'
'units=m'
'no_defs'
END
# Background color for the map canvas -- change as desired
IMAGECOLOR 255 255 255
IMAGEQUALITY 95
IMAGETYPE png
OUTPUTFORMAT
NAME png
DRIVER 'GD/PNG'
MIMETYPE 'image/png'
IMAGEMODE RGBA
EXTENSION 'png'
END
# Legend
LEGEND
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END
# Web interface definition. Only the template parameter
# is required to display a map. See MapServer documentation
WEB
# Set IMAGEPATH to the path where MapServer should
# write its output.
IMAGEPATH 'C:\ms4w\tmp\ms_tmp'
# Set IMAGEURL to the url that points to IMAGEPATH
# as defined in your web server configuration
IMAGEURL '/ms_tmp/'
# WMS server settings
METADATA
'wms_title' 'QGIS-MAP'
'wms_onlineresource' 'http://localhost:8080/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/pipes.map&'
'wms_srs' 'EPSG:26191'
END
#Scale range at which web interface will operate
# Template and header/footer settings
# Only the template parameter is required to display a map. See MapServer documentation
TEMPLATE 'fooOnlyForWMSGetFeatureInfo'
END
LAYER
NAME 'Pipes'
TYPE LINE
DUMP true
DATA '../htdocs/data/Pipes.shp'
METADATA
'wms_title' 'Pipes'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=lcc'
'lat_1=33.3'
'lat_0=33.3'
'lon_0=-5.4'
'k_0=0.999625769'
'x_0=500000'
'y_0=300000'
'a=6378249.2'
'b=6356515'
'units=m'
'no_defs'
END
CLASS
NAME 'Pipes'
STYLE
WIDTH 4.41
COLOR 86 236 186
END
END
END
END
le fichier javascript:
MAP
NAME "QGIS-MAP"
# Map image size
SIZE 100 100
UNITS meters
PROJECTION
'proj=lcc'
'lat_1=33.3'
'lat_0=33.3'
'lon_0=-5.4'
'k_0=0.999625769'
'x_0=500000'
'y_0=300000'
'a=6378249.2'
'b=6356515'
'units=m'
'no_defs'
END
IMAGEQUALITY 95
IMAGETYPE png
OUTPUTFORMAT
NAME png
DRIVER 'GD/PNG'
IMAGEMODE RGBA
EXTENSION 'png'
END
# Legend
LEGEND
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END
WEB
# write its output.
IMAGEURL '/ms_tmp/'
METADATA
'wms_onlineresource' 'http://localhost:8080cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/pipes.map&'
END
END
LAYER
NAME 'Pipes'
TYPE LINE
DUMP true
METADATA
'wms_title' 'Pipes'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=lcc'
'lat_1=33.3'
'lat_0=33.3'
'lon_0=-5.4'
'k_0=0.999625769'
'x_0=500000'
'y_0=300000'
'a=6378249.2'
'b=6356515'
'units=m'
'no_defs'
END
CLASS
NAME 'Pipes'
STYLE
WIDTH 4.41
COLOR 86 236 186
END
END
END
END
mercii à vous
Dernière modification par tima (Fri 03 May 2013 11:42)
#2 Fri 03 May 2013 11:49
- Renaud
- Lieu: Ploemeur (56)
Re: mapserver
La question aura plus sa place ici.
Je pense qu'il faudra la détailler : qu'est-ce qui bloque pour la publication ?
Renaud Mouche
#3 Fri 03 May 2013 12:19
- tima
Re: mapserver
j'arrive pas à voir mes couches, le code affiche la map plus un truc en rose
merci M Renaud,
#4 Fri 03 May 2013 12:23
- tima
Re: mapserver
mes couches sont en projection Lambert Conique conforme SRS: 26191
mon objective est de diffuser mes layer (WMS WFS) en utilisant Gqis, mapserver, et openlayers
#5 Fri 03 May 2013 22:18
- tima
Re: mapserver
votre aide s'il vous plait!!!! ![]()
