GeoDataDays 2025
#1 Mon 23 September 2013 11:30
celdia
QGIS 2.0 (Debian) : Erreur - impossible de faire une copie de qgis.db
Je viens d'installer ces jours QGIS 2.0 sur ma machine sous Debian Wheezy. Mais au lancement de QGIS, un message d'erreur apparait me siginfiant qu'il est impossible de faire une copie qgis.db. Et l'erreur python s'affiche:
Impossible de charger l'extension processing provoque une erreur lors de l'appel de sa méthode classFactory()
  File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 204, in startPlugin
    plugins[packageName] = package.classFactory(iface)
  File "/usr/share/qgis/python/plugins/processing/__init__.py", line 33, in classFactory
    return ProcessingPlugin(iface)
  File "/usr/share/qgis/python/plugins/processing/ProcessingPlugin.py", line 53, in __init__
    Processing.initialize()
  File "/usr/share/qgis/python/plugins/processing/core/Processing.py", line 127, in initialize
    Processing.addProvider(RAlgorithmProvider())
  File "/usr/share/qgis/python/plugins/processing/core/Processing.py", line 75, in addProvider
    provider.initializeSettings()
  File "/usr/share/qgis/python/plugins/processing/r/RAlgorithmProvider.py", line 51, in initializeSettings
    ProcessingConfig.addSetting(Setting(self.getDescription(), RUtils.RSCRIPTS_FOLDER, "R Scripts folder", RUtils.RScriptsFolder()))
  File "/usr/share/qgis/python/plugins/processing/r/RUtils.py", line 55, in RScriptsFolder
    mkdir(folder)
  File "/usr/share/qgis/python/plugins/processing/core/ProcessingUtils.py", line 95, in mkdir
    mkdir(head)
  File "/usr/share/qgis/python/plugins/processing/core/ProcessingUtils.py", line 97, in mkdir
    os.mkdir(newdir)
OSError: [Errno 13] Permission non accordée: '/home/cellou/.qgis2//processing'
Version de Python :
2.7.3 (default, Jan  2 2013, 14:09:21)
[GCC 4.7.2]
Version de QGIS :
2.0.1-Dufour Dufour, exported
Chemin vers Python : ['/usr/share/qgis/python/plugins/processing', '/usr/share/qgis/python', '/home/cellou/.qgis2/python', '/home/cellou/.qgis2/python/plugins', '/usr/share/qgis/python/plugins', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/PIL', '/usr/lib/pymodules/python2.7/gtk-2.0', '/usr/lib/python2.7/dist-packages/gst-0.10', '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7', '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode', '/usr/share/qgis/python/plugins/fTools/tools']
Tout de même QGIS s'ouvre bien avec l'interface. Mais ce message d'erreur est bien gênant.
Merci à l'avance de votre aide.
#2 Mon 23 September 2013 11:47
PA
Lieu: Paris
Re: QGIS 2.0 (Debian) : Erreur - impossible de faire une copie de qgis.db
Tester la suppression de qgis.db dans le dossier ~/.qgis2
(garder une copie quelque part).
Le fichier devrait recréé automatiquement.
#3 Mon 23 September 2013 13:31
celdia
Merci de ton aide, ça marche maintenant.
Cependant je remarque (peut être que je dois ouvrir un autre sujet),toujours que qgis ne reconnait pas la clé publique d'import gpg.
Une mise à jour avec apt-get update donne (pour les paquets qgis):
W: Erreur de GPG : http://qgis.org wheezy Release : Les signatures suivantes n'ont pas pu être vérifiées car la clé publique n'est pas disponible : NO_PUBKEY BBA6491F47765B75
Cellou
#4 Mon 23 September 2013 14:16
PA
Lieu: Paris
Rebonjour,
C'est un problème non lié à QGIS directement mais à votre système d'installation via apt.
Taper :
gpg --recv-key 1F9ADD375CA44993
gpg --export --armor 1F9ADD375CA44993 | sudo apt-key add -
pour ajouter la clé correspondante aux dépôts qgis.org
#5 Mon 23 September 2013 16:12
celdia
Merci de ta rapide réaction.
Mais apparemment, l'export de la clé n'a toujours pas réussi.
Est-ce 'identifiant exacte de la clé?
root@libres:/home/cellou# gpg --recv-key 1F9ADD375CA44993gpg: demande de la clef 5CA44993 sur le serveur hkp keys.gnupg.net
?: keys.gnupg.net: Connection refused
gpgkeys: HTTP fetch error 7: couldn't connect: Connection refused
gpg: aucune donnée OpenPGP valable n'a été trouvée.
gpg:       Quantité totale traitée : 0
root@libres:/home/cellou# gpg --export --armor 1F9ADD375CA44993 | sudo apt-key add-
gpg: Attention : rien n'a été exporté
Usage: apt-key [--keyring file] [command] [arguments]
Manage apt's list of trusted keys
  apt-key add <file>          - add the key contained in <file> ('-' for stdin)
  apt-key del <keyid>         - remove the key <keyid>
  apt-key export <keyid>      - output the key <keyid>
  apt-key exportall           - output all trusted keys
  apt-key update              - update keys using the keyring package
  apt-key net-update          - update keys using the network
  apt-key list                - list keys
  apt-key finger              - list fingerprints
  apt-key adv                 - pass advanced options to gpg (download key)
If no specific keyring file is given the command applies to all keyring files.
Je suis bien curieux de connaître la source du problème, même si ça n'empêche pas qgis de tourner.
Cellou
#6 Mon 23 September 2013 16:21
PA
Lieu: Paris
celdia a écrit:
Est-ce l'identifiant exacte de la clé?
En effet, je n'en suis pas certain.
#7 Mon 23 September 2013 18:55
PA
Lieu: Paris
gpg --recv-key 47765B75
gpg --export --armor 47765B75 | sudo apt-key add -
#8 Tue 24 September 2013 16:45
celdia
Ok merci encore une fois
#9 Tue 01 October 2013 12:39
Samy-DT
J'ai exactement le même problème sous Ubuntu.
Impossible en revanche de trouver qgis.db. "no such file or directory".
Je suis passé par le terminal en tapant :cd ~/.qgis2 puis j'ai listé avec ls. Je n'ai qu'un dossier gdal_pam.
A la sourie, j'ai essayé de trouver ce dossier .qgis2 mais je ne l'ai pas trouvé.
Savez-vous comment je peux procéder ?
Merci.
#10 Wed 02 October 2013 12:32
celdia
Bonjour Samy-DT
Effectivement ce bogue persiste encore chez moi (sous débian), je le croyais résolu, mais apparemment non.
Je crois que l'erreur doit aussi être liée à la version de python.
Tu peux faire :
more ~/.qgis2/qgis.db]
pour voir ce que ça donne.
#11 Sat 12 October 2013 16:28
Pascal Boisson
j'ai apparamment résolu le pb en suivant les indications http://hub.qgis.org/issues/8613#note-4
It also happens on Ubuntu 12.04. Deleting ~/.qgis2 and running QGIS from the command line by typing "qgis" stops QGIS from creating that folder as root.
The icon that Unity creates runs "sudo qgis" instead of "qgis".
#12 Sat 12 October 2013 19:03
PA
Lieu: Paris
Merci Pascal
